| Adding an item to the Source/generateGroup???? [message #515126] |
Wed, 17 February 2010 14:39 |
sheamus Messages: 14 Registered: September 2009 |
Junior Member |
I am trying to add an action to the Source menu, in the group with the generate getter/setter.
I can get my action to appear in the edit menu, if I set menubarPath="edit/editEnd", but I can't seem to get it into the source menu.
I examined the plugin.xml from org.eclipse.jdt.ui.jar. The getter an setter actions in there use menubarPath="org.eclipse.jdt.ui.source.menu/generateGroup". But when I try that, my action does not show up at all.
The following is my my plugin.xml:
<?eclipse version="3.4"?>
<plugin>
<extension
point="org.eclipse.ui.editorActions">
<editorContribution
targetID="org.eclipse.jdt.ui.CompilationUnitEditor"
id="BuilderPatternPlugin.actionSet">
<action
label="&Sample Action"
icon="icons/sample.gif"
class="builderpatternplugin.actions.BuilderPatternAction"
tooltip="Hello, Eclipse world"
id="builderpatternplugin.actions.BuilderPatternAction">
</action>
</editorContribution>
</extension>
</plugin>
~S
FUDForum. Page generated in 0.01482 seconds
