Home » Modeling » M2T (model-to-text transformation) » starting an Ant task from a Xpand workflow
starting an Ant task from a Xpand workflow [message #512407] Thu, 04 February 2010 18:26 Go to next message
Matthieu  is currently offline Matthieu
For my project I have a MWE workflow which generates my code. It also generates an Ant buildfile so I can then compile the generated Java code.
The question is: is their a way to start an Ant task (basically the default task) of the buildfile, so I generate the code, and it is automatically compiled into a jar file and I get my final application without having to start manually the compilation ?
Another question : is it possible to copy files from a directory to another using a task in the workflow (I have some files which does not depend on the model, and I juste have to copy it into the src-gen directory, is it possible to do that during the execution of the workflow ?).
Thanks !
Matthieu
Re: starting an Ant task from a Xpand workflow [message #512610 is a reply to message #512407] Fri, 05 February 2010 10:40 Go to previous message
Sven Efftinge is currently offline Sven Efftinge
Adding new tasks is only a matter of implementing IWorkflowComponent.
But given your sceario I'ld recommend to start the workflow from ant
instead. MWE is shipped with an ANT task.
Sven
Matthieu schrieb:
> Hello,
> workflow ?).
> Thanks !
> Matthieu
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Previous Topic:[Accelo]use of @code-explicit
Next Topic:[Xpand] Where to find OAW examples?
Current Time: Fri May 24 06:20:50 EDT 2013
Powered by FUDForum. Page generated in 0.01886 seconds
