Home » Eclipse Projects » Web Tools Project (WTP) » Axis2 Client web service config Port Name ConverterSOAP11port_http not found
Axis2 Client web service config Port Name ConverterSOAP11port_http not found [message #231699] Thu, 21 May 2009 04:19 Go to next message
Kumar Prateek is currently offline Kumar Prateek
hi,
i have been trying to create and test a web service following the steps
mentioned in the tutorial at -
http://www.eclipse.org/webtools/community/tutorials/BottomUp Axis2WebService/bu_tutorial.html
however, in the step to create a web service client on the Axis2 Client
web service configuration screen i dont get the option to select
ConverterSOAP11port_http under the port name list.
Please note that i have axis 2 1.4 installed and using tomcat v6.0 to
create and test this web service.
Please help me with this.
regards,
Kumar
Re: Axis2 Client web service config Port Name ConverterSOAP11port_http not found [message #515277 is a reply to message #231699] Thu, 18 February 2010 05:41 Go to previous message
Hans  is currently offline Hans
hi
some ppls answer http://dev.eclipse.org/newslists/news.eclipse.webtools/msg18 693.html
but i dont understand the answer.
where i can set
definition.addNamespace(SCHEMA_FOR_SCHEMA_PREFIX,
XSDConstants.SCHEMA_FOR_SCHEMA_URI_2001);
if i do this tutorial: http://www.eclipse.org/webtools/community/tutorials/BottomUp Axis2WebService/bu_tutorial.html
i cant see anything about definition namespace
thanx for ur help
hans
[Updated on: Thu, 18 February 2010 06:06]
Report message to a moderator
Previous Topic:Web module question
Next Topic:Strange plugin-file (strict.dtd) validation error with legacy web services.
Current Time: Sat May 18 09:11:27 EDT 2013
Powered by FUDForum. Page generated in 0.02614 seconds
