Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » How to obtain a component of the screen.(To capture Texts, Buttons, Labels inside a Wizard/Shell using AGR)
How to obtain a component of the screen. [message #512306] Thu, 04 February 2010 11:08 Go to next message
Caio Bulgarelli is currently offline Caio Bulgarelli
During the MACRO, I need to call "hooks" in order to do some Java verifications (JUnit).
For example: If a Button is enabled or if the Text is correct...
I found out this diagram "Googling" on the Web:
http://www.developer.com/img/articles/2004/03/25/figure_01.gif
Figure 1. An SWT application from different perspectives.
OK, Now I need a help.
I need to get a String in TextBox inside a Shell.
http://i752.photobucket.com/albums/xx163/caiob3/shell1.jpg
I got success, but my code was a little confused. =/
Look:
A part of MACRO (XML):
<command descriptive="Android" type="item-expand" referenceId="21" value="true">
<item referenceId="22"/>
</command>
<command descriptive="Launch" type="item-select" referenceId="21">
<item referenceId="23"/>
</command>
<command type="verification" contextId=" shell/org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDia log " location="/PluginProject/src" resource="pluginproject.VerificationHookClass003" hook="checkSettings:Qorg.eclipse.swt.widgets.Shell;"/>
<command descriptive="OK" type="select" referenceId="25"/>
</shell>
A part of JUnit (JAVA):
public void checkSettings(org.eclipse.swt.widgets.Shell arg0)
throws Exception
Point p1 = new Point (130, 0); //The 1º TextBox
Point p2 = new Point (130, 24); // The 2º TextBox
Control[] c = arg0.getChildren(); //in oder to get all Components of Shell
//Call function to get the Text inside in the 1º TextBox
recursiveFunction(c, p1);
assertEquals(s, "-no-window");
System.out.println("" + s);
//Call function to get the Text inside in the 2º TextBox
recursiveFunction(c, p2);
assertEquals(s, "android.process.acore");
* This function collects all components inside a Wizard.
* @param c
* @param p
private void recursiveFunction(Control[] c, Point p) {
for (int k=0 ; k<c.length ; k++)
if( ( c[k]) instanceof Text && p.equals(c[k].getLocation())){
s = ((Text) c[k]).getText();
else if( ( c[k]) instanceof Composite )
recursiveFunction( ((Composite) c[k]).getChildren(), p );
The Result is:
http://i752.photobucket.com/albums/xx163/caiob3/result1.jpg
OK, I did... However, Can someone resolve in a better way? Without using "points"?
Thanks a lot!
Caio Bulgarelli
R&D - CM - MOTODEV
MOTOROLA BRAZIL
Re: How to obtain a component of the screen. [message #512528 is a reply to message #512306] Fri, 05 February 2010 06:25 Go to previous message
Paul Slauenwhite is currently offline Paul Slauenwhite
Unfortunately, there is no other cleaner way other than to iterate the
component hierarchy looking for the widget of interest.
We use a utility class in our AGR tests that may be of help:
http://dev.eclipse.org/viewcvs/index.cgi/test-results/platfo rm/org.eclipse.hyades.use.cases/src/org/eclipse/hyades/use/c ases/auto/common/VerifyHookUtil.java?root=TPTP_Project&v iew=log
Paul
"Caio Bulgarelli" <qbxt43@motorola.com> wrote in message
news:hkerd8$os2$1@build.eclipse.org...
> Look:
> value="true">
> </command>
> </command>
> </shell>
> throws Exception {
Previous Topic:How to use AGR to capture interactions in other environment.
Next Topic:Where is TPTP Manual Test in TPTP-4.6.1?
Current Time: Sat May 18 21:32:12 EDT 2013
Powered by FUDForum. Page generated in 0.01810 seconds
