Home » Eclipse Projects » Plugin Development Environment (PDE) » Headless PDE build, missing required plug-ins!
Headless PDE build, missing required plug-ins! [message #514475] Mon, 15 February 2010 09:02
Matthias Kohles is currently offline Matthias Kohles
Member
Hey there,
i'm trying to build a rcp application by using the headless pde scripts (eclipse 3.5.1), but i'm running in some problems.
Every time i start the build, i receive those "Some inter-plug-in dependencies have not been satisfied" messages. The strange thing is that the build will not abort or fail, it just continues with no compilation errors???
For example, i have this snippet of the error message.
java] [eclipse.buildScript] Bundle org.eclipse.emf.nl_de:
     [java] [eclipse.buildScript] 	Host plug-in org.eclipse.emf_0.0.0 has not been found.
     [java] [eclipse.buildScript] Bundle org.eclipse.emf.nl_es:
     [java] [eclipse.buildScript] Bundle org.eclipse.emf.nl_fr:
     [java] [eclipse.buildScript] Bundle org.eclipse.emf.nl_it:
     [java] [eclipse.buildScript] Bundle org.eclipse.emf.nl_nl:
     [java] [eclipse.buildScript] Bundle org.eclipse.emf.nl_no:
     [java] [eclipse.buildScript] Bundle org.eclipse.emf.nl_pt_BR:
However, those plugins are in my baselocation which is set in build.properties. Does anyone have an idea or solution for solving this problem?
thanks in advance
best regards
Matthias
Previous Topic:Re: How to reduce hard-coding IDs
Next Topic:Headless PDE build, missing required plug-ins!
Current Time: Tue May 21 22:27:06 EDT 2013
Powered by FUDForum. Page generated in 0.01874 seconds
