Home » Modeling » UML2 Tools » Many Use Case diagrams and one model
Many Use Case diagrams and one model [message #514737] Tue, 16 February 2010 09:08 Go to next message
Jean-Louis Leroy is currently offline Jean-Louis Leroy
I am a newcomer to Eclipse and EMF. I am trying to create a series of Use Case diagrams based on the same model.
After creating a first diagram (File!New!Other!UML 2.1 Diagrams!Use Case Diagram) and putting a few objects on it (an actor, a few use cases) I created a new diagram with <right-click digram>!New Diagram!Use Case. The new diagram contains the same objects as the previous diagram. Is there a way of creating an empty diagram based on the same model ?
Next I remove objects from the diagram (using <right-click>!Delete from Diagram). I see that they continue to exist on other diagrams as well as in the .uml file. Good. Now how can I add those objects again if I need to ?
In fact here is what I would like to do : create a new project ; create a use case diagram - and its underlying model ; create objects in the diagram ; create a new empty diagram ; add existing, selected objects to the new diagram ; create new objects ; etc...
I suspect that I am asking an obvious question here. In my defense I have spent several hours on the web looking for information on how to do this, both on the EMF site and in google results, without success...
Jean-Louis Leroy
Re: Many Use Case diagrams and one model [message #514818 is a reply to message #514737] Tue, 16 February 2010 12:37 Go to previous message
Vlad Varnica is currently offline Vlad Varnica
[Updated on: Wed, 10 March 2010 09:06]
Report message to a moderator
Previous Topic:tagged value
Next Topic:Many Use Case diagrams and one model
Current Time: Thu May 23 00:02:26 EDT 2013
Powered by FUDForum. Page generated in 0.05309 seconds
