Home » Eclipse Projects » Rich Client Platform (RCP) » rcp and junit test
rcp and junit test [message #514229] Fri, 12 February 2010 17:19 Go to next message
Eclipse User
Originally posted by: nospam.somewhere.org
How can a implement a junit test for a rcp application?
My application uses eclipse/rcp and consists of several rcp plugin
projects. Some plugins are gui and others are non-gui. A single plugin
may reference other plugins.
My first step is to implement the junit in a rcp plugin project.
Now, google search found some interesting tools: tptp agr and swtbot.
Some comercial project are found, too. But my interest in costfree tools.
questions:
1. The tptp automated gui recorder sounds good, but the documentation is
very rare. The docs i found seems to be for an older version of eclipse.
I am not sure how to control this tool :-(
Any idea?
2. SWTBOT, the docs seem to be more complete but i havent used it. Do
you think it is a worthful alternative to tptp?
3. Are there other free testing tools available?
How do you implement junit tests for rcp based applications?
regards,
markus
Re: rcp and junit test [message #514276 is a reply to message #514229] Sat, 13 February 2010 07:40 Go to previous messageGo to next message
Christian is currently offline Christian
Member
Am 12.02.2010 23:19, schrieb Ceeper:
> regards,
> markus
On question 4: My first shot for simple rcp testing was to just write a
little IApplication that runs all the tests..
and put it in a fragment of your plugin under Test so you get full
access to all classes in the plugin.
here some exmple code for runnign the tests:
import org.eclipse.core.runtime.Status;
import org.eclipse.equinox.app.IApplication;
import org.eclipse.equinox.app.IApplicationContext;
import org.junit.runner.JUnitCore;
import org.junit.runner.Result;
import org.junit.runner.notification.Failure;
import uc.crypto.BloomFilterTest;
import uc.protocol.hub.AdcHubTest;
import uc.protocol.hub.NmdcHubTest;
public class AllTests implements IApplication {
private static final Class<?>[] TEST_CASES= new Class[]
{BloomFilterTest.class,
NmdcHubTest.class,
AdcHubTest.class};
public Object start(IApplicationContext context) throws Exception {
for (Class<?> c:TEST_CASES) {
Result res = JUnitCore.runClasses(c);
if (res.wasSuccessful()) {
System.out.println("Success: "+c.getSimpleName()+" NrOfTest:
"+res.getRunCount()+" Time: "+(res.getRunTime()/1000)+"sec");
} else {
for (Failure f: res.getFailures()) {
System.out.println(f.getDescription().getDisplayName());
f.getException().printStackTrace();
break;
System.out.println("Failure: "+c.getSimpleName());
return Status.OK_STATUS;
public void stop() {
probably there is a better way... though that pretty much was simple and
did the Job for me...
Christian
Re: rcp and junit test [message #514416 is a reply to message #514229] Mon, 15 February 2010 04:27 Go to previous message
Mickael Istria is currently offline Mickael Istria
I am a big fan of SWTBot, and I think it is worth trying. It makes writing user-level tests very easy. Moreover, it can be integrated in headless unit tests suite as easily as simple JUnit tests.
Simply write some JUnit plugins tests (ie JUnit tests that have access to Eclipse runtime, UI and workbench classess). When writing them you can launch them from Eclipse as you would run simple JUnit tests.
If you want to test them in your built RCP application, you'll have to:
* Provide test, and dependency and Eclipse test framework in your application (for example as an additional feature).
* Run your test headless from inside of your application using the org.eclipse.test.uitestapplication (see http://www.eclipse.org/articles/Article-PDE-Automation/autom ation.html)
The difficulty here is to provide right dependencies so that your test will start.
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Previous Topic:small exclamation icon on build.properties
Next Topic:Problem while exporting RCP
Current Time: Tue May 21 21:25:19 EDT 2013
Powered by FUDForum. Page generated in 0.04709 seconds
