Home » Modeling » Epsilon » attaching eugenia generated diagram with editor
attaching eugenia generated diagram with editor [message #513730] Wed, 10 February 2010 19:10 Go to next message
saad bin abid is currently offline saad bin abid
Member
Hello Epsilon Users,
I am currently working on a project. I have generated diagram editor using Eugenia. In the run-time environment i am creating both .xxx_diagram and .xxx model. I am evaluating constraints on .xxxx_diagram and can see the markers. but in order to get the same markers on the .xxxx model i have to go to the model and right-click->validate.
Question- Is it possible to make both work side by side? means if markers appear on xxxx_diagram than at the same time it should appear on the .xxxx model as well.
any suggestions please.
thank you very much
saad
Re: attaching eugenia generated diagram with editor [message #513737 is a reply to message #513730] Wed, 10 February 2010 21:28 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Hi Saad,
This should be possible but will most probably require some additional
code. As this is clearly a GMF question, I'd suggest asking in the GMF
newsgroup to see if anyone there can provide some pointers. If not,
please let me know and I'll have a look at this...
Dimitris
> thank you very much
> saad
Re: attaching eugenia generated diagram with editor [message #514531 is a reply to message #513737] Mon, 15 February 2010 12:11 Go to previous messageGo to next message
Member
Dear Dimitris,
I was expecting an answer in the gmf community but didn't get it so far. I am in a hurry a bit as i have to complete the project very soon. Is it possible for you to please help me resolve the above mention challenge?
cheers
saad
Re: attaching eugenia generated diagram with editor [message #514575 is a reply to message #514531] Mon, 15 February 2010 14:37 Go to previous messageGo to next message
Hi Saad,
I'll try to have a look at this within the next few days.
Dimitris
> Dear Dimitris,
> cheers
> saad
Re: attaching eugenia generated diagram with editor [message #514578 is a reply to message #514575] Mon, 15 February 2010 14:51 Go to previous message
Member
Hello dimitris,
thank you very much looking forward to it.
regards
saad
Re: attaching eugenia generated diagram with editor [message #586184 is a reply to message #513737] Mon, 15 February 2010 12:11 Go to previous message
Member
Dear Dimitris,
cheers
saad
Re: attaching eugenia generated diagram with editor [message #586225 is a reply to message #514531] Mon, 15 February 2010 14:37 Go to previous message
Hi Saad,
Dimitris
> Dear Dimitris,
> cheers
> saad
Re: attaching eugenia generated diagram with editor [message #586267 is a reply to message #514575] Mon, 15 February 2010 14:51 Go to previous message
Member
Hello dimitris,
regards
saad
Previous Topic:Making an ETL rule extend two rules
Next Topic:Eugenia: Nodes with images instead of shapes
Current Time: Tue May 21 17:21:04 EDT 2013
Powered by FUDForum. Page generated in 0.01773 seconds
