Home » Modeling » MOFScript » call transformation from Java API
call transformation from Java API [message #518924] Fri, 05 March 2010 08:19 Go to next message
yeliu is currently offline yeliu
When running the TestAPI.java , there is NullPointer exception and the problem is located in the following lines.
protected int parse (String transformation) {
File f = new File (transformation);
MOFScriptSpecification spec = parserUtil.parse(f, true);
The debugging shows that f is null , and parserUtil is null too. And specification of the parserUtil used in this program couldn't be found. We run out of any possible solutions. What's the problem and any way to solve this problem. Thanks for reply!
M
Re: call transformation from Java API [message #519751 is a reply to message #518924] Tue, 09 March 2010 15:35 Go to previous message
Gøran K. Olsen is currently offline Gøran K. Olsen
have you tried runiing the TestAPI in debugmode?
There you should be abel to see what you have done wrong.
Based on the provided information I am not abel to pin point the error.
G
Previous Topic:MOFScript:generate output with the same filename as the source file
Next Topic:call transformation from Java API
Current Time: Thu May 23 10:05:45 EDT 2013
Powered by FUDForum. Page generated in 0.07327 seconds
