Home » Eclipse Projects » Rich Client Platform (RCP) » Can't launch RCP app from new Product Config(May need tutorial on making a product)
Can't launch RCP app from new Product Config [message #512637] Fri, 05 February 2010 12:42 Go to next message
Herb Miller is currently offline Herb Miller
I have an RCP app that launches and runs well from the Eclipse IDE. I am having trouble making it into a product, probably because I do not know the proper steps. The only instructions I have are from an old tutorial at:
http://www.eclipse.org/articles/Article-RCP-1/tutorial1.html
I follow the tutorial: New-> Other-> Plug-in Development-> Product Configuration
(Not sure this is correct???)
I get to the "synchronize" and "Launch an Eclipse application", but the test launch is unsuccessful.
If there is a better tutorial on making a product from RCP, please tell me where it is.
Here is a stack trace of the test launch:
Exception launching the Eclipse Platform:
java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 556)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Re: Can't launch RCP app from new Product Config [message #512655 is a reply to message #512637] Fri, 05 February 2010 14:40 Go to previous messageGo to next message
I found this article:
http://www.vogella.de/articles/RichClientPlatform/article.ht ml#product
I blindly followed the steps and it worked.
I can not explain why, but several times previously when I went to the Dependencies tab of the New Product Configuration, I would click on the "Add" button and nothing happened. The "Select a plugin" window would come up empty, and the buttons were disabled.
Is it possible that I did not wait long enough??
As far as I am concerned, this thread can end.
Re: Can't launch RCP app from new Product Config [message #512686 is a reply to message #512655] Fri, 05 February 2010 23:23 Go to previous message
Lars Vogel is currently offline Lars Vogel
Blindly following my tutorials is always a good advice. ;-) (Just
kidding...)
Cheers, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
Previous Topic:automatically add svn revision number on bundle export
Next Topic:Custom Multi-Workspace
Current Time: Fri May 24 01:02:33 EDT 2013
Powered by FUDForum. Page generated in 0.03663 seconds
