| Anticipating a workbench view [message #520338] |
Thu, 11 March 2010 19:38  |
Marian Schedenig Messages: 25 Registered: July 2009 |
Junior Member |
Hi!
I'm using this code to find the console view in my plug-in's workbench:
IWorkbenchWindow activeWorkbenchWindow =
PlatformUI.getWorkbench().getActiveWorkbenchWindow();
IWorkbenchPage activePage = activeWorkbenchWindow.getActivePage();
IConsoleView consoleView = (IConsoleView)
activePage.findView(IConsoleConstants.ID_CONSOLE_VIEW);
Right now I'm using this to modify an action contributed via an extension
when my plug-in is activated (since what I'm doing isn't possible
declaratively). I'd prefer to do this before the user executes my action,
i.e. before lazy activation initialises my plug-in.
Which leads me to my question: Is there a way to register some kind of
listener that is notified when a specific view is opened? I can have my
plug-in initialise during Eclipse startup using the startup extension, but
at this point the workbench doesn't seem to be sufficiently initialised to
do my thing (and also I'm not sure how much I can generally rely on the
overall initialisation progress I see in my debugger).
My idea would be to register a listener somewhere on the workbench which is
notified when the console view first opens, so that it can immediately
modify (or, in this case, simply create) my desired action.
Thx,
Marian.
| Re: Anticipating a workbench view [message #520588 is a reply to message #520369] |
Fri, 12 March 2010 18:07   |
Junior Member |
Prakash G.R. wrote:
>> is notified when the console view first opens, so that it can immediately
> Check IPerspectiveListener.perspectiveChanged()
Thanks.
I just tried it, looking through the various versions of
IPerspectiveListener. It doesn't seem to help my problem, though: I can use
the IStartup interface and extension to fetch the workbench window when it's
created and attach a perspective listener. I then get events in the listener
whenever the *user* changes the perspective, e.g. by switching between
views.
However, more often than not, the view I'm interested in is already shown
when the workbench starts. And I don't seem to get any events for the
initial views shown after the workbench has opened.
Marian.
| Re: Anticipating a workbench view [message #520595 is a reply to message #520588] |
Fri, 12 March 2010 20:08  |
Junior Member |
Never mind. When the view is visible in the workbench's startup
configuration, I can find it via the workbench window in my early startup
method. If it's not there, I register the IPerspectiveListener and check for
it on perspective activations/changes. Once I find it, I do my thing and
unregister the listener.
Seems to work like a charm.
Marian.
FUDForum. Page generated in 0.01530 seconds
