Home » Eclipse Projects » Rich Client Platform (RCP) » IDE without projects and workspace(Get rid of projects, have source files somwhere on filesystem)
icon5.gif  IDE without projects and workspace [message #513499] Wed, 10 February 2010 07:09 Go to next message
Florian Philipp is currently offline Florian Philipp
Member
Hi!
This is my first RCP project and I could need some help finding the right starting point for what I intend to do:
I'm trying to create a lightweight standalone IDE for a domain specific language we use in-house. Surprisingly enough, it took me less time to create the editor plugin using Xtext than to design the GUI around it.
In our use case, all source files lie on a Samba share with a three or four levels deep directory structure. I cannot allow to clutter this with Eclipse settings, project files etc. In fact, it would be great to get rid of the concept of projects altogether and only work with the directory structure and the files.
I thought this would be rather easy; all I need is some kind 'Resources' view where the root is an arbitrary path, not the workspace; but I just can't figure out how to do this with minimum effort.
Do I really need to create a whole new ViewPart or ContentProvider for this?
If I need to, how are the files and folders represented in Eclipse; IResource, IFile?
If it matters, I'm on Eclipse 3.5; Sun JDK 1.5.
Thanks in advance for any hints!
Florian Philipp
Re: IDE without projects and workspace [message #513601 is a reply to message #513499] Wed, 10 February 2010 11:21 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
> this?
> IResource, IFile?
resources are based on the workspace and that's what provides settings,
..project files, etc. You won't be able to re-use IResource/IFile etc.
It seems to me you have 4 choices.
1) use a workspace and create projects in there. But have your source
folder "linked" to where they live on the Samba share, so that the
eclipse project/resources info won't show up there
2) define your own Common Navigator view and provide your own content
provider that works with the file system FileStore and
org.eclipse.ui.ide.FileStoreEditorInput
3) create your own navigator view and embed a
org.eclipse.jface.viewers.TreeViewer, and then back your viewer model by
regular java io objects. Basically create your own file system
navigator. Use FileStoreEditorInput and IWorkbenchPage.openEditor(*) to
do it.
4) find someone that's done something similar that's has a consumable
license and work with that.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: IDE without projects and workspace [message #514307 is a reply to message #513601] Sat, 13 February 2010 17:42 Go to previous message
Member
Thanks!
I'll look into it.
Florian Philipp
Previous Topic:How to resize a SourceViewer inside a Dialog?
Next Topic:small exclamation icon on build.properties
Current Time: Tue May 21 10:38:11 EDT 2013
Powered by FUDForum. Page generated in 0.03262 seconds
