Home » Modeling » M2T (model-to-text transformation) » XPand workflows and documentation?
XPand workflows and documentation? [message #510285] Wed, 27 January 2010 01:08 Go to next message
Erik Putrycz is currently offline Erik Putrycz
According to http://www.openarchitectureware.org Xpand has workflows to run the transformations. However I cannot find any trace in the Eclipse XPand documentation... Is there any recent documentation?
Re: XPand workflows and documentation? [message #510454 is a reply to message #510285] Wed, 27 January 2010 09:58 Go to previous messageGo to next message
Sven Efftinge is currently offline Sven Efftinge
The Modeling Workflow Engine (MWE) is documented here :
http://help.eclipse.org/galileo/index.jsp
Sven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: XPand workflows and documentation? [message #512331 is a reply to message #510285] Thu, 04 February 2010 12:10 Go to previous messageGo to next message
MJ  is currently offline MJ
Hi there,
sorry for reacitvating this thread but it also might help Mr. Putrycz.
I've a question regarding xpand.
Where do I find an "overall" documentation for it?
The documentation in the eclipse "overall" documentation (http://help.eclipse.org/galileo/index.jsp) does not really help me. As stated there: This documentation describes the general syntax and semantics of the Xpand language.
In my case, I'm doing a thesis and I'm trying to gather some basic information about the oAW ingredients, especially Xpand.
I have a very specific question regarding code generation.
An oAW tutorial ( http://www.openarchitectureware.org/pub/documentation/4.3.1/ html/contents/emf_tutorial.html ) uses a EMF model for codegeneration.
For me it is important to know if an EMF model is required in any case and ESPECIALLY where to find a valid reference to cite.
So that why I would like to have a document which provides such basic informations, at best for all oAW components.
Hopefully someone can provide me something, since through the migration to EMP, it seems to be really hard to find any good information.
Best regards!
[Updated on: Thu, 04 February 2010 12:10]
Report message to a moderator
Re: XPand workflows and documentation? [message #512609 is a reply to message #512331] Fri, 05 February 2010 10:37 Go to previous messageGo to next message
MJ schrieb:
> Where do I find an "overall" documentation for it? The documentation in
The reference documentation is all we have.
If you search the web you might find lots of tutorials and other
information. But if you're looking for something official from the
authors you'll have to live with that.
What's wrong with it? Is it too extensive or not extensive enough?
> An oAW tutorial (
No. It provides a configurable type system which currently supports EMF,
UML, XSD and any Java classes.
And you can even execute code without any models (EMF or not), e.g. by
passing a list of strings or the like.
> and ESPECIALLY where to find a valid reference to cite. So that why I
When moved from oAW to EMP we have migrated the reference documentation
as is. We haven't had any other documents you could cite, had we?
Sven
Re: XPand workflows and documentation? [message #513524 is a reply to message #512609] Wed, 10 February 2010 08:31 Go to previous messageGo to next message
>What's wrong with it? Is it too extensive or not extensive >enough?
In my opinion its not extensive enough. It does not provide enough "overall" knowledge I want to gain in order to write something about general stuff.
>No. It provides a configurable type system which currently >supports EMF,
>And you can even execute code without any models (EMF or >not), e.g. by
I'm sorry, I'm pretty new to oAW and I might have to specify my question.
Are you referring to the options that can be imported into EMF for creating an Ecore model from them? In that case I have to rephrase my question.
Do I need an Ecore model in order to generate code with Xpand?
>When moved from oAW to EMP we have migrated the >reference documentation
>as is. We haven't had any other documents you could cite, had >we?
I don't know. I've not that much experience in this field so I can not answer this question.
Anyways, thank you Sven for directly answering to my post.
I really appreciate it.
[Updated on: Wed, 10 February 2010 08:51]
Re: XPand workflows and documentation? [message #517017 is a reply to message #510285] Thu, 25 February 2010 13:25 Go to previous message
Hello Mr. Putrycz,
since you did not answer in this thread again I don't know if you have found what you were searching for, but since I had the same questions I have some suggestions.
On the oAW homepage you can find some good tutorial videos:
http://www.openarchitectureware.org/staticpages/index.php/oa w_screencasts
For me, I can say the "helloworld" video helped me pretty much.
A 2nd source of information I've found in the following book:
http://www.amazon.co.uk/Eclipse-Modeling-Project-Domain-Spec ific-Language/dp/0321534077/ref=sr_1_1?ie=UTF8&s=books&a mp;a mp;qid=1267122221&sr=8-1
I have not finished the book but chapter 7 and 14, as you can see on the page, cover xpand.
Hopefully I can help some people who were searching for something like this.
[Updated on: Thu, 25 February 2010 13:26]
Previous Topic:[Xpand] Regression when migrating from 0.7.0 to 0.8.0M5
Next Topic:problem running jet.transform task
Current Time: Mon May 20 03:31:49 EDT 2013
Powered by FUDForum. Page generated in 0.01779 seconds
