Home » Eclipse Projects » BIRT » Download report as file (PPT or PDF) not working(download popup appears, but "opened so far" endlessly )
| Download report as file (PPT or PDF) not working [message #518490] |
Thu, 04 March 2010 04:51  |
tero Messages: 58 Registered: July 2009 |
Member |
Birt Version: 2.5.1.v20090624
Eclipse Version: 3.5.0.v20090611a
Windows XP
I am working on a big report, but experienced this also with smal reports, and also on another PC:
I open the report with the WebViewer, which runs as expected and I can see every page, but when I try to download the report as a file (I tested it with PPT (the required format) and PDF) the "saving pop up" window appears and starts displaying the "transfer rate" (around 200 KB/Sec) and the "Opened so far", which is counting and counting with apparently no end (I wait until 200MB and cancelled, the report should be around 3 MB as PPT).
I also tried producing directly a PPT file from the Report Designer in Eclipse, which has the same result.
The aim of this project is to have the report as a file, which I was able to do so far. But suddenly now (after days and days of development) this is not possible anymore.
Any idea is very welcome.
Thanks.
| Re: Download report as file (PPT or PDF) not working [message #518657 is a reply to message #518490] |
Thu, 04 March 2010 07:16   |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Tero,
Are you getting anything in the log file?
Jason
> Windows XP
> Hello,
> Thanks.
Jason Weathersby
BIRT Exchange
| Re: Download report as file (PPT or PDF) not working [message #519374 is a reply to message #519060] |
Mon, 08 March 2010 11:24   |
Member |
Hello Jason,
Thanks for your recommendations. I changed the MaxPermSize accordingly and now the report is deploying.
I also found the logs in the metadata folder. I could not change the log level though.
After doing that I was able to see some warnings which I solved accordingly. E.g.:
05-Mar-2010 18:37:15 org.eclipse.birt.report.engine.executor.css.HTMLProcessor execute
SEVERE: There is a invalid value for property SIZE of element FONT in the HTML.
Nonetheless this is not solving the "download" problem. The logs in Tomcat, where I can define the log level, are no giving a hint.
The last line of log after the report builds is:
FINE: Finished preparing query.
then I click on "Export report" | PDF
and the download starts but never ends until I get an out of memory after about 5 minutes and a report size of more than 200 MB.
the log only says:
08-Mar-2010 14:20:58 org.eclipse.birt.report.engine.api.impl.RenderTask render
SEVERE: An OutOfMemory error happened while running the report.
08-Mar-2010 14:20:58 org.eclipse.birt.data.engine.impl.DataEngineImpl shutdown
FINE: Data engine shuts down
This looks like a neverending loop which puts objects in the memory...
I tried also downloading with other formats, here the results:
PPT (required for the project) + PDF: download never ends until out of memory
DOC: download apparently successful, but file not opening with the message: "Unspecified error" Error location: Line 1234, Column: 21
XLS: download apparently successful, but in a strange format + with no charts
I had a look at the line of code pointed by the DOC error and could not see anything wrong:
<w:r>
<w:rPr>
<w:color w:val="000000"/>
<w:rFonts w:ascii="Verdana" w:fareast="Verdana" w:h-ansi="Verdana" w:cs="Verdana"/>
<w:sz w:val="16"/>
<w:sz-cs w:val="16"/>
<w:spacing w:val="0"/>
<w:jc w:val="center"/>
</w:rPr>
<w:t><![CDATA[Availability Target 99.98%]]></w:t>
</w:r>
Line 1234, Column: 21 is in the ">" in <w:r>
I experimented taking some attributes from there and even the whole <w:r> but then the same error is coming for another line like that one further down in the doc (and another and another...). The strange thing is that there are other <w:r> sections not causing errors and I cannot recognise any difference with the one above.
Another interesting issue is that if
- I use the Eclipse Birt Viewer and I try to download the report there,
- cancel because of download growing beyond 200 MB (ppt should be 4 MB) and taking very long
- and closing the Viewer and closing Eclipse
the Windows Task Manager is still showing the process "eclipse.exe" and that process has a continuously increasing "Mem Usage" and it has to be stopped manually there.
I don't know what I could try else. Spent already hours and hours and still no clue...
Any ideas?
Thanks!
[Updated on: Mon, 08 March 2010 11:27] Report message to a moderator
| Re: Download report as file (PPT or PDF) not working [message #519382 is a reply to message #519374] |
Mon, 08 March 2010 11:50   |
Tero,
Can open a bug for this and post the report to the bug?
Jason
tero wrote:
> Hello Jason,
> level though.
> accordingly. E.g.:
> the HTML.
> the log only says:
> render
> shutdown
> memory
> charts
> see anything wrong:
> <w:r>
> <w:rPr>
> <w:sz w:val="16"/>
> </w:rPr>
> </w:r>
> Another interesting issue is that if - I use the Eclipse Birt Viewer and
> I try to download the report there, - cancel because of download growing
> beyond 200 MB (ppt should be 4 MB) and taking very long - and closing
> still no clue...
> Any ideas?
> Thanks!
Jason Weathersby
BIRT Exchange
| Re: Download report as file (PPT or PDF) not working [message #519602 is a reply to message #519382] |
Tue, 09 March 2010 07:41   |
Member |
Hello Jason,
I found the problem after reducing the report bit by bit until it was possible to download it and then including the excluded pages one by one.
The section causing the issue is a page with three tables. These have, by default, a "Page Break Interval" of 40.
These tables go beyond the 40, but already by 25 (aprox) they are already crossing the page size defined in the Master Page.
How I see this is: there is no problem in displaying that configuration in the Birt Viewer, but as soon as I want to download it as a page-abled format (PDF, PPT, DOC (XLS did it)), there is a conflict between those "page break" definitions and the engine gets itself in an infinite loop.
I hope this helps others so that they don't have to spend days in debugging. A big handicap here is that the logs, even if FINEST, do not give a hint to the issue.
Tero
[Updated on: Tue, 09 March 2010 07:57] Report message to a moderator
| Re: Download report as file (PPT or PDF) not working [message #519613 is a reply to message #519602] |
Tue, 09 March 2010 08:42  |
Tero,
Thanks for the update. Can you update the bug?
Jason
tero wrote:
> Hello Jason,
> by default, a "Page Break Interval" of 40. These tables go beyond the
> debugging.
> Tero
Jason Weathersby
BIRT Exchange
Current Time: Fri May 24 06:06:28 EDT 2013
Powered by FUDForum. Page generated in 0.02627 seconds
