| Problem with XPand2 and UML Profiles [message #513466] |
Wed, 10 February 2010 05:26  |
Markus Messages: 15 Registered: September 2009 |
Junior Member |
Hey guys,
I want to Transform a model into text. I have modelled my model with MagicDraw 15.x and exported it as a EMF 2.x file.
The MagicDraw uml model is based on an UML Profile, named
"SdkApiProfile".
My workflow-file looks like:
<?xml version="1.0"?>
<workflow>
<property name="src-gen" value="src-gen" />
<bean class="org.eclipse.xtend.typesystem.uml2.Setup" standardUML2Setup="true" />
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
<platformUri value="."/>
</bean>
<bean id="mmUML"
class="org.eclipse.xtend.typesystem.uml2.UML2MetaModel">
</bean>
<bean id="sdkApiProfil"
class="org.eclipse.xtend.typesystem.uml2.profile.ProfileMetaModel">
<profile value="platform:/resource/src/metamodel/uml/SdkApiProfile.profile.uml"/>
</bean>
<component class="org.eclipse.emf.mwe.utils.Reader">
<uri value="platform:/resource/src/model.uml"/>
<modelSlot value="model"/>
</component>
<component class="org.eclipse.xpand2.Generator">
<metaModel idRef="sdkApiProfil"/>
<metaModel idRef="mmUML"/>
<metaModel class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel"/>
<fileEncoding value="Cp1252"/>
<expand value="template::Template::Main FOR model"/>
<genPath value="${src-gen}"/>
</component>
</workflow>
My Xpand-Template is very simple
«DEFINE Main FOR SdkApiProfile::DomainModel»
«FILE "test.xmap"-»
«REM»do some stuff...«ENDREM»
«EXPAND PackageIteration FOREACH ownedElement.typeSelect(uml::Package).select(e|e.name=="root")-»
«ENDFILE-»
«ENDDEFINE»
«DEFINE PackageIteration FOR uml::Package»
«EXPAND PackageIteration FOREACH this.ownedElement.typeSelect(uml::Package)-»
«EXPAND Typedef FOREACH this.ownedType-»
«ENDDEFINE»
«DEFINE Typedef FOR SdkApiProfile::Data»
«ENDDEFINE»
«DEFINE Typedef FOR uml::Enumeration»
«ENDDEFINE»
the problem is, that in Main-Template, the generator expects an uml::Model, but it is also a SdkApiProfil::DomainModel. And I do not know how to tell Xpand (or MWE) that the imported model.uml has stereotypes, which are located in SdkApiProfile.profile.uml. I think it is already done in workflow-file, as you see above.
Can you help me to fix the problem?
kind regards
Markus
| Re: Problem with XPand2 and UML Profiles [message #513490 is a reply to message #513466] |
Wed, 10 February 2010 01:50   |
--------------080508050009050805040507
Content-Type: text/plain; charset=UTF-8; format=flowed
Markus,
in your workflow please try using only the profile mm - this refres
already to UML2 MM and ecore MM
</component>
ekke
Am 10.02.10 11:26, schrieb Markus:
> Hey guys,
> MagicDraw 15.x and exported it as a EMF 2.x file. The MagicDraw uml
> model is based on an UML Profile, named "SdkApiProfile".
> <workflow>
> </bean>
> <bean id="mmUML"
> </bean>
> class="org.eclipse.xtend.typesystem.uml2.profile.ProfileMetaModel ">
> <profile
> value=" platform:/resource/src/metamodel/uml/SdkApiProfile.profile.u ml "/>
> </bean>
> <uri value="platform:/resource/src/model.uml"/> <modelSlot
> value="model"/>
> </component>
> <metaModel
> class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel "/>
> </component>
> </workflow>
> «FILE "test.xmap"-»
> ownedElement.typeSelect(uml::Package).select(e|e.name=="root ")-»
> «ENDFILE-»
> «ENDDEFINE»
> «ENDDEFINE»
> «ENDDEFINE»
> «ENDDEFINE»
> kind regards
> Markus
ekke (ekkehard gentz)
independent software-architect
senior erp-consultant
eclipse | osgi | equinox | mdsd | oaw | emf | uml
max-josefs-platz 30, D-83022 rosenheim, germany
mailto:ekke@ekkes-corner.org
homepage (de): http://gentz-software.de
blog (en): http://ekkes-corner.org
twitter: @ekkescorner
skype: ekkes-corner
Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID: DE189929490
Content-Type: text/html; charset=UTF-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Markus, <br>
<br>
already to UML2 MM and ecore MM<br>
<br>
....<br>
<br>
<br>
<br>
<br>
<br>
<br>
</component>
<br>
....<br>
<br>
ekke<br>
<blockquote cite="mid:hku1kj$po1$1@build.eclipse.org" type="cite">Hey
guys,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<workflow>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</bean>
<br>
<br>
<bean id="mmUML"
<br>
</bean>
<br>
<br>
<br>
<profile
<br>
</bean>
<br>
<br>
<br>
<br>
</component>
<br>
<br>
<br>
<br>
<br>
<metaModel
<br>
<br>
<br>
<br>
<br>
</component>
<br>
<br>
</workflow>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
«FILE "test.xmap"-»
<br>
<br>
<br>
«ENDFILE-»
<br>
«ENDDEFINE»
<br>
<br>
<br>
<br>
<br>
<br>
«ENDDEFINE»
<br>
<br>
<br>
<br>
«ENDDEFINE»
<br>
<br>
<br>
<br>
«ENDDEFINE» <br>
<br>
<br>
<br>
<br>
<br>
<br>
kind regards
<br>
Markus
<br>
</blockquote>
<br>
<br>
<div class="moz-signature">-- <br>
<p style="margin-bottom: 0cm;"> <font ,="" color="#808080"
face="Verdana, sans-serif"> <font size="4">ekke (ekkehard gentz)<br>
</font> <font size="3"> independent software-architect<br>
senior erp-consultant<br>
</font> <font size="2">eclipse | osgi | equinox | mdsd | oaw | emf |
uml<br>
max-josefs-platz 30, D-83022 rosenheim, germany<br>
<a class="moz-txt-link-freetext" href="mailto:ekke@ekkes-corner.org">mailto:ekke@ekkes-corner.org</a><br>
homepage (de): <a class="moz-txt-link-freetext" href="http://gentz-software.de">http://gentz-software.de</a><br>
blog (en): <a class="moz-txt-link-freetext" href="http://ekkes-corner.org">http://ekkes-corner.org</a><br>
twitter: @ekkescorner<br>
skype: ekkes-corner<br>
</font> <font size="1"> Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID:
DE189929490<br>
</font> </font> </p>
</div>
</body>
</html>
--------------080508050009050805040507--
ekke
independent software architect
blog: http://ekkes-corner.org
FUDForum. Page generated in 0.01751 seconds
