Home » Modeling » M2T (model-to-text transformation) » MWE(Resource and platform behaviour)
MWE [message #514931] Wed, 17 February 2010 04:08 Go to next message
No real name is currently offline No real name
I am not exactly sure this is the correct forum but I don't see any dedicated place for MWE subjects...
I am using the fornax maven plugin to run the MWE workflows and I am having problems with platform;:/resource uri if I am building a hierarchical project structure with Maven instead of flat projects...
If Ib uild everything flat, platform uri's are working correctly with platformUri=".." configuration but if I configure the projects hierharchically it complains that there is no mapping for the projects...
so flat project from Maven look like this, if I start the build from projectA it is able to resolve projectB with following uri platform:/resouce/projectB/...
projectA
projectB
projectC
in the hierarchical project, if I start the build from projectA the previous uri naturally doesn't function platform:/resouce/projectB/... but unfortunately platformUri is like projectA/projectA setted so platform:/resouce/projectA/projectB/... doesn't function also..
projectA
+-----projectB
+-----projectC
So the question for me, I now that eclipse favors flat structures so that mean I have no chance with the hierarchical structure or this is just bug....
PS. I also tried platformUri="." that doesn't function
Re: MWE [message #515198 is a reply to message #514931] Thu, 18 February 2010 01:59 Go to previous messageGo to next message
Sven Efftinge is currently offline Sven Efftinge
The right place to ask MWE questions would be the emft newsgroup (MWE is
part of EMFT).
I org.eclipse.emf.mwe.utils.StandaloneSetup.setPlatformUri(Str ing) we
just iterate over the contents of the specified folder (ie '..') and add
an entry to the platform resource map for each contained folder.
> projectA
> projectB
> projectC
Are you saying that platform:/resource/projectA works, while
platform:/resource/projectA/projectB doesn't work.
Although projectB physically resides within projectA?
Sven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: MWE [message #515204 is a reply to message #515198] Thu, 18 February 2010 02:44 Go to previous message
Exactly,
In the hierarchical structure projectA contains the projectB but as platformUri '/projectA/projectA' which naturally not true that is what I am seeing from log output...
I tried all possible versions of platformUri="..", platformUri=".", platformUri="../.", platformUri="../.." all to no avail...
Btw, thx for the tip, I would create the thread also in EMFT forums...
Previous Topic:Any way to generate only one file?
Next Topic:[Acceleo] Generators interface ?
Current Time: Mon May 20 14:30:35 EDT 2013
Powered by FUDForum. Page generated in 0.01649 seconds
