| Which use case to choose? [message #517972] |
Tue, 02 March 2010 11:05 |
Alexey Messages: 61 Registered: January 2010 |
Member |
Hello!
The real use case I want to implement using AMW is this one:
1. An input Metamodel in xml ( and input model conforms to input Metamodel);
2. An output Metamodel in xml (and output model conforms to output Metamodel);
3. Some transformation rules to convert the input Model to output Model;
(The reason, I want to make the transformation in AMW and not in ATL is that AMW lets me to set the transformation rules on the Metamodel-level.)
Please, could someone tell me, which sample-usecase I should implement for that? There are a lot of on the AMW-page.
Thank you!
Alexey
FUDForum. Page generated in 0.02111 seconds
