| Re: How to debug java extensions? [message #511889 is a reply to message #511854] |
Wed, 03 February 2010 05:31   |
Sven Efftinge Messages: 1668 Registered: July 2009 |
There's a 'java debug' flag in the workflow launch configuration, which
you need to enable.
Sven
arco schrieb:
> I had to add quite a lot of java code to my Xpand project to manipulate
> the model before output generation and to facilitate processing while
> output generation. My problem is the debugging does not work for a
> workflow, therefore not for Xpand, and not for the java extensions called.
> Not even a stack trace shows useable information since it does not go
> below the level of Xpand declarations. So if e.g. my extension throws a
> NullPointerException in the third sub routine I get no information where
> it happened and how it got there.
> Is there a way to overcome this shortcoming?
> Best regards,
> Marco
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
| Re: How to debug java extensions? [message #512219 is a reply to message #512075] |
Thu, 04 February 2010 07:40  |
I consider it a bug, that exceptions thrown in Java extensions are not
logged properly (please file a bugzilla).
Is that what you're are missing?
Sven
Marco schrieb:
> Sven, thanks for the advice. Now my code can be traced in the debugger.
> But still there is no hint where an exception was thrown. The top line
> of the stack trace just names the extension without information what
> happened below.
> How can I best track down such problems?
> br
> m
| Re: How to debug java extensions? [message #512260 is a reply to message #512219] |
Thu, 04 February 2010 04:26  |
You'll have to call it by its qualified name.
<<EXPAND my::path::TemplateFile::plop FOR this.onePlop>>
Sven
> Sven
>> happened below.
>> br
>> m
| Re: How to debug java extensions? [message #512262 is a reply to message #512260] |
Sorry wrong thread :-)
> Sven
>> Sven
>>> line of the stack trace just names the extension without information
>>> what happened below.
>>> br
>>> m
FUDForum. Page generated in 0.01648 seconds
