Home » Eclipse Projects » Web Tools Project (WTP) » Server for static web site(All desvers lost. Need to recreate for static web site)
Server for static web site [message #517459] Sun, 28 February 2010 06:05 Go to next message
Ulf Andersson is currently offline Ulf Andersson
Hi, I tried to search the forum, but I was not successful.
I suppose I need a server (instance?) in eclipse to be able to publish my changes to a web site.
Problem is, I lost all my servers in eclipse and now I can not recreate the Apache server. I do not have Tomcat, nor can I install one. That is not an option for me. But all I see when I try to follow the instructions in the manual / on line help, is application servers like tomcat.
If this is not the proper forum, then please advice me of one.
Please help me I'm lost.
Bes regards,
/Ulf Andersson
Re: Server for static web site [message #517623 is a reply to message #517459] Mon, 01 March 2010 04:56 Go to previous message
Larry Isaacs is currently offline Larry Isaacs
> tomcat.
> Bes regards,
> /Ulf Andersson
You might mention with version of WTP you are using. Assuming it is a
fairly recent one, try Windows -> Preferences -> Server -> Runtime
Environments, click Add and expand Basic. Does HTTP Preview (I believe
uses internal Jetty as the server) or HTTP Server (uses publish
location) serve your needs?
Larry
Previous Topic:JSP from multiple directories
Next Topic:Query on RAD with open source tools
Current Time: Sat May 18 20:00:52 EDT 2013
Powered by FUDForum. Page generated in 0.02114 seconds
