| Suppress attributes for EMF Compare? [message #517445] |
Sat, 27 February 2010 22:08  |
PB Messages: 4 Registered: February 2010 |
Junior Member |
I want to use EMF Compare, but get a lot of noise due to certain attributes I don't want to compare.
Is it possible to suppress attributes during the matching process?
Per
| Re: Suppress attributes for EMF Compare? [message #518835 is a reply to message #518802] |
Fri, 05 March 2010 04:07  |
Laurent Goubet Messages: 1548 Registered: July 2009 |
--------------030108030403040205050605
Content-Type: text/plain; charset=UTF-8; format=flowed
There could be a number of reasons why your engine is not called :
1) you registered it against the wrong extension / namespace
2) you registered it against ecore with "lowest" priority (same as the
generic engine), thus the generic engine is called instead
You can work around 2) by either setting an higher priority or ticking
the option "Comparison engine selection" on the EMF Compare preference
page. If you're not calling EMF Compare from the Eclipse GUI, you'll
have to programatically set your own IMatchEngineSelector through
MatchService#setMatchEngineSelector() and IDiffEngineSelector through
DiffService#setDiffEngineSelector() so that they return your engines.
Laurent Goubet
Obeo
PB wrote:
> Thanks!
> I created my subclass like this:
> public class MyDiffEngine extends
> org.eclipse.emf.compare.diff.engine.GenericDiffEngine implements
> IDiffEngine {
> I added it to the extension 'org.eclipse.emf.compare.diff.engine'
> However running a compare does not use my class (I have print statements
> in it).
> Per
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------030108030403040205050605--
| Re: Suppress attributes for EMF Compare? [message #622272 is a reply to message #518802] |
Laurent Goubet
Obeo
PB wrote:
> Thanks!
> IDiffEngine {
> in it).
> Per
FUDForum. Page generated in 0.01629 seconds
