Home » Eclipse Projects » Rich Client Platform (RCP) » PartInitException when running RCP application outside of Eclipse (Plugin missing on export)
PartInitException when running RCP application outside of Eclipse (Plugin missing on export) [message #515455] Thu, 18 February 2010 14:41 Go to next message
Jennifer is currently offline Jennifer
I have a bit of a frustrating situation. I have an RCP application that runs perfectly fine from within Eclipse. When I export it, two of my views don't show up and I get a PartInitException. The plugin with the views is in the dependencies of the product I'm exporting so I don't understand why I'm getting this issue.
Exception
!ENTRY org.eclipse.ui 4 4 2010-02-18 14:26:30.375
!MESSAGE Exception in org.eclipse.ui.internal.FolderLayout.addView(String): org.eclipse.ui.PartInitException: View descriptor not found: org.eclipse.contribution.visualiser.views.Visualiser
!STACK 1
at org.eclipse.ui.internal.FolderLayout.addView(FolderLayout.ja va:75)
at rcpapp.Perspective.createInitialLayout(Perspective.java:39)
at org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Pers pective.java:817)
at org.eclipse.ui.internal.Perspective.createPresentation(Persp ective.java:271)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:157)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation. createPerspective(Workbench3xImplementation.java:55)
at org.eclipse.ui.internal.WorkbenchPage.createPerspective(Work benchPage.java:1666)
at org.eclipse.ui.internal.WorkbenchPage.init(WorkbenchPage.jav a:2447)
at org.eclipse.ui.internal.WorkbenchPage.<init>(WorkbenchPage.java:564)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation. createWorkbenchPage(Workbench3xImplementation.java:39)
at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:758)
at org.eclipse.ui.internal.Workbench$21.runWithException(Workbe nch.java:1045)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at rcpapp.Application.start(Application.java:20)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
!SUBENTRY 1 org.eclipse.ui 4 0 2010-02-18 14:26:30.375
!MESSAGE View descriptor not found: org.eclipse.contribution.visualiser.views.Visualiser
Code
IFolderLayout flayout = layout.createFolder( FI_LEFT, IPageLayout.BOTTOM, 0.75f, editorAreaId );
flayout.addView("org.eclipse.ui.views.ContentOutline");
flayout.addView("org.eclipse.contribution.visualiser.views.Visualiser ");
flayout.addView("org.eclipse.contribution.visualiser.views.Menu ");
It's just the two visualiser views that don't add. I tried to add the plugin to the configuration plugin list as well since I saw one post about that. But then the exported application doesn't run at all, I get a java.lang.IllegalStateException.
Thanks!
[Updated on: Thu, 18 February 2010 16:53]
Report message to a moderator
Re: PartInitException when running RCP application outside of Eclipse [message #515461 is a reply to message #515455] Thu, 18 February 2010 14:49 Go to previous messageGo to next message
I should also mention the preferences for that plugin are not there either, so it's like it's just not getting included on export, even though it's in the dependency list.
Re: PartInitException when running RCP application outside of Eclipse [message #515481 is a reply to message #515461] Thu, 18 February 2010 17:06 Go to previous message
I FINALLY figured it out after trying everything.
I hadn't correctly configured what needed to be included on the binary build of the plugin that was missing. On the build tab of plugin.xml, I hadn't checked under binary build, the icons folder (needed for views) and the plugin.xml file to include.
They are included when running from Eclipse, so it gets confusing when it doesn't run on the RCP app.
Anyways, hope this helps someone else Smile
Previous Topic:Product export - osgi.bundle missing
Next Topic:Extension details do not get filled automatically
Current Time: Sun May 26 03:59:09 EDT 2013
Powered by FUDForum. Page generated in 0.01551 seconds
