Home » Modeling » GMF (Graphical Modeling Framework) » Can a label be associated with the canvas
Can a label be associated with the canvas [message #516258] Tue, 23 February 2010 06:58 Go to next message
Dennis Hendriks is currently offline Dennis Hendriks
Member
Hello all,
in my ecore, the top-level class is Specification. This class has an attribute called 'annotations'. The 'Specification' class is mapped in GMF to the canvas itself. I would like to add a label to the canvas (upper-left corner of the canvas is fine), that shows the content of the annotations attribute. I couldn't figure out where to map in the gmfmap however, as it seems a 'Top Node Reference' is needed, but there I can not select the 'annotations' attribute as 'Containment feature'.
My question is: Is is possible to map an attribute of the top-level class to a label associated with the canvas itself? if so, how? If not, why not, and what are the alternatives?
Any help would be greatly appreciated.
Dennis
Re: Can a label be associated with the canvas [message #963480 is a reply to message #516258] Mon, 29 October 2012 17:15 Go to previous messageGo to next message
Hristina Pavlovska is currently offline Hristina Pavlovska
Dear Dennis,
Did you maybe find the solution for your problem? I'm facing the same challenge so would like to know if the canvas's label is possible and how to do it.
Hristina
Re: Can a label be associated with the canvas [message #964110 is a reply to message #963480] Tue, 30 October 2012 05:05 Go to previous message
Member
No, I never found out. But then again, I never looked into it again. We are looking into switching from GMF to Graphiti though, so I'm not sure it is an issue any more...
Previous Topic:GMF EXPORT DIAGRAM AS XML
Next Topic:Internationalize : org.eclipse.gmf.runtime.diagram.ui.
Current Time: Sun May 19 17:44:22 EDT 2013
Powered by FUDForum. Page generated in 0.01643 seconds
