Home » Eclipse Projects » Rich Client Platform (RCP) » about dialog menu entry
about dialog menu entry [message #515278] Thu, 18 February 2010 05:49 Go to next message
Luca Ferrari is currently offline Luca Ferrari
I've inserted the command in a menu of my application to show the about dialog, but the menu entry is not shown. Here there's the excerpt of my plugin.xml file:
<menu
               id="hrpm.rcp.menu.aiuto"
               label="Aiuto"
               mnemonic="A">
            <command
                  commandId="org.eclipse.ui.help.about"
                  icon="img/info.png"
                  id="hrpm.rcp.menu.aiuto.about"
                  label="Informazioni sull&apos;applicazione"
                  style="push"
                  tooltip="Visualizza le informazioni di rilascio di questa applicazione">
            </command>
         </menu>
so the menu "Aiuto" is visible, but the entry of the about dialog is not visible. Am I missing something?
Re: about dialog menu entry [message #515322 is a reply to message #515278] Thu, 18 February 2010 08:41 Go to previous messageGo to next message
Daniel Krügler is currently offline Daniel Krügler
On 18.02.2010 11:49, Luca Ferrari wrote:
> plugin.xml file:
> <menu
> label="Aiuto"
> mnemonic="A">
> <command
> icon="img/info.png"
> style="push"
> </command>
> </menu>
Your description misses several elementary details: What kind
of extension point are you using? I would have expected that
you use "org.eclipse.ui.menus", but your xml does not look so.
Greetings from Bremen,
Daniel Krügler
Re: about dialog menu entry [message #515329 is a reply to message #515322] Thu, 18 February 2010 09:02 Go to previous messageGo to next message
>> plugin.xml file:
>> <menu
>> label="Aiuto"
>> mnemonic="A">
>> <command
>> icon="img/info.png"
>> style="push"
>> </command>
>> </menu>
Sorry, I misread your xml assuming it would start with the
menuContribution element. I assume that you need to use
"org.eclipse.ui.help.aboutAction"
as command id.
- Daniel
Re: about dialog menu entry [message #515386 is a reply to message #515278] Thu, 18 February 2010 10:54 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
Luca Ferrari wrote:
> <command
Daniel is correct, that's not the right ID. 2 helpful hints.
1) When adding a commandId, use the Browse... button. You can type in
*about and it will narrow down the valid IDs for you.
2) you can use org.eclipse.ui.IWorkbenchCommandConstants in 3.5 and 3.6
to find the most common commands that we've published.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: about dialog menu entry [message #515399 is a reply to message #515386] Thu, 18 February 2010 11:40 Go to previous message
Thank you, I was using the wrong command id!
Previous Topic:Show Headless RCP application output in cmd.exe (not osgi console)
Next Topic:Product export - osgi.bundle missing
Current Time: Sun May 19 20:24:36 EDT 2013
Powered by FUDForum. Page generated in 0.02097 seconds
