| What happened to the Projects Tab ? [message #515717] |
Fri, 19 February 2010 16:59  |
sasha Messages: 58 Registered: July 2009 |
Member |
I haven't used Eclipse since 3.1, and downloaded galileo Java EE bundle.
however a lot of things seem to have changed.
I am looking for Java Build Path, under Project->Properties and only see
Resource
Builders
Project References
Run/Debug Settings
Server...
and so on.
I am looking for what it used to be
Info
Builders
Java Build Path
Java code Style
Java compiler
Project References
| Re: What happened to the Projects Tab ? [message #516991 is a reply to message #515717] |
Thu, 25 February 2010 11:45  |
Eric Rizzo Messages: 2011 Registered: July 2009 |
> Resource
> Builders
> Project References
> Run/Debug Settings
> Server...
> and so on.
> Info
> Builders
> Java Build Path
> Java code Style
> Java compiler
> Project References
Note: this topic is probably better placed in the Java Development Tools
(JDT) group; I'm copying it there.
The most likely reason you don't see a Java Build Path option is that
the project you're looking at is not actually a Java project. When you
created it, what did you select?
Hope this helps,
Eric
| Re: What happened to the Projects Tab ? [message #568403 is a reply to message #515717] |
> Resource
> Builders
> Project References
> Run/Debug Settings
> Server...
> and so on.
> Info
> Builders
> Java Build Path
> Java code Style
> Java compiler
> Project References
Hope this helps,
Eric
FUDForum. Page generated in 0.01629 seconds
