| Re: How to inform JSDT infer engine to load a specified file? [message #515183 is a reply to message #515141] |
Wed, 17 February 2010 21:54   |
Nitin Dahyabhai Messages: 1857 Registered: July 2009 |
On 2/17/2010 4:14 PM, sean lee wrote:
> Hello all,
> In this customized JSDT infer engine in a plug-in, I want the infer
> engine to infer certain JavaScript files. But it seems that eclipse only
> infers the single file which is currently opened in the editor.
> To give an specific example, I have two files: A.js and B.js. In A.js I
> defined a super class of another class defined in B. So when B.js is
> opened in the editor, I want the jsdt infer engine to infer both A.js
> and B.js. Unfortunately, Eclipse only infers B.js. Is there any API that
> allows me to call? It might be API call as
> "InferEngine.includeInfer("A.js")".
I thought I already answered this in a bug report earlier today,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=303103 . If the two files
are on the Include Path of a JavaScript project, the infer engines will
be run on them both automatically. Even then, just running the
InferEngine on both files isn't useful by itself.
What are you hoping to accomplish by running the InferEngine on both files?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
| Re: How to inform JSDT infer engine to load a specified file? [message #515374 is a reply to message #515183] |
Thu, 18 February 2010 10:36  |
sean lee Messages: 2 Registered: February 2010 |
Junior Member |
Thanks for the reply. By running the infer engine on both files, I want to use the auto-completion (code assistant) for JavaScript subclasses. That is, currently if we define a field, say, A.foo in A.js, and when we type in "this." in B.js, I want the auto-completion menu to fill the rest part, which should be "this.foo".
Moreover, there are 100 JavaScript files in our test environment. All of them are under the same folder. Certainly, we can add the folder into the include path of the project, but the system's performance will therefore be slowed down.
| Nitin Dahyabhai wrote on Wed, 17 February 2010 21:54 |
Nitin Dahyabhai
IBM Rational
FUDForum. Page generated in 0.01648 seconds
