| Re: Problem with euGENia [message #586377 is a reply to message #515009] |
Wed, 17 February 2010 08:47  |
Dimitrios Kolovos Messages: 1772 Registered: July 2009 |
Hi Zied,
Which version of Java are you using? If you're not using 1.6 I'd suggest
upgrading and giving this another go.
Dimitris
Zied wrote:
> hi
> i'm doing the tutorial of euGENia but when i try to generate mfgraph,
> gmftool
> i get this message : The chosen operation is not currently available.
> and when i try to add emf file from wizard i get this message :
> "The selected wizard could not be started.
> Plug-in org.eclipse.epsilon.util.emf was unable to load class
> org.eclipse.epsilon.util.emf.NewEmfModelWizard.
> Bad version number in .class file"
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
FUDForum. Page generated in 0.01961 seconds
