| Configuration Tomcat v6 problems on Galileo Eclipse [message #519920] |
Wed, 10 March 2010 09:15 |
Jhonny Frias Messages: 1 Registered: March 2010 |
Junior Member |
Hello comunity,
I need help with the use of Tomcat with Galileo Eclipse.
I have configured tomcat v6.0.20 on OS Fedora 10, just installed Galileo Eclipse, and import a war project that have 7 months in production with other service as Mysql, Zimbra, some java libs... imports occurred well, and the application web runs very well with tomcat v 6.0.20 without problems.
Now, I try to add the Tomcat server in Eclipse IDE and gives me some errors, they say you can not add the server, then I managed to do it, I do not know how!, and when I attempt to Start the following error:
"Could not load the Tomcat server configuration at /Servers/Tomcat v6.0 Server at localhost-config. The configuration may be corrupt or incomplete."
I still have not managed to understand the error and apparently all is well. Please, if you can help us, thank you ...
[Updated on: Wed, 10 March 2010 09:20] Report message to a moderator
| Re: Configuration Tomcat v6 problems on Galileo Eclipse [message #519940 is a reply to message #519920] |
Wed, 10 March 2010 05:00  |
Larry Isaacs Messages: 1261 Registered: July 2009 |
Jhonny Frias wrote:
> Hello comunity,
> problems.
> incomplete."
> well. Please, if we can help, thank you ...
See if this question in the WTP Tomcat FAQ helps:
http://wiki.eclipse.org/WTP_Tomcat_FAQ#When_I_try_to_create_ a_server.2C_it_says_that_it_.22Could_not_load_the_Tomcat_ser ver_configuration..22_What_is_the_problem.3F
If you are still unable to get it working, being more specific than
"gives me some errors" would help. I suspect the server creation was
only partially successful, leading to the Start error.
If any of the error dialogs offer a Details button, be sure to take a
look. You might also check the Error Log view to see if there are any
relevant messages provided there.
Larry
FUDForum. Page generated in 0.01540 seconds
