Home » Eclipse Projects » BIRT » Hiding empty rows in a cross tab
Hiding empty rows in a cross tab [message #518550] Thu, 04 March 2010 08:08 Go to next message
Damian Sirbu is currently offline Damian Sirbu
Greetings everyone.
I am looking for a solution to hide empty rows in a crosstab, using java event handlers. (the 'row' may contain elements from several groups and a summary field)
My problem is that I did not found any suitable event handler to extend, or a 'crosstab' javscript object in the documentation.
Any hint or advice would be appreciated.
Thank you
Re: Hiding empty rows in a cross tab [message #518652 is a reply to message #518550] Thu, 04 March 2010 11:58 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Damian,
There is a property for hiding empty rows. Select the crosstab, then
the property editor, then Empty Rows/Columns.
Jason
Damian Sirbu wrote:
> Greetings everyone.
> a summary field)
> Thank you
Jason Weathersby
BIRT Exchange
Re: Hiding empty rows in a cross tab [message #518656 is a reply to message #518652] Thu, 04 March 2010 07:16 Go to previous messageGo to next message
For script take a look at this blog post.
http://birtworld.blogspot.com/2010/02/birt-crosstab-scriptin g.html
Jason
Jason Weathersby wrote:
> Damian,
> Jason
> Damian Sirbu wrote:
>> Greetings everyone.
>> Thank you
Jason Weathersby
BIRT Exchange
Re: Hiding empty rows in a cross tab [message #519312 is a reply to message #518550] Mon, 08 March 2010 08:38 Go to previous messageGo to next message
Thanks, I will give it a try.
Another question: is there any way that, while using BIRT report viewer from eclipse, I could print some output to the eclipse console?
If I call System.out from any part of the report, nothing happens.
Re: Hiding empty rows in a cross tab [message #519372 is a reply to message #519312] Mon, 08 March 2010 06:26 Go to previous messageGo to next message
Damian,
Take a look at this post:
http://birtworld.blogspot.com/2010/01/quick-and-dirty-loggin g.html
Jason
Jason Weathersby
BIRT Exchange
Re: Hiding empty rows in a cross tab [message #519556 is a reply to message #518550] Tue, 09 March 2010 05:15 Go to previous message
Thanks, this is one method I used - 'dirty' to say at least Smile
I am using swing JFrame to output text atm, but I am still not pleased.
I wonder why System.out does not write to eclipse's embedded console. I think it's locked by BIRT's own logging framework.
If so, maybe we could hook into it..
Previous Topic:Problems with images from shared resources in PDF output
Next Topic:DataSet column as flat String
Current Time: Fri May 24 21:31:24 EDT 2013
Powered by FUDForum. Page generated in 0.02097 seconds
