Home » Modeling » Modeling (top-level project) » Appeal for review from modeling community to review EMF Build Manager Project Proposal
| Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #511284] |
Mon, 01 February 2010 00:34  |
Hasan Ceylan Messages: 198 Registered: July 2009 |
--nextPart9518732.qByx2aadVe
Content-Type: text/plain; charset="ISO-8859-1"
Content-Transfer-Encoding: 7Bit
Attached is the PDF version of the forementioned EMF Build Manager Project
Proposal.
I would like EMF developers and EMF (and subprojects) committers to review
the document and forward their thoughts.
I am also looking for mentors for the proposal.
Below is the extraction of "Background" of the project. Please remember to
review the attached PDF for full proposal draft.
BACKGROUND
EMF has been around for a long time. But the fact is that it lacked the
necessary IDE Build Manager integration ever since.
We think, the current code generation and validation toolset is below
eclipse UI quality standards and fell behind similar facility provisions
from the other projects.
For instance, given the current infrastructure, if a developer is working
with two ecore models that are dependent each other along with their
respective genmodel, when developer makes a change in the base model that
requires a change in the dependent ecore model, will need quite a lot of
clicks and at least 4 editor switches, 2 actions executions along with
several clicks to locate the action and run them.
Also during the generation process, the UI is blocked and having finished
the change on the base ecore, the developer cannot continue working on the
second ecore before the base model generation finishes. Further more there
is also need to switch to genmodels twice and initiate generation
delibarately.
In addition to this, if developer would like to validate the model in
between the unit of the works, that will require clicks to locate the
validation action, click to run the action and click to dismiss the
feedback.
It is also in our experience that the genmodel editors are kept open just
for triggering code genration. Furthermore, this not only clutters the
editor folder with unneeded editors, but also breaks the 'editor'
description for genmodel, as usualy once genmodels are set up, they very
seldom change, but needed to be open for code generation.
When used on large workspaces with more than a few model, problem becomes a
real burden.
This is where EBM steps in and delegates much of the work to background
build manager and prevents user distrubition with using the instruments like
auto build on resource save, Marker and Problem View instrumentation to
provide feedback.
Hasan Ceylan
hceylan@batoo.org
+90 (532) 713-5384
+90 (216) 332-5647
From Thomas Gray's poem, Ode on a Distant Prospect of Eton College (1742):
"Where ignorance is bliss, 'tis folly to be wise."
Content-Type: application/pdf; name="EBM_Proposal.pdf"
Content-Disposition: attachment; filename="EBM_Proposal.pdf"
JVBERi0xLjQKJcOkw7zDtsOfCjIgMCBvYmoKPDwvTGVuZ3RoIDMgMCBSL0Zp bHRlci9GbGF0ZURl
Y29kZT4+CnN0cmVhbQp4nKVaS6vryBHen1/hdcBOP6SWBMYgX/sEspvkQBZD VnlByAQym/n76e56
9svyneGAfSypH1X1VdVX1TIXe/rl438nczqb+G+wLn4uW/r8+R+nv/zu9N98 M/39/K+P+9fHHC7r
aTHmsp2+/n76/ac9uen09c8fr8bezvZq3M1fjb/99euPH8+vjx96o8Nk4/Q4 2q4wejKzCWa52flq
VrOZ3dzzfMF8y9+rmV9P6gxM6U7W0YZc2k8a7W9nD2tMJtzC1SywyO0c0uV7 /jXBCHg2rurSLRj/
MM906zN+WBOv5mesvdmrdfDl7RS/zHab4o/5dl7T4DwowNr5sfgV4kpr/Fzh Rh6W5myku8zGbgFl
9Ga9hJGQdklTf2Zh0pJxdpmbdhsXNXAhSQHPOethp3ZNSkkb29L16XZecNZd 78vmndmT7OZvP32Y
y3L6pdjyn/7wEfGUjPxT3KeNUMk//nP6c2O7yZuOXFe7377+PbZ1hJ+rFGHv SaqlVHmta8vil7ZB
baDV9jwTKi9qJgFBqcYmzUT9wHP6ge5CeH+Ba9ou9pu6Fn+iee5kG0CGgpJ1 endpC0eoCfNl6qrr
HdzYhwD0qaATBbV5ENxyrSLSvDAAZAtdEKnNHcNochEnLYwKcWfTw0bSkoCJ VpdnD9f2h+smUM5r
iOJUoDSoDPOwn4we13cqNcvhlqbl0tsV7seaKd7pbcgZDEQRXqZyAmfz9wYX d/rAPWvfWBms6AlZ
tozljYCpZimdrJkU0aN2BSDMektYy8/usIGbm8nV84W+u9/WKzsi7e+3SIuD VhU6QXAcnLMISGCi
BDLlE/wlz0dBYZTFfB9FJXybWDgvyTEq2AU0hmxC7Zfu7uz3aYctLuK/wTyU iWJkSvpFZe5sBEoz
74QUNCqEjzzTI67NCnPuFhYxtvdX52/WZE7woBxaYixu8ykTlEGT0dosK54I DKDUgJtgYOQEOepH
RBHYyhg8tKWNRmlNc2TLeY2ftS2b3GNR1J1z95m4SX6iSTSaaWT7EhST7GjO O9wG9bmZAZvXc4GV
2cuRr5OQm0KKRo1sV7fYPf25tVVLPUNXN3HY2dpQ50EKqDLsMJ46cxTjXehL 8SN6x0KwxDBwqJUw
lsm52YxkCm/L5F9kCLdtI2nQFzpcGCkJRk7AlE/ojD4c7N6RmEie8TGodRAw dIcI2e8ckR1oWl1U
SVVZEIOHeuJpPrnK2GM9sL2sKqZgm+jaqxIyuzOSXGblTZhMKCQnbUGQxaoD CwPiVszJVfBWbGtX
NcmuIzEHxbv4LYe3guzi87Z5AOfDbE4lgAtco7RBn2hqy/iYBm8uwsltwCZB ebqsohh0VFeNzDSZ
jpWOcBL5UwP8hp5EbCN/aHJ5FFzT4o0pAmYkVgenspcoc/Vm3H5b5yubdJfa xrpoj7mxOrLMuJOt
Sm2U+wxZzFMiQMWetythoZVSOEGUVaqavBMjrKYzlJIvkiaVj3qgRI9BJ8AQ M6mMN6QU7p5+uGgC
9y26VrlHIhWwI1hrJ7Ka5CJGYYoyPd0ZA87HGFOb7AhwdmpLsLsSGcRjNZCt hQ5TIMiCsc9YNmHl
+E+ZVOmBOfJTK58pIAUI4nlgpiLVp6ipfuPSHZLCbgO2epEdsoL8NjXFCkZX aM2gd7YmFFfDrkv0
2/zwkxzhfV+hVe7Z8zmY5eFbBBdzrzQ6Ow4sTGC+Z/zAIqZfOGu11QUJtL4i 2SqbM+gNEqIXFAlv
rIWjrMKPLa6q+z5NElCdDGbXQ+insrM11QH4/WraEgXVE5iV1mGLqSyItaAP V/gTLlsmz6HOGAZP
MOqEIECchoJkc8h5NsGTVCu5MDvkzMvPtMlcWSg0cEFaw8GyS2PKrVuHoAgC vte116A9FONJUQ2M
DDvPybCNnY4MG0Jbr9SYK4JIwTlA8SlqozF+o9CalozgpTsO7/qMMipj6pM/ mALpylOEQjoBcxdM
T2rPHDeWMrli2RVShVMlYsm4k1HMsA5Yk3uM7W2SvRvzHdl79rW1kRmKn60c 3FKfvXZD5cva62IA
dU8SsvI9nZkAMJ/Kco/Rk1VU6EUEzQpKOlf0b6XFVVtGAimVxbjgwvbY2T5t GtLSvmJeOfW4MhND
rHiHXHrvG+rhTd78p6pZck8vJ8Uy+VTd8O8ij2HQDEaTl1MLj6uIoVYq1yKt kjBEPOv9Uztdz7rU
FU1JDSTaMOvph5k6vNpeWMnMZOiIPobc1kRHjmi3li2VhnqdcFBSktMhgHdC vAVnUhnQRQyi0MQ6
NFMZ60j7F02cw1g3/BIBvrPy3ta7CtzS860BOy7oXgCFOOwrXhQ6Rjmyopnb 5gJw3gf1bhXPwawh
3c/iAVv03dsoKF5epKs6gB0Ebd1TPaBCRYBUU1I8UDFQ95yxupHehxjsV8Wg +syToFMNU6DhHvSr
qOrWuaE+bpMmsjoGKLvscqagkpDYrKwl+jWE6HlT3viQLooIG7QjsuW4kmfv NsfZqs/riIKR34qx
Fcq6B6u68a94UE1gVVXUJA7c89Ar546ZDnzSLXWuHLA+xV7FhBSxmpZFlzMw X8hG0pxBKGMV1Z/6
QKuxXHOYs7TBLulvQGnqQ6+GdnwfbSkYbcJVdZKQCYdCvupW5Fc0ykoVgTyy tZ0uS2O8I1vP66gp
Y+kcRJ+BHIUEv7bnrRsR9aOwXL6CsOYMwHyX0/aTwiAeKQq36lb0temakF04 c5fMlxUII5yIWFAn
aFRs0aHZo6hG+CUb7KZkUbwu6IR6ll3Lcu/EzkvEv0rO6ZikNc4RONz0dnLW qVm9/aO6tmx5Rw0M
4EuYb8B1xF+wta/C8VY3bjTZNBKB2Gygb0gJRZeh2xlJRxJNGcsUYQgML7Xx zOcRPXTH25tUqXUk
ZIB6lTmq5eKtoYFtNG1rryMDW9M2L4zme4sCZRhQRjjB6fkVvxcxk0pIZvIL 1axOrdkM44IcDd0V
VNtxy7LN7iDNhrrYYsRRvZuXV0ORSXAPuFsW9UxfYKgo1YhmviyEWpscGNFu Sx1xZ6nZJCCxpYZh
paj8344teQ/L0qQRt4PCeP1H9bYfkkHdxLcBTruI93CRJW+zBElHDFRrB049 LBgsRWlsR0HK4zOX
EYZzNY/lONzDV0HotLN4yaLTytMhQA48Ujjl9tyRquelfceq8+Jf700fVSjl zXTeDlWHC5jceu8H
aoqju4R5iG/qlaDV+qib2fc6ohfVtVClionQsbvjhuNcv6OKduiepUK7WckR yDZ8aIJnNy/cdemY
48hdJ98m1Yfgu9ieJod8BBPl7JZV/axWHsr69qy8OVXKpFe9ICRtEYKCKq4K SkxBcGVjFCfb4O9F
izuTvILCyak5GYK4hByMJ2BIU0DZkF+/FB+1xKrjv8vVx8J2ugqHdOOUGs3b s9aRed02PFZ/Q8WH
R8nl6aUE8XdJ+w+n/wPku/tbCmVuZHN0cmVhbQplbmRvYmoKCjMgMCBvYmoK MjU2OQplbmRvYmoK
CjUgMCBvYmoKPDwvTGVuZ3RoIDYgMCBSL0ZpbHRlci9GbGF0ZURlY29kZT4+ CnN0cmVhbQp4nLVZ
SYvzRhC9z6/QOWCnF7XUAiEYj+VDbgFDDiG3LJBDIN8lfz/VtfQqyXIgDHhs qbtVy6tXi9RVd/98
/N2p7qLg66ANfI5T+Pz2W/fTd91feDP8ffvj4/b8cMPVd6P2V9c9f+2+f+hO ++75+8+zVoudZvW1
XPSsNf1XXrnll+cPH+vz48etg4ZpvPZ0kOm0oYP8cjGzmpTX02Jm3S9w4Agf 6nO5DLPq1ah1+Dks
Fxt+fsIquBbWwa8bPPQRruCHNxpXreEko+1y8bBIr3iBT8CvXhtr92Qd+yDr OIislmSdlV6ef25t
AAMWG7aUIxm0EsGjGpcRfhqHSqLiZtAWtLqDAgoWki4sPO6a4N4jGIf2GLwK 38NJuEBUlMd4soOa
yLpkKr3Kw0uTGqfusJIExTNuqMCD3VEuvgWxzHRsSucEPydNmTZEU8IOUHIV qVCKOysdFDIgKWpG
kk2LBvvYaN+EC1agcQGbpdBvWi5TuDUc4JOdgL4iA/MdfNi07W86AewsPjHx OPypMlG9iMEgISjI
un2AiLAGvc8YKaUDjBx7zvZvei5tOBEEID5HLMjh50KFoDLJrwmzZB3GLp8g VxWcvhb46AXAq6zE
fUOwRW6byDJs6mhOvE6LLDiJLYf7yINftDKsACrBQ2y/uFlZ1OILlSaCmnYF X+ngh0Qt0GoQMD4t
uYmYTLC2S7NObfgAdh46zajrWDvNsoE4ELagY/bFCGzv+v461GnDLD2EwaLd HNhZF981eKHKKAPf
0cdPMrZBnVXohpQb6hAMtCbYYj8yS4DDzBCj2XxBnK4VJksEUW7Rei+wjVAU 8zAFcOVkAv8toYqw
wE6nhY0OjYjFTpXEXAvcGRfoEim1hKt1nMj5oE9Ajh5nfSPOzASVQCGFH0TH hN4+ktSLHOuUEYSc
o5dsQ3K0WbTuZwkkAShE2l4UvfS8cAeqFjIx0kZmTZUOwsxYuuZ0Yuy9fk// bEPSn12WWLUN3a3K
4CZ3zluBzJsyz7b6lHBP6T9E4jmp/9AylflcvBOhKbKGVExV2V0SawizoMoo CaaiNsr5eejEVJGZ
kCKAsADJuRe8cU7r6flcRW0VAKMQupWgOTSXnd40V9qQ6iibyAcsxhgRUgpe Bs1DysoJx8caKMvg
zKKZmqosY2OQHGXAVD0x0NLZezmoDehUOGRr7vvmxKxhB9vmJ6duHE4h9Rxu 701b6tyK5sSDPaZY
M0jVKKl+rcgybABj1R0OkrRBoYiqq3I0OzlZtKo7vVQou/gCfcxbZGTyDS9q PfKmJnYyhYumCCRc
jVQ0CNMW5BRrsgNaR6BtpDXCpSpLZ86uO7W9JDr9eWQzpd60Wdrwhs2wJVul jJAI4q7g/1Bb5y1L
Vn7kbRQFMJF/qmO30m8qmYuEwvTqWKAY7DVPmLjGPHSslE3Wbw2ctgKcRmGj g+i3I9Bi64rDMtl0
xoewr3wXC3ISsLBPrDyhV+BCTdWchiVlY6ktCtjwbNMK/jd7AJDN4K7TO0DO NuSZ2LpSe+qtYkvF
MFeQZorkzJXGILaR4QOsCgtiSSxEmbJMOI+vyr3NPPPKNLh1x6qU7FsnHJ/Z 78iXNXtGKpYznR10
dVtmfwVaF4Z7lZ9alGY9MHfSVmqSRDN3qQpkOhKZSZgAzBVTGRZRaM5bmMVI oTBmWM/oqA36E/Rr
rBblTqI2bThNv6gHBu8jk1vmLVV/HkqnHO2p+slGHcWc4/yMY3OewZ6wuoBY lkurzuXsWKgct74x
F2knbfuzCgtYbl3yCtF6vNq6qK2nqWW+jFXiEMaEWbGYTHIEMz29NQo2+Ya8 NBw8WZJ9Lu1U06ts
d5K78VkGUlZEbzWDZb7ZGy+9yuh15UV167sMKdRXd1nVZFdmJ8N44CYsyWG3 QCNV9KOMkLiyH/GT
xkxAvydfXUwT+PWo2KeCKp+3YydoJETb9qbNNhxlRU4oB5TxaXFsCM8d2VhN HyQQ6asyRUTJSSxW
lSnv5e8OpL3tC8ZSpqq991hqi3Z24zSGZh2q8IQXScH1EyCgcdY+paBzvdsK 17wCyzr9xGzrEl+7
8AwkTx9cu5czs9hN23wqk/KpeIaYgadqJj0z2tuXMwUd42hM8qwED8GX0LPj YY/LU1ii9ZIGTDYY
CoTPg6BGH4JD8HUB2A03BjGmxfkjLyoNDmm8cuBF1W9tyJJ7yog8+dh98eF6 +9aj6Q1p29VZMEYa
7m/igH3JU6C1aNnTpOjo5VMdlvmEriGXTByf3o5uvRqz2bYIpVjI9nZEq0ab qnusMjLy4ZTjcRBD
LaX1NOeP5NUKijon3/zY/QvX+ZA6CmVuZHN0cmVhbQplbmRvYmoKCjYgMCBv YmoKMTczNQplbmRv
YmoKCjggMCBvYmoKPDwvTGVuZ3RoIDkgMCBSL0ZpbHRlci9GbGF0ZURlY29k ZT4+CnN0cmVhbQp4
nN1Zy6rkNhDd36/odaA7Kj0sCxpDd9u9yG7gQhYhuzwgi0Bmk99PvfTws+/A JYEwjNuWrVKpdOrU
ka65wOnvt79O5nQ2eNuBxWtMdP366+nH705/8kv69/X3t/v7W+gu/amLCa/v v5y+f8IJ8O63n67Q
D2e4msjXpxlNMA+6h8Qto+nk2fQmDD+///A2vb992TQe+kssxi0bN37ortjv bK9oBS+d/IzDub/C
DW/hbu4DWYcHPPI33XBOV3AD+4WuwPHArr8kGdjmgeFOliJ4suHNRCNZGpRv DY0sjTCcI86bnj1E
8eQ5nLsrPPM3+DU+cx+xl8hBhx0s8C9/9JQLfenNHa2wsTF/ig0WR+iwcw+T jG3UL3D4xstEsQ/3
wGdyDPuhMY8B65cveA59vol4m99DdY2a831vku3mTmtXL5PFD+bWJX7sOEgg 79xi9xfEwcVvrAgh
4f2P/SW0AZG7WELxCYzMiJ9mwaw+kss8n5QDOelKWQuGsUb+WzuPBdzQq52J WM6otV/7E7EQNntQ
Frg0BAJD0kgitgsWn4IrDrtONruvEegUkboYNwGrQInzwxfYfASZuYFs63ca tViTgZHZNZDCYGHQ
BkA/nAOaTl4M+b1JNpGHOAuGS0KE40uAPHDahU0wF/dN0RbYAGC3RbApXhIp /LeOTPExAyhpi861
y76rDY6JtUMXibB2/Ic+Ivet3dn3H5LZ7KFoIVcFLg4nBAIGWcGpTYRMAgti ybwnGcIJMGNCXI3U
kI0GwoyKAH4cNQZNyBi0fgj91RkOVk/MblMhp1l48X9mQfbgmQlUMazcW7iY snoXIAiN7psCzAAJ
KV7CklcEFXLRfNOZVU7VMBXOx2VIXJQ4aLdZypoe5y+JlFGUkaWkjh+ClpiG 1JrCs532dd3SLOM2
jWwkfmb3OVF6G3BtK/XUKqRB+ASIrOF4kPh2Y5lerWvvstaoeVOLeqVLniLx vs5ixPzuiImURbUs
w5x+NSSxrF4DBPMRssRvbK6UhXsIQzg0usBlPW0uVqNUvAFqcyShHiyhjq0e lTOJWuf+baHU0pVz
e95F9M3b7JvLEIAdCKDMtW2HMhknEWlUlFK7d4E1rRcV8Ky1SvH6sKGmNoaz b8udNRBwJrFNB4/y
web6WdVIX5GGFpeR8bm63DK8WnJecfpSc32wUpf0S4WmZKxbWQqaD2KJQ9Do D0mWfQ42mKXruO/n
qiyUTWttx4WjroO4JhKBWJZfhJoBNPOcAmNd46I5jOUtihKZKfglViM7A0RC etfnAiSB6umdQoPN
SuXlViL1UuXAdNfGziwrrcdnd1OSrDoNTPNGF561EVnnRnujpvsQ0WgQIDrP dnjaj6EH8cUT+eco
aKPMQAZkotoVJ5L7JuXSWXZnhCIn+ywY5edWSo+tG7B+sUu78Uq0uzqYDgf3 fVqVYYxtWGC+VKjM
L00Bts+cQ3MBVFNA9FFhrVlh1zTV7DCcXZi9WUpDI6ynElHNrGUFqOVCneDP HPafBMRt7SgUo+Wm
6IpSoFKb/LOv1PWQM14p114XBXseLarRWOGnQsVSapZbpt0c7zZW60U19jGs qvGcgqBhoBdA9SFk
foFmKxi4ArnPBKXr9nhp03MG38a+yhb84m5zoSN1aZot2NpkK9lnFUattKrs KVzP2qokS6O4VV3H
3Ka7w9WWvohA8kBV4IsdZTnKqGcWW+zcCpRW8FSBuHty4DeW5BXyrF3tn5oI v97J7slVEXoUJNzt
3oUMcqwa+XAMZec7rH/z4zZrhuR5YLQZTFcP2JiC6fcOXM3QuBzAHR+7uY0D Bzu5hxvdwwT3sBNd
3YSzxFa4uRFuyim1fqI0E31SFUujoRtu6nPp9OWsqG7rZqdXcN3St42wlbor FdfJISRo2ddqSjXW
Jq2AuSy6Z3mn1Xos77wZXKBpTO2WWRcVas7l3eY8edxMGyy2e693qKyL1qvx AsFu4wSgPaJ41prU
qslFfcuYLScfph5fkOLVrxrd2xxDyaer3fkxtm3dsvmyA0PJY5yhOmNN4GtH J5As0DDDaA/NpdBh
AyfVg5eDb5mNnD48kacMfUhLwCKOPQsch45nARFNz0zZLUtRzrelU6BL4mBE OX120k/8iNIRRzOM
F/aV9aC8lv6ANyQB4VF1IzDG7ipDyDzmOUpDsBZwLpY5kt+jJjwTP2K/cLWh tne74TZUENfxpmw6
AJatW+S6QL3E58GUKFJEzmZCaZHA4jaf6oiNHEWQH4kGvlutg35OpwZCndIr P9dNjmUPotUTLuw8
6hjapB0D19NjBHYpC4V9BDp7axEIWKNFNcgII1FEKg7xlBokTbr6Ok8B1DeB juIkqHuNLmFjDXKk
FFUzcehbX1oHRg1bngBoyMWz1lcbZXYzO3k5m8U/jnkwmd42Y24fHPOxjXn4 l2KOPnxK3KWUWTqx
Vw8dxMakQrgN7YQ8snBeJow5kRHNR2daMnfwfqxXrTO5UmzHfuTr8z+JPfzP Yw/msNpx7IEQKLEn
4WulKMgfTx2VtA8xB4sP5tM1Q+M3NAWE+qG38reFV946s+stfK63x3++RaAd 83inzLLnbfhcb4/l
NgQ4ZED21g2RDmw+1WN2NHs989g+jj12cMgb7DGgT623osDAIXtUseA1QqzL DgTckTcJVtB0MMSr
s9qZhqhDghqNuEPJVDWKnjBtQWvEWUNtNs5qXA6qkpOGDzV0FqUAzhf+kIPT IJtmdiaPoaOzbAPa
xrAZkYOwULiNhvly+geBRDdiCmVuZHN0cmVhbQplbmRvYmoKCjkgMCBvYmoK MjA3MQplbmRvYmoK
CjE2IDAgb2JqCjw8L0xlbmd0aCAxNyAwIFIvRmlsdGVyL0ZsYXRlRGVjb2Rl L0xlbmd0aDEgMTc4
MD4+CnN0cmVhbQp4nO2Uz28TRxTH38w6TqBVglNDcohg8qM0uaRxKFGQIlEU kQqwE5G4RqmQYLMd
20t2Zzf7A8W5JO6pUi89Q+ihUqUeWqlSD1w49MAlKje4RFUvvVccEEgcQvh6 PXYiiNR/oGN59vPe
+86bt/NjoyCWdJy2yCBhuaafZYzQfiFivdbdSKw0LGJ/oEtVnFp59sTzMuzH sG9Xpfn1P8uvzhLx
EdhTVTi+2bvRCfsm7JGqG63/Sbtp2FuwuxzPMrM0AeTfoku75rrfS3MN+3t0 Qpmu7Pr51yewf8N0
w74XRlm6sw/ps0a8UQgl5dGHwHRi/99WiFOdyKiny9hFrP65zGDm48HMYN2g vU1Obyhdfn2v3lHG
al1lO/y28Td1Y+mGPjl7/rOpc5N9p05mO9PsK3X9+o/KzRfy19jOfMFT2wsF 5efnqbnKbGB0bOja
9q2emZf0QVcy8ePSi9LhQpIKsM+op9kwrrO0t3lI8u5+8RRRne/SVXDzaDQU nHp0Dk6tPf+8PWaI
/dDOc7qdk+EUn9bMsQqjmg34P9WcAl/Q3IEzNKs5Df9Ck9H107JmRsdoTTOn DG1oNugEfddclUR/
X3ND/7tmTmfokWaDeumv5puhG6R/NUPPujVz6mN9mg3KsPGEDXQn2UXNjLpY UTPqYTc1G/QRcxNO
oRtgW5ob+bc1c+plP2k2oHmIlWGpY7Bn2FPNjLK8RzOnbj6s2YA/pzkFvqy5 g/r5suY0/Guj1piY
nJiYFkuxEgXbCrywFkbSDcUVZY0v+FIt1dwVz1mUldgxgwPHAZVkENqeErnx XO7Ae8lxRLHme5XA
9Ku2JeakGcWBDPN2pQlaINuRWc91kaYtmPOUFSFxKKJ2nrX4UIaiF0cyFOX/ 0okvw1g6TjKlbInK
dmhVJd75XsWxreqqtCOpWkNUorwUhxsSMRWrSmgGiM97gWsi0tbNxWoDU9ui aOusSJqXzWgxjiIp
IG+pWgHh2w8EXjdW9vsliVWpXBmsvlsNRLId+kK6UirITd+Xjn1n9VBNuEgW jeHjO4nrOUHToCWK
SeFZIBuxgDwKqYZ/RJJcPAVdQdyicVwqHz6FETVEVqB0aBGeCjI4ZGLsUYqj fCV4AuS2YTXmziF7
Dr+jtDiRSduv4JtyRHsLlrIv9QplbmRzdHJlYW0KZW5kb2JqCgoxNyAwIG9i ago4NjMKZW5kb2Jq
CgoxOCAwIG9iago8PC9UeXBlL0ZvbnREZXNjcmlwdG9yL0ZvbnROYW1lL0RB QUFBQStPcGVuU3lt
Ym9sCi9GbGFncyA0Ci9Gb250QkJveFstMTc5IC0zMTIgMTA4MiA5MTZdL0l0 YWxpY0FuZ2xlIDAK
L0FzY2VudCA3OTkKL0Rlc2NlbnQgLTIwMAovQ2FwSGVpZ2h0IDkxNgovU3Rl bVYgODAKL0ZvbnRG
aWxlMiAxNiAwIFI+PgplbmRvYmoKCjE5IDAgb2JqCjw8L0xlbmd0aCAyMjEv RmlsdGVyL0ZsYXRl
RGVjb2RlPj4Kc3RyZWFtCnicXZBBT8QgEIXv/Io57h42tJybJmbNJj3oGqs/ gMK0ktiBTOmh/94p
Vk08QPJ474M36Gv32FHI+oWj6zHDGMgzLnFlhzDgFEjVBnxw+VBld7NNSgvb b0vGuaMxNo3Sr+It
mTc4Pfg44FnpO3vkQBOc3q+96H5N6RNnpAyValvwOMo9TzY92xl1oS6dFzvk 7SLIX+BtSwim6Pq7
iosel2QdsqUJVVNVLTS3W6uQ/D/vIIbRfViWZC1JUxlTssfpTu1j/bQBtzJL kzJ7qbA/Hgh/vyfF
tFNlfQF+i215CmVuZHN0cmVhbQplbmRvYmoKCjIwIDAgb2JqCjw8L1R5cGUv Rm9udC9TdWJ0eXBl
L1RydWVUeXBlL0Jhc2VGb250L0RBQUFBQStPcGVuU3ltYm9sCi9GaXJzdENo YXIgMAovTGFzdENo
YXIgMQovV2lkdGhzWzUwMCAzNTUgXQovRm9udERlc2NyaXB0b3IgMTggMCBS Ci9Ub1VuaWNvZGUg
MTkgMCBSCj4+CmVuZG9iagoKMjEgMCBvYmoKPDwvTGVuZ3RoIDIyIDAgUi9G aWx0ZXIvRmxhdGVE
ZWNvZGUvTGVuZ3RoMSAyNjc0ND4+CnN0cmVhbQp4nNS8e3xU1bkwvJ619p6Z Pdc990wmk8wwM7nM
JJmQCxBCJhtIwuaiDBAQEkMmkESQWwgBRGuJAqKgR1pR8VKhHo5tlR4DUqu1 ren50FNfa6WnaGtt
K22x7Xk1Si317Stk+J61ZxLAtud83/v7/vkmmdnr8qxnrfWstZ7bWmsPDmzt JWYyRBhRVm/o7hfD
ToKfHxECjtXbBoOXZ95bhOGzhFBXX/9NG0pr3v2IEHaBEL140/odfT/b85dh QoyXCFkkrOnt7vna
CVeckBs5jilrMGFvZoce49MwHlmzYfCWP3t/iOVvRAAQ1m9a3f3qPbGbCOlM Y/7uDd239L+i+56A
8XMYD27s3tAbn2z4MiErMU3/q/5NWwZ7SOQyIb1afv9Ab/9f2h82ENKH+XQQ 0wD/+MeMQR2PUyaI
Or1BMprMFqtNtjucLrfHm+fL9xcECouCoUnhSLS4pLQsFi+vqExUTa6uqa2b MnVa/fSGGY3JJoX8
//0j3kfcRBUbiY30a7/XfNgx4uPPyx9e+5tZcPmz/y9bYcg+DpGnyElyH3mH dOYyWkmKrCVbMeXq
zw/ITzCVf1KknTxN9v0DtMfIC5ifhUuT+8kj/wAuRR4mz5F/v6aWFNlAbsO2 fIu8A5PJazhVNpFP
wEDuIK8g1k8w7bq/h4pa8adPC/ZdlfoueYzuJ/Mon5eP8ByaoDI5RR6HlYh5 EPt530SPZ/wN0r3k
dvxdQtaQbRjWPmLjpV8Q6fKfsVe3k3nkTjKTrL+qxHfhMDPi+LWRw0jTH2hp ifFMvcpups9TOvYA
Rr5EbsJvN2Df6X1sJmkW7UrLiuVL25YsXpRaeP11C+bPm6vOaW1pnj1rptKU bJzRML1+2tQpdZOr
EpUV5aUlxdFIeFKoKM9ll21Wi8koGfQ6UWAUSHlLuDUdHC5ODwvFYVWt4PFw NyZ0X5WQHg5iUuu1
MMPBtAYWvBZSQci+z0EqWUhlAhLk4Awyo6I82BIODr/RHA6+AO2LlmP4vubw iuDwqBa+TgsLxVrE
gpFQCEsEW/LWNAeHIR1sGW7dtmZfS7oZ8R03GWeHZ/caK8rJcaMJgyYMDZeG +49DaRK0AC1tmX6c
EoOFVzvMoi3dPcOpRctbmv2h0IqK8rnD1nCzlkVmayiHdbOH9RrK4FredLI/ eLx8ZN+9L8hkVTpu
7gn3dN+4fJh1Y9l9rGXfvr3D9vhwWbh5uOzWc3nY897h8nBzy3CcY52/eKKe +VeqhGExKoeD+/5C
sDvh0Q+vTenOpeii8l8ID7Yiefftaw0HW/el93W/cHloVTgoh/cdN5v39bcg hUlqOZZ64fJ39vuH
W+9dMSyn18D0XGdbF88fdi7qWD5Mo63BNd2Ygv9N4dA0f8i+Yhwm9Y+yCRIC yYE0DYV4x/e/oJBV
GBkeWrQ8Gw+SVf4TREnEVwzTNM8ZGc9xL+U5Q+M5E8XTYRzN+UuW7xsWonN7 wi1I4/3dw0OrcD7d
zIciLA9bP/WHwvsc9mB9YoUGG8RWze1ZGxwWi5EsWOrqAjhTeJF9shaxfpp9 jPqxgmK7I1gfRjQc
T0u4JZ3737YmDxEEK8qH1Xh26NuWDyvNGFC6c2PUcrwqgSW60zhEa5u14RtO hPuHXeFZE+PJm9Wy
dslyrUiu2LBr9jBJr86VGk60NPOagy370s3ZJnBc4UXLXyQ1l88erw36n6sh tWRFMwf2zMZ5Vdyy
b3lP33BR2t+DK60vuNwfGlZW4ACvCC/vXcEnGlKo7CxWF9JqHKaz25bPXxKe v6h9+bRcQ7IZHJ0Q
bfkcmvByfxYNTrlhQ9QQXE79bAUCypgQbMVAeNYM/B3WRw34lZHgWiqfqrNm BJeDn4xDYzOGy4It
vc05OB6/BqnIp9NsdRybjkcRz2zVH1oRyn4qyilmB3MVYwkDJ6o6nsWiyAkw jSIaLYnTMo/P+eDy
cG94RXhNcFhJLed94+TRqJwjhkbz3Fi1XRO7ilhIJhLC7PEIJ+Zwa9x/NXGH 52jxiaj6uey549nB
fYbw/CX7OPJwDiHBls8dJnwKK9Psfm318/Ucbu3GRYwrWlvP+44rCl/La/iy 3Ree27MvvGT5DA0a
Ocjt/lt5XQ4yH+a3zaooR2Y263gY7l50XIG7l7Qvf1FGderutuUnKNDZ6Vkr jkcwb/mLQUIULZXy
VJ7II0Ee4ZgWY8SgwftfVAgZ0nIFLUGLr34BiJZmGE8DsvoFmk2Tx9MopgnZ NEVL4x8cpbw1SGPk
3y3BHj4+X1ixZl96BZ/jxIMUwX8YhnASqRNOHgeqMw8bw72zhk3hWTy9iac3 ZdN1PF2PMwM8UFF+
6z65JfyXvApNbJNm/OkRl6L2qyeVx4EkZpzQC4bR6uM68ZczTjCKQXKc8WSR J5/Q66RLM04AT6+x
h+zRkD3UTIOZCBzKrBGXfvZMs/AG4VpoAyHC7ahvhciQskQMuANUNLgNWw2s S7dJt1PHHDqHzlsU
VsKpcH/4SPhsWLR521NwFig02cFu96RtVS5wuWw2wZsOFRZCV8hhTQtED3o9 7RIYaRqtSXTKo/wh
j9rrE1qsOtEJic7R6k75x/Z6ZFmdk6s6O5vAXlIXsodLKlkc7KGpNRjEZlcn aRPUsFDDsWPso1nB
YMfKNu+7cHORohRlHgJDcuPyJlv9LOfFn9T5hSfy6zIvvyPoGIxdOJLpeXLs Vwwjf808gX1lpOHy
Z8In2FczCWC/R5X8RynsNz5mpI/KcKt/n/9RP7vVts/2qI2VvHD5rKIaTKow BR6tBLESDJV60lGm
WO1qWVmN3tUeDA4HabDMApYOUiPXVNUoNama4RqduaaxqvFAI+3HnyONw42n G8XGFy6PKGq6R000
ftxIbY1QRxqDCJVuHGkUp8uNqUZKEPp8I1Mw3I/FTjeebdRVOtJHOBXDvvQ0 R6hLlw6zYFehAwna
NIr/SMrNo/XQuXlgZefKzs3xzQPyr1d2jnZysmJefNRRv7KT0zXeyT9QW0mR qjVITWc26PEWAo9C
3VRO9+pC6nZZqb6Q8Ud4UnGYfT98/Rfa33y389Y5gd6KrofWnq+sjq+pWXnn osilvGPHaO993x2o
KpvbN+OG+1bVNXzx1Xv7f72S/bVheUMgI5bM6Rk71do3OzT2I1ypELtuY+bf s+MTX7x1btOahXUW
qXbJQOsNX7qpXpebh7rf4NjkkW8oQcgz21WSZ7KrXgJALBZDntXbXuVQHCkH c+Tnc4K6nV51YT5s
Nt9h/pKZzTYvMa82M/MLl/+oTMFxM1PKbkwbhgzUcKflyxZqthRYqEVH7XlM 6rKaTYw5vMzQRcAG
RbhI3KBDwtbUrOy014x6qzGEv476zuwsTVRzGsblX2IYUxsTNTWcrvFQGOxe dyhLPwlCbn0uylaG
M+6TmanHjsFDcBJ+CUPHjo2dPSnccfFNf12WDJcEdqku/+IqLT6ZaGtxATxE 0zSBM7VbcVGxSoRm
cVDcLR4VT4riQRFE3u+8ZR3qkAiUiFA/Ip4XqSL2i0Mi45nPNSiqBmQKl6g7 RbQwX4Tv4oTBXsTj
fKJ04WzAifLjyVXOupB7AXXBQ488otXddvlD+lP2CqkjX1Ui86r3VdMvuO91 0+meeZ5bPfs8gljj
ronWsBn5C/K/kH9vvkBfuPxzxStZ1MI8yaxGFdmtRqPOVjI1OBWm8iZUFYbU hVO7pj47lVW0FphM
Bc4KMZYK1RY3F9Pi4pAsp8RaU7PpqIkFTWAyiR6kf6KTcwqNQzjq6yHBWUZn fLP8a2Qe8clV8Xgn
0eayNkEraUldjTaHp9TVVurqapO0ptrjdSP/gPAkndtVqKM/LWnbszLRcf10 S8XkolWzOntjzTd0
3NAcq1yypaX5zhmJWH57zaKlsZblNy5viYGhae38MpNNFv+wq6B00dLqmeWB wuIZ7bOVnuaw0/zG
Bm9eqrmyoawwWKZwtwBxIVN5H+3WUjL8IrFgn+MGWS1z1btongsk/u+eY5PB I8eOxIDE5NhI7GxM
qD8SOx+jMU4jV7xKTcRAjkEqBv2xodiBGOMZzxVNUjWAuNOjkqI5QxEgETkS jIxETkfORnSGSDRV
SorcciTlnOQuFEXfYqPMOa29pqkG52g1H3JkCqPVcT7eA3Ec+s3yL5E9VCNP QKYQ5yTUJ1kNX/W5
SVtbHJ6EiVdmNLQCMFqQuuGGyJT2mdGBzLrbFy0taEpOcezM9Gy/F6rZp9bS eKlFjhQ6C2fdPH/s
IV9FhY+uXLJCZzAJY04eE6kmwCi5/vKH7ATOLxMpIvcqM3YbDxqpaIT9hscM 1GiA/cJjApUE2E0P
UqqjYDCrKJJCwRCVQ1WhVOhsSOAxJcQaQpwwnpnz1MMh6A+BEkqHhkJHQkI6 BFqWNVqpelSdPSXJ
/hTzaPwSEqNZQqzk0//Xo5OrVnbmPuDizK6udgpOHj1yRk4EnDuUs0Z24u3f nvn5z3/59i9O5jf2
zJ2XnubxTEvPm9vTmA/vfnyZZP700aX/9efuR9ZOnbr2ke5Vj66rr1/3aHYt l2GnD2F/88i65wQj
aMslIdlUZxFsgp3AAKQ5xCpbg9YR62nrWavOYC3K78qnSj4sc/Y5qZPlUd4b GVcXpXmyLeWwSdaU
2Y39weHFRRKXX6vphM0DCT6sic5qHNVOwNl/7SB6cZDpofj0AkVp8Hw1M2v7 dnBI3lRnZ4S9ktlo
sDiMY7P4QLGgr2Krc3J5IZ/XyAsqhDuIj9yg1NNpBrsq6OBZP4z4ocm/0E+N 1jks5Uq7qMulJ0xm
QcYMTDCnJEWyqpLeZHPbFxFOeJyNP46PVvO5WJOV+52dA5x1ikhxe7gO5bq7 xh22uzy4iKe6rQyu
T3fddntv089+1lAVnVtkm9wwyzVwE32gouStt9rGds6cZdTNNLpsxiyNm5DG T4tPkhA8q1gknU9X
pmMGUxjGwpxyK/96Ud0fhlo0InrCbHf4TPhc+EJY6A+DC5PaMFHgP4Phk1qG zhT2h+mPzofhlAbK
tLI8nx0dL5uF50FRq8I4/JyqFXtci5oPPaY+FobB8O4w1RIm33Of+kwYeLHd YeYPgxCGC2F4KQwc
j5YUD1NMXMcBDoaZVupA7xp1/jjsM+GXwvRgGOLhDg7pClOe8nqY8TDvxmBY nH4xDCexjfRIGCJh
3uFBDZ1ODqOcCEMwXIXq21D4QHgYFbjzYQOa3xgdCQt5FkvBHEZCMq6toZBg CBWEUkVukp9iPpsj
hZISrFYJSJYlc9bSlB3Nai4UcSl1DfAPrqXN/JNlNPzDY3FtuWnLbhxES+Fr zxmum/o5hm2lAeBz
QZu5v3nyyfiirXNRcEyukIsLwuX5xs8+ez0j7GfLJ5fMuvmrG6aZDG/cZjQV zexpfbzt0qehiooQ
mdBny1CPyCe/Uea5LVFLnYW5zVFznZn53C3upW7K3F4vChwwmAoGC3YXHCxg 6QJoLmgroOcK4HQB
tGHyyYJTBYJSAJGC2gI6XAAFfFycyRaVFMgFwQLWIGC5owVMS2+YOl0dKQAO 54L2lO6sjuqaPODx
kLSrygc+X8LV5drkYi6XzpmWiBnMZn2XxEDXJTiyqzkn8RKd1yjHm7s2c3rG x4mLchv1E9Sgu1BL
4QrzVdrHtVozfP29sR8cvlpd3l/U2FhE28c+Hdc/xtXkn3A1GenmR/78K3YM NeNDygqvgoLMLM2Q
qNkwA1Uom26OzfSxibpMRUeKgBTJRSNFZ4uEelIULKoqUjAsKkXpov6i4SIh qAWGEHC4SEfmDPvg
ft9hHx3xnfZRnyb0UD3z6fNTUsCmY4ttLo8pZeVcTZteNXx+8R6PaoptTmhp 7BpllsYmtO5ix0us
jCsBdZqoqp+/dNot0/4JarZnPjIEUjcsj0xZ3hS+BQrBvGSFTaZ/8FVcetRX sUCeVOAonLV2Pu3z
ZeVSHH8c4gLixJ4/riwh80xoEDxjZB8YLxrpbiMYfXNMrriLznd1uB5zXXQJ PNbgesb1kusDl052
KfWNqqtIKHIV0foLRXAAtcmU1veRIuEABmgRl+cVVar2zPNrT0W2yKq4xCbk pwI2ly/lHefqoxDn
EruLLxj5l5q0GjuDSwcF1rjSk102hZRdkdO32QtLPZ6SQru9sMTjKS20G7+a 8R3ZA3HhvatTEeri
onFePy6jZNRfJLJXKRXnxAmYCEzvIOvIbeQxIvhJB3mJvE4EHnsGtVLTKdTU eDeaWlX+VAqmNagH
TMhjTLIpZTpiGjaNmHQHMHDexEy5fmuAZuyvLiURIqZYrq+Q7Wg8PoB6tTbW 2MnolU5t4n04Aq2t
V6kROF7zcJ7+Aducj63/glLXV7qtlB4ygGS4x0AfF+A+AcwCGBwkPMcbJ3GY g18lPhQfibNgPK0F
hLjW9Hil6lcXolLtTeW7nSkPKUkZ5TAhwUWazlAjv8bHQ9OdNd2BDwiqVhOa Q9QK4aA9x8MqWSPk
piVougNOU00LpT8t37Uis7Pm5ic31WypoxTgCWgezPw1UxRtTjfMuDka21iz Z2dreCr8ZutLu1rM
JhPqubYLeRWfveirgDfWHlhR4sXZa5Dexr6r2PfN7AckRqaQh5XQumLwe+Ne avUkPdQRNNnUgKPC
Qc0OsNgBBGDciA1IdhW1DUOBccoc3bShadA1DZRpgIHJc1wlnBJFRqtaUrIQ jfji4knxVEEBmVKz
yGjz4Hi5J6WIrClQfGEi6+FMCjibist8gQ5MkEQzMvkPjGuU48uzNik0QZ2m WOlsEK5LglNvRRuT
0wh+omxMVWzNZJy2GrVrenPntLzCKXOXdlXdZw1Ni1Wtik6aNnP/27salk0r uL95dTX7Qd701fPH
9vgqVtpKw3mx+TfNSHYkSzwGEB6ItVQX5Lu3vmF1ZwoF6qxMJYeL8nCOJ1BH /w3qYWHy/IvEgASJ
SbIqGMBg45qVTZ5jMn1goh5T9GgUhKgreip6LirUH41eiNKoZm6hih6PgisK I1Fc2lHojw5FD0RZ
NKema0AVXE3PnzOEi55y7hjEwGnkijpDUTAVtuXLpqKUNeD2EeJaLP5jRb3r WlU9rhEW/jstvbng
ura2qzX05Iw61NBv3rwZzCz9OeV8+ZKuK8p5lg8wsjzTyt7B5V5L5pAVcJ/i 3dECyyb3TaaTg6iH
q5OXT14z+e7JwmTeVQlTaB6y8Gqu0VpRTkRKMamEJ1n4hFtmsKkeXq5omsGi BksRQj9nUnWlLiyQ
pWp0kuILoLmIP5Oik6J5e1HDaK1T8gNqXd18FTnQSwQENKyoRDraOkDpgNoO CHZAB6/bsSKtDnXA
YAekO+Bkx6kOqiX7r2tTj3SA0AFNQsfujqMd7Cjmnek41yHw/Odmqqr2rGvM PuMJ7ak40UKdqIAG
O6py+Cpt+Wp9cm6gKg/ydOHqhBBjKTUwDddXkZpQ2RETqCbVNDuVismzU84C bX04NC9Wp/xGtTxq
99bzNYID2NnF9aB41vbOCvI414a4pwYHHZfRaKdWMo7ryeGtl0e5kat9CE4I iHPzRIfmSYke7dxQ
tcd9lRCYWsnqphaPiwPvVC/CMJweIb66svYLaKbxhEnD+v7t+bIlBU1MnQKe Qw/UbR+5d91DK2O+
imTEkYgVPPFEbfc/tRdMrymWfhXePylU1jonc9Ad9lm99avmte9aVpZ5bkOH O7FgytTrJns8VQvo
riefknS77IW7B2fe3t0QTi6uCjVMrc3X+WNTJ52Y987CHYvKdHqJbYofKN5y 6Tv1iiNRW+eLNMTy
wk3LaP3tO5s6ZxQWzuhsaupqKuK8PYX8rRXXahFyuEGl4h4XHHKCybnfST3+ Yj+V8nx5ZXmP5AmG
YrXIZCoqJ+WQHCo/Un6+nJXzgZ09T+VPxRurVKOg3o06GElFo7pgyifrFtk9 uZFKaDwdV9xm5Ok/
rk7IE+YgjBOO2yJZOk/hxA0AcBKGkJYguJsGOgtnzUrme2dev7xi61d7yn/8 8vxdq+ozD09bVOeD
L9vjKrzjmHvXTY2iwaibZvN7LMoXv7Pj009KVz6xbTE8nlh224IFty1LZPXV 6zOvwE7yU+IljSel
Q+RhzX0TQpNLJDLIaa416b4ifn2TtFO6X2JS2tnvHHIyJ8EJ1nlhFDoTnafi Y1xycoMemSuOt5Br
NewMzR1c0rHUVRgudDXXFdSW5E1u2LRyQd51gbapDp/T4YsWTKl3lzVy2ocy C9gw0j5EqsgBpXdt
YkeC6gKw237QTnV22G06aKIMlWYdGq6TVGu1Ug2keqia1mMgVd1ffaD6dPX5 ajEbYAurIe4RCuZk
LYvT3LIIFaQK/ZUppydWskiQZJJitnGlbzRnVXCG2KmJ2nEbPSdrnTlDNuej 5AuikAVA44GQFS16
u+YJOrQODNRdP2te8fJ7V9XUrvnK2prNNdzaPppRttOeSTNXNlRtKI711ey+ haEKONURcJuTt31r
25YXd7WaTOaiUIGUyUsk8tj1fQc6YnZ5zG6Q3tXGCefm9UifErJBKTHo79ZT g+VuCzVIAD6kScDp
LCkjZZBUyobKjpSdLjtfJpZp0jVWoXaVPVtGlwX6AjSg7jDeY6TGvJTLJpdM WsS9XprWy2ckcojc
jJxcRVZ2gtb96IQY1RQN+7ixNDFT2fX56uIVsVu/ubF29i3/smrRoeTUeHRt /czVLeHCBXesnjRn
doO33hlwGmcPvbh16MXt05zmzGdPufMTPY+ua/9S3zRRMutx/LndFNJ84yFy VLn9qP2knYpFsCf/
wXwq+vb4qMFI8ym1GvPMNpW0F4Rt4UR4U3hn+P6wmAg3hRdi5HD45fB7Yb0t 3IWRNzF4OaybxpMo
B96JuYItXITAOxH02bDOoLe2p5zgNKQtFruYdnV5mNXZZc8ZRdzDnV2pK7P6 YXZSxHOz4iqH9lV2
0PgMYe3hhUMrV61ZufO6YOb6t8ZeP3wMPrvvewNViU3f2ceGU4PzI2N7Ktpu zTyTmTVuEjWuO7Bk
8aHBVq5nXn4lswDu0eyCUihTfuwNonwj89YZb8PRU1BwtKFpUBCZs84FJhc4 XTFTzB+jmTOxczG6
LnZbbH+MRWLwTOzdGH0m9lLsYowdjIEpBj+Ox9bFaEw58S01pnztabWHp/pj 8Rh74gOEoqdiZ2LU
H5vPEXRw0NpYc4xyBHS3hmCDBjY/1qFV8lhMjCkdXWotz7stxqt6N/ZBTNdw JIYSjTsdg7Gq2HBs
JHY6pkvF0rF+jAhZ3yPq5rYYGLgZEk2V2kKpgM+Pln5W6c0a7l0D2Z2FlZpJ nzXj41kbPxvjgmzz
2I/O4MzFoSHxvzFScqu1rsbLbbesrXYPN0i8WcPEyw0UY3zhhlnlSjThD1U3 zLgPav7Gbvns3M0P
p8uNhn/fUPDFe9mIZrsB2Xv5d7CDvIVjVKL4yEPECMQoG88bWe5hMNoeE50k p2MN5Ljk1e2DHc5g
hS+/POh0BsvzfRVB542+8pDTGSr38Qhm8nqiuDZ+gGvDC39SLosW7lVgRkO+ gUo2H2RsvoW+Lt9O
3/2+l33v+S77DOezJu+bPtbvA5uvCPPZm5j1sY+hNXzYB0M+KPIlsBAjPvjx Jt+zWPJjn5Di0Alf
k49d9sFpH7zsgyM+aMLiO7mqBjsR6cuI9rJPTPtgoQ+qeAH4yscadMK3CeGe 9QkyL/kmIrzsEw74
jvjoTh+kOWSTj57l+MYbKwa18uuwvW9qVd3vgystzqZig7sQMe+PUOVTfFTZ W+QDbPZ7vBvDPtrF
Y1U+2oBtPjtehBPkfh+r4pGzvvM+lsWswQYRmiNHBCMaNfp9Qz5alO04Ik6Z h8zD5hGzYKZdKPJe
lt6UBMndTi1EAklysbSRuWkXyTGJ6hoUhJAY+1Gn/KNxj+64uyQ7X3Pxv02Z iHVO5K+8gmAg66jq
5Hwla7nYJ5wsXjc0vFWz60TUP1t4vNnvmLNy0/TJbyETedhs+Ak0ZF75iaAT 2cV1/rqsjG/PLKBr
0Gb1khYlr8QN1a5ZLnqLDW4xQa3YLNISEW0iTSNFU0xPPrnfAhaF69MOYsAl 2cQ9IqM/ildzn0/W
ZV0oeN2VFKexIwma39Rv8FbMWz//rld2KcquV+7avLvFCR+1fe3wg7s2x9vm fO1dKPje98D/i6fm
tM188Vefcn5/+ZK4Fee0TIrJLUrbVh9sRV3L6reus7JOtoHRejaXURPzMyr5 KUj4T8BKOogHvJ5S
ZIpNSikES6G/9Ejp2VKmb0+Fz4ZpONKlSxezcJc57ecjxLcqNdG2OccsRldq W705Qud4eCHLKqtC
ISpgVhD4Co1ntyWFo4sf+fmek4Wt8+ZHdn5rcOrYX78Glu/f1PZ0ZuzZ+r13 bi05duwY/frBn93b
fPE2ShnMf/DXrKz1iUvfPpr513agkOXs/Kzl5Q8FforQCn6lsN14s3GfkbWT mwldaug10KWsl1Gm
EzwClXAkzj6H9osu94QXLv/wObQVJW7dRDBghMVAYL5kdEmSkcJig2SYw6iL MTTvJQkKNUCHxa5K
EjOaiJ/ECZtEZBlH+NtqWkW9bg4PK/bSVvWsDCflU/IZmR1BdY+n1gUmqbIc lKtkJshwFDPpkAw0
LffL1MCIwchYyizaFAlEqVeif8FVAZRvntXgvG3i+5aQqO7s4rM4zu0N5OTc b4jWe2Mizv3we/Pk
+N74qdxjchV3OcX51iB+JAhzP4ZbL2kP9lRm77zM7Wl4/kFwgO5BuJHdfOlO disaj/6x7XQ/Pvn8
jhOi86FuNIO9pOwR6uBc3YU6Kta566J1TKiFc7UXaqlY666N1jJTCXxQcrGE vlzyZgktCaKFaCqF
D0ovltKXS98spaU8RSiGc8UXiqlY7C6OFjMhCue4OS5G3dFolJm88IH3ope+ 7H3TS70aBg984Lno
oS973vRQD0/BIfyhYjIWqqCz60I6JnNb9TRaoswOBmaIzCkrm5Y3R+d8yEmN zmRrcluSliXBlQRd
Ev56Lgn/kYSTyVNJ+mQSDibhziQMJmFVEto4gCdZjCWET5JwKnkmeS7JTiTh aBKmJJcl+xDRQ0kx
kgRPEoQkXEjC28nfJ+mpJDyUfD5JdydhWxJWJKE22ZykxUlwaGA//DRb3Zkk e0qr8K4kDCShJwmp
JMxKQiSJ0ioLipC/TcKZJLyahOQLl4cU77Mn1MXJVUnazJuAoFoLqZZ3+ejX 1CeTJ5L0apTLcviy
LTzE2/dpkh1N8gawh5Kwm4Ns0/AVJ6ckKU06khQ78vtsf+nzHORgkvL+bkuy 8Qo/5a06l6SvasR4
SCMXbz6iqeI1uZKRJFtzPgc1iNVRhafztjBE/24ShpMjSdqT3J08mmSpbCub k0wep+Rp3gB4JgkH
tEY2JNclaTCLmk7TsKaTR5IUx0jhQ4ldVDoOYqfOJS8khSE+eINanbVJ8Gs4 cZxHkkDlZCrZnxxK
DidFWxIMpGZO/zQg02BafWqGzZkXKasRp6VKPFPc3IRZbJFJdXVF1olTzV2E /Ec7LaB5CjdrG6xd
18qcia3G8dSrkrv+TsY1ReJaevzqzGsB/rZwLlc+g+yW69AoN7qQC5DOOHco bObf7P+1Mc3R5PH+
XXeT57/YJC64bnFbpGVrINje3VXMve47Mkvvnb80v6WlyW2/LzNr/9KlBY0N dY77Msu2bwdn1iVV
W+8oCbqucUytMBgtwpSZV+Kao8o34agCMgvlaEqTo9cpdQ2e+Z4OD2uQ58sd MmvxLvXSebZ2G2UW
oqAYJc5PUgagxCAbggbFIBgMVkKywpTzujFNnBIkP6B5WZcUuZ+kpK6QOtwu aoVZ89fPq/AanC27
N+95lYvUVzML2uKbdz14+GttX/z0Vy/ObJvz1C8y73/ve5lz735Nk/H08ofi 91G+uOBXiryOovZd
VqHeLN8qPypzV/gfFa/Vrs4XO0S6ShwQ7xTZk+IJ8d+0Yxunla0Ie5/4FZHe LN4q0uUisGIX+GgZ
nUtXUMFjLba2WpdZBZ3RYyw2Mo++WE/R5pSzcsgmu2w2GeWQ1WbNySELLBaY MN9scZktZlhsEk1z
dGaXTmcWBbPVwijYptjAxsWUEVult3lt1GB+4fILJwrm8odiss8dNMNSc6+Z YvzrygrL3Boz6Mwe
M5XMzGZjZqaTiSfiafa0eZjsAcEDJz0XPPSIB5o9g57dnoMeocoDEQ+0eXow ctQjoOJQ3+Y5h1BM
8QAd8sBpD3i426asXOVPJeEvUl/2QL9nyHPEw7o8EPSAiehkHdVZmJWYZKRA ymGwARXMNpGbzt4a
TeAlalAF7KzWlsv47slVm2bVdi/KvkRCc8F1xrVNSXtNTfY/KwbP7M27SiZe EY3ZBdbVmXXexXE1
ooQ0jQtJP9T4tZC4LPPK9X98f17mpU3w8uPv/a7tt289Cn1cVtL1Ywdz8nIP 7R17mN6Rk5m+TCv7
K86XSezuF4k/q2nk8xGxYMCTV5xHqQAGgc+OSpNdxeG2M4/HGygszI56oNAV CBR6YHFBoGCO1+Py
epGahgAUBjiSy5JdDQS8hRIpI7SMKIGQSiIrImsjOyJsfgR8kbJIfYSZIvDX DyIXI/SRyDcir0XY
/ggsiwDmR5Q//E/1gwi8GIFnIrAjck+EdkTWRWhj5LoI9UfiEfp25PeRTyPs GxF4LAL3ReC2CHD0
1BMBxPrDixEY5cVfi9Bnsjn3aBVLEfjfEUDM70Tg9XH823Jl45GGyPwI80Xg bcStNYreFtkfoRLP
PYQF3418EKGvReAkL/RQ5KkImxuBKRFwRSIRqsuVwzY9pOyJwGBkd4Qui/RF KI3AJxE4EzkXoc9H
Xo3Qe3gmpCLpCK2OzIrQ8eJrtPInIv8WoUcj8OUcir4ItEWgNQKOyKRIdYQJ EbjAq/p9hJ6MnIrQ
pzTQ3RFYHFkVGYiw2kgzp0NxhEa4FE61qOqrETgaORmh4yg5JNXginnjAeue 9ilvIWiV744cjByN
sIEITNRdjYPCWwCgIZWipapWeYQvnKWFITUVAQ0hNu10BGh/ZChyIDIcGYmI tsjCCDUEzVVmxczM
5gLiDXqp4k15015GvLKXSt7GAJgC4KgKjAQoCQQDVQE2N8AxT1Jmq2IAWgJL A72BPQEBPAEWJgWF
zJsK+mzyIrOuQHMZ8FVo96IGyrcsV/Jjc9zgrq5OdI6Lw/jmeNfflV/xzf9A fl1rmv2tPXclfeXn
JGH8KiH44/g/1n33GkZwjXPZqPk1JMj62nLeCn7sdHyda8rwQ5kvBWctWtOS XzJpkjsRKpoab22o
8uRnHk3DyYOZTx+AlbjiOxbde1MDFXXi62lvccvKepX1a6t/E31AW/l87XsJ ER9A28tFDilrmeyU
wzIzrLWCFfm2pd2gdxkMeitp1+sNNuKSXUGXwredPchBm1KetIfKnip8IBvl sSHPAc+w57xHb9lp
uN9wmJsIYDBYbC5m6NITKxPsxquOGtQ4vPWaiYA9rs5aZVnjIDFav1eOx+VT oNm94y61q60BPWt9
a+zBtzJlD9OpJ+EO2Pg0nHyAyhmFO9DgO/Rcfl1d/tiDdB1/kqzNRevFVsLI ghcx8kelxB9U0WLi
nsQY/Q79n/QzqpNoHqYSEWakxSMiVRgwtLiGv41qPDJ64szavwk+rTTn3+a4 Nww1PT3ws1UusV3b
Eyb8bBnqBTKJkfsV2RRGAtjybNTKCp2FtJAr/9O5+07VB71BKgfLlXIg5UPl tF4uP1BOlfI0Rg6U
D5ePlJ8t1we16Ei5kG+a814MNGeZE5lyzJqKevKNRnFRQLanXETbTdB0QM0+ rx53XKPWxV1h3H/L
vbi5/Zecf1rbJdbO3mFsYjunhGaiLd0NeVOnVDti62v2fWFs/z2QAKRExR3X j7xRu/5fNletTrcX
w/m+/cuigmQ2jHkNhp8LlXkVmWHn5Lq6vHD8Pz/c/vJdqsnhs2lzrIQQgd+p 88ENirxL/4CeLrR1
2ehC0kWoA/WR5ySLauei4hEMWEpRDWgwzzd3mFmDab6pA+1+CXr0g/qDeqbo U3oq6Gv1tIcCzkmr
1WLT2bS5Oic3V/V6GZ7Vvax7U8d0OssmA3Clq8rAbHwq+hV/2k+P+IH4gxhO +Uf8Z/26Rtk/7Key
vwoT0v7T/vN+HcFgv/8Apo9ggt7PdYMVnar2vG5p9llXrz0VZ3yyaiPynLQb iFt2B93M4Na29R1u
1e1J+YjBIjN3ykaseoGZnG4dZPcbJlaANmrazmt1XDtzkfUwv8E1B863ahz1 9prsipCRT2icYpxj
xeNEs5VzayO7DXG1Trwc7lgFC7ZmLsDyvszOZZnMbT2Zndv3w2R4BQ77Kyq8 mY/GPvKiYgsP7s18
ctUBByCHMh/RNI6bHm5RivQCddFm2oYKDzVJMHZOgtMSnJROSfQI2v3aSd+P L6iyFJSqJKbFHX/8
QB2WRiTaI+2WDkpHJUHiAsP+q7OqILkkeka6INGRXOGy/3hbTUvQJkGVpEiU A0Qk9vpJ6Yx0TmJY
BUdB+3PQT3z7B+pj0jPSSxLbLUGDNF+iL0nvSh9I7CBCKF85gjXAY7dJ+3nS S9Lr0kWJDUoQlxok
+gwC0t0c7OYNHGztBQnmSx0cl1/iEB3SOiz4GJYy2CS4LAE9LD0rvSd9LAkp CTCpHtOw3Yp0WqLv
STAkgXAe+Hl8YH+hRPcXQhLaaY34qOacXqnpbZu1UDx7+Gw8EJ+QDpoBxBNy STj6aBU47ajR2UX3
Ifhh5mdQlvlIdzhR9pm9LMHHZx6Oj0Mbn6OKTZCIj8wlK4hgJvS85sIrNaNC LekkjzRFapWEi59K
gKP2dm7UnpRgUBuX3GCN/kl1YEc4DA7L2xqhh57/3R/UbdmgUvPr36iTOAQO HZLs9xKcwsGhT0nP
S5RjoqskqJWapTaJ8TqLcfQ0zL5XX1OPSvAQH0IYkADplpLSEqM897mXvq9q 2KPf/o7KyUyRmpzU
lEgHpCM4e4THRjid+Z6jVkLpufd+9TKnfj+mM43+fJaxhRIQHM3zErwsAS9L F0pdHI8s0S5pk/Sm
xLQKJKV1gZqShiTKhzLNJ+jVI/kXkcD4CGZ3AMcPDo6L/HhOqY+jGqEpEvGr pH6cj+JAdhSz2xLx
0dxY1kXtUWS583Acf4bj+VGiTPy4LPG/u7WxROGxCuWwiXxfmUraXWJEPCge FQVB3I0BZhH7LUOW
AxbWbGmz9FiYbAlaqGCBs5bzFnrScspyxsIsGnNK8aMPI8oNzXPVtIUX0orQ KgsIFpclYmENgqXW
0oxIBi27tYLnLNJpy1kLpRxplSVlSVuOWIYtIxbDkPY4bRFMui4U5mIXG3d1 g3ZCJDtx41nlJ/H5
Y1NuPTx/bOyPx47RvGOp8Y0tLo2zNupv9PdwvYO+qZzQ28BrhdsssNwCcQus ESGPgghgYCJajGZT
u05Ei1HMmpI3clPSbMkame1ZIxNgsWyTbySAohDuMoPeXGKeat5uFqQbbDfZ 6BRbq41y07LExozj
RiPxvOaBlzzwDQ885oF7PFDsWebZ5mFve37voSc9pzz0KS35Ng/0cdsRWj0g eXyeMg/7rWYjrn/n
1yo3J+ldaPpwA7MWbVA0jIB64BMPnPPA2x446uGo2A7PPR6KCMr4WcxirOYu z/MeUfLA0//p+d8e
6lH+5evq6553eejRr6hY5Vpe3zIPLfZMQUimGacHHsgap9G9+1WXB3Qe+NQD ZzzAsb3qYSs8MJ+n
erAIG9BKrNuUM2f71qoveuBOD6BJCz281DkP3e95zPOMh/VnLWOKprDLw3uh 1aaUz25V93uAa3Zo
99d6aP0FTq/XecyFdjRzoXXNO3fGI2oF6lxe1e+Je+Z7mI4p4VI1wZrYQsb8 DCyoSSnmPLUMnxaL
1SqjLd3lQKFsNmu8B4FzRoHLDJT/a6fnrXlqrbkZDX8Bp4OT+5Vrajrj2kGW 8UNLaHAnajTFPc5v
lozvnMTHlXJcn/H4xF5KXAOIZ88GX6O4xz+v58uvXjHVueXwOXX989Z510R5 tMqvcl3X5ESzKzOv
LnM081hdpnkrJa9AE6ytgBuh6ifwXeGjz/7MHr/UI1r48ri0kD15aSU7jmHN n335Q/FxXCdF5BEl
vgagTmqRaJ2hxUCnW+ZZqKEATKzoRkHn0lGzLiSEoKk21Byi/PbBc7GEqt1C mBaMqMEQCCFXiJ4P
AeWXFIZDI6GzIdHdbiWii9m6qJ3Nyb8hn+anDfw4sgGFmQkpHufXuHKe/FFN iGWPqmQ1y1ynsz3k
qmQ4GKmz52LZMwF1wt6T8NqxysHXHs38JfO/OC8oWbo3vfah7grhI62/7934 zbsW/+lXrFaLvbt4
b7q2duVdi/j5yswC9i57B+VajOxS2k22/bbHbKy3bGsZzWd8r9ukA0PEh/Iv pJ9Dr2jSqXLI6tFH
yoUrGrR6i/1uO11oB3tpCjyyKRIpWmT1UH1K9OeYGnefcs9pbo+I7/Ej4x4/ Zkk6oWbc8zhlqhW0
mxrZkxAwfgAie9CSVbSuyWy+Q9BV7Gl/5bu1a7+6vmZ7XSYentWdzJs2FdXq jTW7h9g7n32Hn+4A
sfiGWLjq4odbXryjxWzKRPu+1BnnajUd5SctuU1RSgg7KzYTI7GSOxTZPM0T UOt0LbqlOrZMB7oX
Lp9XHM58VZZTMk3J/fKwfF4WLNzRN9njVy2C4vKpgtFogI1WHaEyDVKFpmg/ PUKHqcFADaJ1K2FI
UL0O8tDEQXUzwddW9qoEBhKJeA2KQH6pYzOJgz1sD9UhLWrcOM1DLHZs7Gl6 /5bnM0+ImSC8DyWZ
d6BkDzt0aeB+Vj3Wyfccsf33iwvIJLJTWRotBNH3oI8azI4CxwzHAodwjw1i ArhcVNqUP2lSfoRE
lAhVIunIkcjZiJCdzlXYZEolb+h+BxCH7KAOh3nLXi94dTS0jbcaB7CTn13v tDu0E2+4jLPnqdCc
RBOI+1ZxFMtAc69qjmO+jTpu+Qj6ELv/0uu939jbOzu07a7ChikJR3jWggeW /fJX8dTgweM99MQD
Kx+8Y9vQwc4775ZsTuNRoA7ft7+2+N47br/r4Q7sowP7+Ad2jPjh+8qkba6H XFT07/HTm/NvzX80
n4n5oG0PaTtCW53g0PbzclaPBQNGyz4LlcxgkHI5Bp5TxXegeBHGf/xOorOK +ny9y0ksVtHsNvsx
5NRh2NrihD1OcPIxv7e4TJ0nwj4RmJiHYTcsxjLzzW6Umm6Up1hkjlV0Wa2i e14+5Oe7EK8FEYva
WUcjCQSU7h5VCLgCNBKoDTQHegK7A0cDpwJnAucCEk+PYCJPOomJ5wIXAsZ6 nlobGAwc1FL1tfhz
BjME7rh5LhBSNQdOrc2rpgJA5YASoM5V/D6Hnphlc9DMDGanO59ZUzqL3yUY vbKNiHpmTjGjmzRl
L0Fe8RXU1CQ2803F7EnGzQNx+Ufca+Cor+dfzOSm0hXeDPEuvrOwWd47MpL9 cgtqwo7KbjhyX208
ri3yrP5iylpS0tVOFz2wHRszy25/J3NH5l83QF3m/CZ4+vZvnb4DFq/P/HWW G20puC5zHJ8yHIIv
cVdL5hOQ8enOPM3XMSon4guiSmw4W/5TUXXIiqw22SY5wGEx62Ax0qJdr3Pp 9TocJsxIC6ILFUC/
DHIQVXlZFg7rQTOBa7AtepfLBedc4OI0rlqu8qdii1eqp13I4l2nXeddTMtD 7q898wuzMMWyU+1y
wRQBNUJr2mHjV6fBJM+XqUHWiYJZL9i6jMDvoGqngvlNVO0+CD8Yp1mcnV2a IJV/xJ3Rmj9r87Xy
UB4ZgU5ObO7AiWomaU2WoCyEGkAI3sjMOQSvfR/efXrstZN7xs7vhf2/h5/W cR3xrxcNmg9nV+Z2
Yc3YVi4Dl7EbwY8ykMHTLxKRKwYXL6tnxHPiBZH9m3YVdUiRPvlUXSb2iZTH nvvwY+3u6XN/+CB7
B9X42/fVHhGWZYG//cv3VCTxuzz8/Nu/ULPJI8/95K0stPn1N1XtMMSkLPxz I6dyaF56WR0U4e3c
9dcl33pRPSXCU+LzIj0owloRpoitIuW6O0X8/1yPcMpjT6ii8uAh9ffipyJd K+4QqST6xBfF10Sh
X1R23qkitnvER8RviGxbDq9xVS/H+3y29ueXtat9uRYuWpptiHX+QjUiAhUd IlWybWxo0rKenzJd
PZ3DY66qxfBZ8bzIqFa8KJIt7vMFVJv4rPiyyAzwSBXh7xOQKVDCSNMb2oUf tE/j/MoP/uZWR9ZW
5W6KzfH4hJsTF1acX66KZ+9X8dmhWbFo7dSw8LJXkvPExkwR9zNe/o04jGNo BUV5ao4JeoyDxt1G
1irArcI+gUr8hMcOdg+jvQxmc7/bYrPJfCNlLkqZySgtNraLggt5lGDEzEET PwPK+kwgmPjF3TaT
YDKJ5sMUdtB7KE1TtB+mUWrkZ0XkIrlLpja5SV4o75SflT+Wde/Jl2XssKKJ SqHhCP6OyCwoD8kH
ZEbk0/JZLkD5CYjnyhOq9pRd2lOxmayqcRPSV3TjVLNpF0sipdrFkudRKucu pSh2C6pPjKKtIXZZ
9UxgXHltyl7k5pwG5B93dlaP+3q0a9BZimruYXzWdGr+4bh87QbQZr47CsiJ rjoaIQ4/MPZ+zdh7
D9PCk/AQPIhUrsv/7M85bTLK3s2vw+F98vLv4AH2A34+jTz57dqy5rK2Mqad CrWgnk/K5DI640wZ
8JTn+U2abFAprKhSz5bBybJTZWfKWFUZzhEEDZaxI2XDZVQDcVhk1UUeKuw3 DhkPGNmwEYycKqFi
1ah5x1AFOcxPw4HB6HssLOeOwWUPwvGZNaCdTt+safUD2Utmf3s4zv75w3IP OIPlVw7LZZ/XxD9/
eI7+9EqulkHG75qLe1E3KSPvKZU7RNhhBJ3dYy+2t9qFaAGIfrc/6mdRD4he tzfqZRKTUF2x2cLt
RFtJ/ARqvDjeGu+Lb4sLn8bhP+IAI3HQLvYsn9mspuIgxCPx2nhzXKgX4pAN HoyfjJ+Kn4tfiBvk
ONBgXImn4/3xs3HR11FlUFAp44euDGWRLltxUfHhYlZcXOjqMsmySSjsYhoB +YV0zpezt9RG+fn+
rK+C73Fwr0NNgrupJwwTfkmIU1Amob97eDert4vC4GcHDl8+mYZuWHrnBzfP 9rf8YN3Wb39x9vV7
nu2e3L10lvMYfLyrtbj2hmcu/QukoTNYkDn71OS6mV8efeabf9g33eLKM8Ht +VOm5E/QV3gf6Rsn
axR3bwG4A9FAb4C586J5vXks6uV7SJoDmDuClRIMyHJxhVIB+R1VooJrjNNB dHcZCRdTRqG4uKiL
O+Kxd9mboNnOZ08qayK8U5wUqYS6WseUiHYZwfn5nvI3eFgZ0x3NXD5+Y+dx oE+13LqpJ6GbVdj6
Ypp3ddYXnhtIbu6+Lj86Uxdbf+tdrhv/9eITJ8HwzTbJ6jBm3v3XeEL50ug3 D/3mwXlyQdT1w8wr
Zq/DOHHnU9yPfM5PDihlBjcYXGCwgAE1O6OnvcMOtfZmO7VrWtWpAMsqWExT k6Y3ZtWkypKYehbV
pFSgP3AkcDogSL72FD2L6m9eWkJ+ZjKwLovIfB477XLxs4fVWTHNfycuFOT0 I/mXneNXFpGnjLtl
7KHcM2vN8KtiDceOUd8xup3bZ9xnM3bPsXF/zdifqI0/s++HoHVjr4+fJbzn 8ofsAo5tA3lfedJV
FCmqLWImJ8ShAWg+gLE2v5buTsBdleCurKukM2Mg5LnyqKHMCUYHmExWMPNj BNRWWFRI5cJCc/vk
RtII0842nuevITndSKsaFXyw0nY3VuiucivulFswuPtKoa0UdpXDtnJoK+8p p9Fy8JTDPTLMk2+V
qVkuLxXy9V1TAKY4w135pAiKivKFiavDCe2Cy4S9rymVCXn8YGBu3ZBO7XD3 +OlA/uOs8WaPB179
joerF5JuYhNl/8yws3nJjeUL+udGGld/cc8XVzfOGPzG+tUn5s8Mlw+l5q1r ndS4eueenasb67d8
c2vylpvbQ7D2W3nxkLNMXTVdXTmzonLasp2d1+9cUZVvz/zn0WAsOHV+fOay xvJEQ8eudOdD6+rN
rnxL9h4in3NLcM75SDH5Z+Vmo3Ofkx4VTgpUe4PBXfaH7HRNFB4tgDUFdxdQ fmiYGnx5sNjt8rny
2t0uFw+EbFVucLvz222lcikopf2lp0tRU2tPoYXpIulEaBOaYSFdUZrfF3aD ritPyKmITaMTfIjP
PH4RDwnNlfG9cZn8YK+IUgzF1zgfIp1/e0Zez7VD6epj9F9/feytw8fobH5O vmJBzxRY96XMy5m9
YCxetLP9meM3fvH6SXRBRhh3K1Z37l5y3Y4bG+WxP/rr6AK4PbV+VsHY/xWa sxHpw3n8Fu38fAlZ
r1y3Iro2SpeF+kJU51/m7/MzybvCu9bLjHowWkBkIKI6bOwgheAt5PcomoJl ShklHVUuxUVtriJX
AhVrsSvstHX5hJwow2V2xS1y1fscck6Q8Y03fkYWmRJkT/bgTAEK0VjfsTvv PHZTLHYTf/bFfnLD
UxeeeOTPT7e3P/3nRx755Ol2euTe3x654YYjv713/9mvtLV95ez+E0C/nkp9 PZM5cSJz8eklS54G
EddjBc6DJznvgS8ps9b5YaEflrpgngtSFqi1wFzdizra64dY/vT8efnsJR+8 lAfz3OB0Qcw53UlN
sl+mJpvfRmPW6Vaqnb45braoNWaImiFlgjpTi4mmjMB3giha7EANLrPbr89H ylrMbp0+X0TD0sIN
UwzrrbAYM9KiFfU2qx6nm9ndjsZrPuasc97mpE6ny+LXCfr8Ljf4+d4ZmN2B okBXgNoCTYGFgZ2B
ZwMfB3TvBS7zkwAKssPhgNCgBCAYGAocCDASSGsscgSZ5NmA3nxQf1RP9S9c vluJ2OzqEv6+IiKK
BWark+m7/DqXRWCyxAgammJXHnNca1naoSbB3wsRz21Fc53sRys1jcxbz/fg rjEq/4ExeUUrnviQ
cel7tT35ue06aHwqM+8g/DBz28O07GnwwNSn4NsHcbK/cWjsZ09njmjOc7qS KpwNZ1aBxpYzxrHl
WrpB48VT+Xst2THiJWcUp+B2uSNuZpL4fhazimhqc+maj5oa6sQOmocB7j+3 WOcAdQFQzX+7Wvao
Hg+1+O7Pno1X+B2B0z76Xjaa8vX7DvjEGVou/h/w8QP1Ak8ewsiIdrpev1DL NVjBaDwMABaaMkuS
2QbWFPF4CJrz3CdTrfHgau32rr0md4VDozk/IlWdiO+dOA/M1cGVXHZBzmeD hIPx93BNpcKvCqZO
LjYWJejzY5fA6W+sn2yrSfgqWEKULIa9n02+9JbebDe9kvnu+HtfxMXEQkKk +1tFssnGN3DPK42o
xC1z97mpXcbQdjNXAm/RwXYG1k0kTMJKmCrhtPbGMSFvk2I4YDhiYAbnFpM+ sEX0jXOAUa51jWbP
xWs6fnaJI1JHTbWD/c3rXOrWP7WZv9DlzC9f8DWsnjuva4rbPaVr3tzVDT56 9OuZS8c7oAfa4Dro
zvxz5tkDv31s0aLHfnvgwPuHly49/L425idxzPeIKjGSpBKTzSkzErvfPGw+ bxbIRkUWgaAGlRKP
oOElGkT9kFFHxC0s6yzLf0M7F5M/yv16URHnYdQu1kVr6BZwjCXAmfkT7K3N 7tq0dtf9WqtvO9KP
23DlZIcyeQ8FWxDVNZ0BWaabRRkzFBeX5m/aJt6FWlslqVQqqVKZrjxSebZS KO0PW/kUC2AB66Si
LSjMS7ZFdO4txn7bkI3abGCzGX0Tb13SLkZytfZtjaidPJ5970L2TnfuJg+7 Sh5r9+7C9pA7ZE8y
eL//2GBD/bbndqz8xgLTrApHzQylsHN7S75fvX1VQ3sgTb8+dsJRMbWFyRUr v9Tb9ejGGW4P5H/X
6LJJiWW3zL1+8PoS2UAfeSTTJhj04rhedwj77iRHlESefrmeTtWDAxbrDfp2 p8PldOidN2rnA806
N3KyJsUNQTcccZ918yMOP1TqDbLqMEg3pnAt8rfaUUZEA7N1OaidSdaut5yw ywmUX6mki5ww2wlR
Zx2ySL1ZexdYp7aD3DmaextYV/alHNXxibsMY9V7NWcXf6FSzh1/9QvBQNjF vfDdl17JvQmMnsh6
3y86hOcvPjrxIrCiifeWrNHuY5xVjKLerUfz3OBwcDdLVbpH1Tk8jmJHq2OZ o8+hu+CA3zvgjAP6
HNscTzmed7zqENscwPPp2w7QCtXPbFF5Nm12tDlotQMg6AAXd+RCvctR6+hx HHSccZxzXHDoMYn2
O4C/XK3fwRxcL46WqtozP6A9lQKnV6XtKfNZMzWDpcvGzF3GFD/cwdJGx5VX /GnayJU3WFw5Oant
+cT5e8fQNAJUhqunTHXWsByl6PY3wXD7E4XJmY6L76NSPEM05F9cY9WBN7Mz d4FDoxF+xcKn1a8p
XbYZfyFF2Xc1v/rlnn8ef5/w5Vcyrfp7xCcJf5EzzSViOX0o00JumHgnMXzu rcYz6YekWfgdaRCX
kQZ9gDTwovRpsoAFSJtAiAu/12O8jNYTFz6bhC2kAdP8GI/jtwzD89h9RMVn Ar/LMZxCHNdjOITh
6zk8rb/8CqbtxXqiiKNd/HcNB9FxHE+TWRinGPfh04s4Cc/DbwnmHcLvPP7V 30co5sd5ffgtxW87
fh2Y5oLNZFmu7JP4bMO+tGl1bCH38H5paf9OKrA9U4Vs207id7sG8zs+/5DH PAn98Al8Qqvo/2Bp
9nNhirBPPKir0h3Tx/S70UB+XKo0Dhg/NFWZRsxV5hcs+yzft/7aVmo7Il/v uNNx2vlH9+897Z5/
8uZ5L+Sd8j2dP8n/fEFtwQuBvMC+wseLpgXzg78I9U3yTPqnsBD+YWR55EfR /1F8Y/Gp4kslt5ac
L71TG5mZpJ0wktWyZZLgOxmCCanEtNwCWDYxfsrEWAJCKrkwJXqSyoUZ2oQ3 5MICwgzkwiIxkztz
YR2xkX/KhfXkVvKVXNiANPXmwhKxQjwXNmEb6ife3l4JS3NhC9kJu3JhK44p 9+yBIGFsiFbkwkCC
9Ju5MCVW+kYuzMgU+m4uLJAgs+fCIsljk3NhHSlkc3NhPbnAbsqFDTgPOnJh iRQIu3JhE5kmHM6F
zeRG4We5sIVkxJpc2EqW6SY3r71p7eDaW3t7gj3dg93BbwSrq6qmBmduWd27 sad3IDh700D/poHu
wbWbNlYGZ65fHxxYe9OawS3Bgd4tvQPbensqF6xd1ZvNDy7pHVjbt7j3pq3r uwcmEFQEPw/x+fiy
3oEtPDK5sqr6St7nQdduCXYHBwe6e3o3dA+sC27qCy7GNqvdg+XBuRtXV2KD blq7ZbB3ABPXbgwu
rVxSGUx1D/ZuHAx2b+wJtk0UXNjXt3Z1r5a4undgsBuBNw2uwYbevHVg7Zae tat5bVsq/x4Blgz2
busNXtc9ONi7ZdPGNYOD/dMTie3bt1d254BXI2zl6k0bEv9V3uCO/t6e3i1r b9qI/a5cM7hh/dIt
vbw/g2uwj1f1uG8TNn7Lpr7B7d0Dvbz/W7auurl39WBwcBPC9gbXYz82YtHu mwZ6ezfwnm7VWrx9
zdrVa4I7Nm0Ndq9e3ds/iBTh4P8Ic+V/1dj1E4W0lpJmspbchN9B/N5KekkP CeK3G+PdGPoGfqtJ
Ff5NxdBMsoWsRpiNCNGLiy9IZpNN+OzXfrs1HJswt1KDXY9/QUzn+Ndg3hYt 1otPXnabVlclWYD5
q7SUK+WDZImWspb0kcUYuolsRVzdmPK3LajA73+H47/LX6aFtkzkTMZ2VWG/ /165/w7rWq2fnHaD
Wg5v5wat7eswbROWC2p94nRWtZLlGJqLZVdrdBvQ+suxDGq4s5BrNdxLEWKJ BpXSSnI6DGq1bdSg
2v5OjQuxxj4sz6l2BXK1hpuPcRbzJgyvyVH0ZqT2gNaCHq3ceN+2YM3/T2fA Eq1127Q6r9PSB7WR
53lrtFg/mY7CIEG2a3+VCHMt5tU5vJVaaANC/p+WGyQ7MN6r5W/RZuPG3HhX ajg34Nxaqs3K8fHh
tMiO498f4z7tySm/RSsxiC3p1sZqfPy3IA1XISV7NfpxjJtyeDnM+tx4bMzV 2o1t4qX5uI2P6dar
aLxda89q/A1iXzZhHi+zWsPRr1G25yrs/2/bXPl/TNn1f6emKzTV5HVWjwsh ir/zOS6lvw96/uZH
7fdlEJQVcHYM3hyD4BjsvAipizD0yYFP6J/OlxU9e/7l83Thx10fP/sxq/oY bB+DgYzKo6nR9Gj/
6JFRndH24f9dwxW0NhFE4ZkdmwRUNrUYKpo8eygaB9ziIvTgIRSZqckh28aB JoFsFM9tYNpes5eE
XmqXgpHagNfcuiGXHmKz/0B/QNcGPHow/yDOrAgzj4/vfe8xxxl48+E76Dde /DVdhxs7Ej/ta4Ei
/MqJvCiIiL731qLUbRZhIq5JBtLh43AtbIVe+COchrMw5V35V8a3sQXmGMYG jMqj9og0B9gcwMBw
zpvnht/HZh/6Vp98OXsOZzwHn3tPYNqb9WJzz5e9u4vM/YTbpyenRqvrdf0u 8Tp+x7g4nBwa0snD
3i6FXf4MHtjLImkTkSDz2EDu9fvVp6zpFsBVonptDWo8D0v2PbGgDntLCU0C 8STYHjkhE5JMbTs5
2FJ76swcwyxD2SrH/mDvSiuqUbFV9IrkDcvDJl8HkwO3+Hd+w//whMvxV7XY BZswUmB5ixVYboU9
2nwoMvZ9kbZNYWAksI2EZc71u9I126Yetkb6k9cCvsT+8G2F0tJlcr5dClJO PcBHwWpFx8JWLUgc
BUjU6jtDjD9WO8fHaCNbCl5UdoJmtloKPihQ0MBTIJ0dZtBGVcr92CMJU6rg gYqIHiiqIf+RiP5P
IyqxlEhKTHUuhopBkmpaM7oGq8qGRDroLI1VGkm53PgLOobC1QplbmRzdHJl YW0KZW5kb2JqCgoy
MiAwIG9iagoxODU5MAplbmRvYmoKCjIzIDAgb2JqCjw8L1R5cGUvRm9udERl c2NyaXB0b3IvRm9u
dE5hbWUvQ0FBQUFBK0xpYmVyYXRpb25TZXJpZgovRmxhZ3MgNAovRm9udEJC b3hbLTE3NiAtMzAz
IDEwMDUgOTgxXS9JdGFsaWNBbmdsZSAwCi9Bc2NlbnQgODkxCi9EZXNjZW50 IC0yMTYKL0NhcEhl
aWdodCA5ODEKL1N0ZW1WIDgwCi9Gb250RmlsZTIgMjEgMCBSPj4KZW5kb2Jq CgoyNCAwIG9iago8
PC9MZW5ndGggNDk4L0ZpbHRlci9GbGF0ZURlY29kZT4+CnN0cmVhbQp4nF2U TY+bMBCG7/wKH7eH
FfgDsytFSFmykXLoh5rtDyDgpEgNIEIO+ff1O6/bSj0kemzG42cGDXlz2B3G Yc2/LVN3DKs6D2O/
hNt0X7qgTuEyjJk2qh+6Na3kv7u2c5bHs8fHbQ3Xw3ieNpss/x6f3dbloZ62 /XQKn7L869KHZRgv
6ulHc4zr432ef4VrGFdVZHWt+nCOeT6385f2GnI59Xzo4+NhfTzHI/8CPh5z UEbWmird1Ifb3HZh
acdLyDZFUavNfl9nYez/e+Ydj5zO3c92iaE6hhaFK+vIhmzAlrwDO2FTgEuy 7HvhyoIrYf8CfiHv
wa+MkZxbsgO/McaDG94lvGOM+Lwz5hW8JzeRdUFGHk1/r8H09+9g+vsKTH+P nDr5S57kj7p08kct
mv6l7NPfb8H0N5Kf/qU40N+gdk1/J/v0r1CXTv7om6G/QV2G/hU8Df0r2ad/ KZz6j34a+nv009Df
v4HpXwonf7mL/k7y0L+Uu5I/emLoX6GHhv4W/ob+Vu6if4UaLf0d4i39DXJa +peo19Lfom+W/k5i
6O/QZ0t/JzmTv+wnf9xrkz9qt8lf4ulfSX76W7wvm/zFLfmjRkt/h3fnkn8j A5ImAaOCWf4zgqq7
L0scPxl4mTtM3DCGv9+EeZpxSn6/AUFBAVQKZW5kc3RyZWFtCmVuZG9iagoK MjUgMCBvYmoKPDwv
VHlwZS9Gb250L1N1YnR5cGUvVHJ1ZVR5cGUvQmFzZUZvbnQvQ0FBQUFBK0xp YmVyYXRpb25TZXJp
ZgovRmlyc3RDaGFyIDAKL0xhc3RDaGFyIDY0Ci9XaWR0aHNbMzY1IDYxMCA2 NjYgODg5IDI1MCAz
MzMgMzg5IDUwMCA1MDAgMzMzIDI3NyAzMzMgNTU2IDUwMCAyNzcgMjc3CjUw MCA0NDMgNTAwIDUw
MCA0NDMgMjUwIDUwMCA0NDMgNTU2IDI3NyAyNTAgNjEwIDMzMyA3MjIgNTAw IDc3NwozMzMgNzIy
IDUwMCA3MjIgMjc3IDUwMCA1MDAgMzMzIDMzMyAzMzMgOTQzIDcyMiA1MDAg NTAwIDUwMCA1MDAK
NzIyIDE4MCA3MjIgMjc3IDcyMiA2NjYgNzIyIDU1NiA2NjYgNzIyIDcyMiA0 NDMgNTAwIDUwMCA1
MDAgNzIyCjYxMCBdCi9Gb250RGVzY3JpcHRvciAyMyAwIFIKL1RvVW5pY29k ZSAyNCAwIFIKPj4K
ZW5kb2JqCgoyNiAwIG9iago8PC9MZW5ndGggMjcgMCBSL0ZpbHRlci9GbGF0 ZURlY29kZS9MZW5n
dGgxIDE4NzY0Pj4Kc3RyZWFtCnic3Xt5fFvVmej5ztXVvu+LZUmWN0WWJVte 4sS2FMeLEiexvGI7
OJbjPSTenY0lKQSyESBAU7aWNFAKoRAFKA2FDkuhU1rawMC0M8NQ6JTXQofQ dqb08QqW33euZCcs
nbf83l/vJlf3O+s959u/71zPzcwPEyXZTzgSHdwxMHXTxEAbIeQVQkA/uHPO Ld+0tRDhdwihtSNT
ozsKw29+SIjITYiEH92+Z+TPw7nHCVFgn1B0bHhg6NvJj/yErB7DOSrGsOLt 1AkJlk9iOXdsx9xu
nm54CcsvYvmftk8ODqwuebmUkOp7sDyxY2D3lIXfzRFSo8Sye2Jgx/CvK5+a wHIRIVLb1OTsXO7D
xhQhDTHWPjUzPPV96UfXYBnfx72LdYD/2IXjQczKlBPxYolUJlcoVWqNVqc3 GE1mi9Vmd2Q5s11u
T443Ny+/oNC3wl8UKA6GSkrDZeXk/6OLP0ZM+FtDNGSSr+E3fLaV+w6xsefi B5f+pn6T2rD41/+X
q5AuAQ+QM+Q28s/kR5lyI4mTcXI11lx6PU9+jP12YVuc9JLTf3Pa75Bz2M6u OEmQa8mdf6PfT0kl
+SX2uZs8sVz3MrmS7CDH8M1xXEU3lEIj+Q/yGNlG/oW8hNDGdLfF35B7yBtU TVLpMmKSkBEBHCHP
0TeX57uDniTrKePBO7ElLtTVkTp4kNwD9+IbblrecfUX1nc1OYy/bWSM7CQH M++poxa+jcrJNThy
O1asIl2knoySKU7NMR5/CPbBUXwmybcys3SR4tSGFEqnJMZto09SunAb1h7H McfJACCG6TFuDetI
g4ta3NWLJLRIUqOpbngZfoHYayTvwQxiaIIcS91DtsFpXkdItKGnu7Ojva01 3rJp44bm9etiTY0N
9Wvr1kQjtTXVq1dVraysKC8JBYsDRYUF+Xm53hyPy2rUaTVqlUIuk0rEvIij QIoavI0JdzI/kRTl
e2OxACt7B7Bi4JKKRNKNVY2f7ZN0J4Ru7s/2jGLPkc/1jKZ7Rpd7gtZdTaoD Re4Grzv5s3qv+xz0
tnYjfKze2+NOXhDgjQIsyhcKKix4PDjC3WAdq3cnIeFuSDbuHDvSkKjH+c4q 5Gu9a4flgSJyVq5A
UIFQstA7dRYKa0EAaGHDqrOUSFXstUkur2FgKBlv7W6od3g8PYGidUm1t15o ImuFKZPitUmJMKV7
nC2dHHWfLXruyI3ntGRrwq8c8g4NXN6d5AZw7BGu4ciRg0mdP+nz1id9e9+1 4s6Hk0Xe+oakn83a
3Lb8nuaLr4Qkn6f1uo98RHA73gsffLZmIFMjztN+RBjYiOg9cqTR6248kjgy cG5x/1avW+s9clap
PDLVgBgm8W4cdW7x+0cdycYbe5LaxBisymy2sa05aWjd3J2keY3usQGswf8R r2elw6PrWeoT/1vN
BBGB6ECcejxs40fPRclWLCT3t3any26y1fEYiQb9PUmaYC3PLbWYOlnL/qWW 5eEJL1Kzub37SFKU
t27I24A4PjqQ3L8V+WkbI4VXm1T/xeHxHtHr3FXBHqGvG1e1bmjcneTzES04 6tIByClsyBGtUFD/
Jf244MAX5Ov07iovTsPmafA2JDL/d45ZcQJ3oCgZ86dJ39GdjNYjEB3I0Kjh bCiIIwYSSKLxeoF8
yaB3Kmn01i3Tky2rYby9WxiSGZY0rk2SxGBmVDLYUM/e7G44kqhPL4HN5W3t foqEF985W+Z2PB4m
ZaSnnnU2r0W+ym840j00knQlHEMoaSPubocnGe1BAvd4u4d7GKMhhnzv4Os8 whuTdG1Hd3O7t7m1
t3tlZiHpBjadKK/hc9N4ux3paZDlktI8qbubOrge7KjFCncjAt66avxNSvKk eGsR4UItY9W6anc3
OMhSb1xG0uduGK7P9GPlz0zKM3ZaG1uaTcyKOM/amMPT40lfgSKKze7Mi3GE lCE1ttTE5aEmwDqK
0whVDJdWxvPubu+wt8c75k5G491sbww9ApYzyBBwnqFVx2dKlyAL0UQ82LxU YMhMNvodlyI32SSU
l4uxzzWvW2p2H5F6m9uPsMm9mQkJrnxdkjAWjq7UOQTpZ/LsbRxAIUaJFuT5 yNlolMnyGBPbI951
Q0e87d3VQm/UIFc79rJ36UkzNHfUBYpQmdWd9cKh1rNRONTe2/2UFl2vQx3d j1GgaxN1PWdzsa37
KTfaCqGWslpWyQpuVmAztWFBKvR3PBUlZL/QKhIqhPLgOSBCnXSpDsjgOZqu 0y7VUawTpeuiQh27
kErWMcQx6u8G9xCjz1U9Y0cSPYzHiRkxgv8hCd5axI639ixQsTIp9w7XJRXe OlYfYfWRdL2Y1UuQ
M8AMgaK9R7QN3o+sAcFoovUldIjvRE9ZQorPAglWPyYR/fZC6Vkx/6/Vj3EU QXKWY9U8q35MIs7+
tPoxYPVhnUeX59F56qk7lQt3pMb4zr8+XC/6Gcl4rNzr6Jnlkr3RgsEcaMyB Ax6Y8cCgBzo9kO+G
EReI7EY7zRXDdTxM88CfWzwXzdesGxJBbm7WhMxggEnZPhmVyfIBDDoDNRiU sxYJ9e4EK4lcKI1c
CAf7IKjDX31VUHuhNFgS6vP3XXL5oLKWLy/L9+aoqQa8hloIl2ZTk1Etkni4 8k9fsU/+5JEbByvm
prJrqkoN0bpA/GtdA8cToeorTnz35zvo6dvabz548MTpsSu2yjQG+f1A9Tbf hm11iW+dOHr0lriA
v5bFD7jf8m3oj5aQtmhlbwj2BKE7CF1e2JUDCrVDTX1KEHFGjrJdTOxzgMMR LpyQRmXKmNQ9q5UE
ZnkbbidyAYL+C2wzF3AbSxeIqRq8OfnlZRWVFXq2frPJKJbUcuVlxZRtS6IG kzGbhktrKfdKdv+h
x6cfeFSpyk4cSk488ITqh1KVVGQONpWsn+iI2PQKU6A+tG6qM0LvfzD16dnN 599YfXPzA0Ae7f3x
66uObwn1d2/Mrt/eXNB617/dMvqNpui2Zt+mr/1KoOc6pGcuHyNyUhbNlpOJ 3WIQa3g4g2SLKtQx
XiyTSGQSnszSNG3CQX0VbqhvOtx3obQklMdLPJV5Br4yL0zNoJYvBOVgeT71 jhweLYs7yssdosaB
8l/hezbACZqgQeTHwqg1hAIxRTkahwRMAacBF6Db9RScAzlh+OrrC/aVhAzl HtMGaoQTdwquMiwu
IE2eQt6rJXdHcyrCjeGuMCcOmUO00A7bjHuNR4xcjwbKLaWTzlWTev25xeei dRp9rFUPbn1IH9Vz
BRa93lLA8Sed4IyqtDGnM8pH9bYYX26etVgCKlKgLaAFBe7ZgEQ1SxKICjGG HJHSYJ/2gsCVOmTI
C2z/SE9/n96C1hMX69de0F7QVWXIy+cU0wJD2JLNMeIhlwYhAoywF9mVS7Or WJLNIdNSGC4Z7m93
59Up9avqm7IHDnUVHj4wqz6+cduarLHJ7OqVAg/nrF3XXtp/21DZme81TLWs aL/1JaNcZ1aC/Rm1
zaT0te5tu2q/XNom44s3XbFmYjLD2TKtUuxr3r72q8/Y5aHmoZptJ7dXMP5u R1z+BXFZSGrIdHTD
6lBzaHOIu64IRop2FtHhAhDlGHNyc7hOC+ROasPuMIUwhMO8RuPSRDScRhOx +yZ4xux8xZzLVWya
VWq1SknxLBGYPoxyy3DFeL80I8l9FyWA4ai8rFaEbG+ReAuKQWD5JbwgRjKs n0EaCgO8dfmtIxWB
1rmbHuht/WqNr05ReHmo69j2ZpNzXXtPoG1/d3HV/NnUmZxV8eD6Kxo8A6Oe 2Pr1HqnUWLv7kcnr
Lvzkvtlat+l3N6LhuOvn87qcLP2KlunGsWdu6oQz/Td0FKydv6d3xw65zqKs mmdykYX4OYYRp4kc
jW4R60GmAZ8GNFpoM5qMTTqtUafTdpjAZNIpznDnOcpxloil37LPwr2he1dH n9b9VEfP6OBuHRCd
Vkd1Rl2LxKCJmuImajTlmspM3H4TzOEEWjOJhPv6pqcj4QthxvrsYhj7ma7K Fuw7aNX6D/pfhNI+
hjuoBURJQWU4Gxj7gJcrqPQY6Bmvc4VV+ncynTuc6ln3g2kZkON0pGprfl6R JCDNMbmvaF3YzO21
BRZy2d46F38DTeQfiYHYompyQiN3yYNyTq65mz+ZFj+kUx5SwZumEmVUgSaD O2CzF7kNBneR3RZw
Gy63FXkMBk+RjRWwUZBR0o76xMu9RMxkbdTJcdZFK+h1CmWTOqqKq6hK3aLV qEx6cRtBq/Dck4x9
eKJlIoZCVBoR3h6+UFpaylBQEoI0fzAW4LwG3CvyCH3DGFIU+fOLuts2uK94 4M6dUjC5Cnt6N3Mv
8dxf9uXWxAMLd3AjtsAb1b2rnIzXI0jLflxTPgmTPVHfXOmBUjpXcqCEVrlB YXPY/Daui45Q2kCh
XzeJxNKR2L4iKGIKJF+mihUVlb9aDgXS2CQqeb6loMAcjOdoW7T92kktp9Wq Ws1IQ6YeIhmeR9U4
LWgItF19SzwPxku0ekWlRc15l6UA8busIbj+tq//7qvAGUJtkd476pzuruGp VZ3XdKwojA3NX1cf
HW7MW/j6jvt3VNSsWj3Wvop+vGauLyKX5dtLLo/5awpWOFYFs0t6r23tue/Y bFvAVdmcOict39gf
Xhlr3nmbQKMdiBQlfww9g5ao3IXMIoM/yJiZfidaiNvlRT0iEElIzMUFuQjH /YFb5KiWc3MhjuNE
LWJCWqgpY9mQcdFhQGKhRZhGrrFIPIxM4Pq6NPXUha9Iwd9oC/Ax5pVQUrP4 79zj3IskG+mwI1pY
X9JRMlTCjRZAVwHk5cNcHsjdzHoCZJNY2CWq4eDrHHCMDE6s57hyX2xSuU9J lU5tbtygFRW3Scyk
hUsvBv2GCEO9gPjpcDjM7FPGb2DrqmQG96LaqaishcqKyrCkmGNYXzK2lZxp Wpr6jbPjrqaqrTFf
ftPQVbfG6ybDnIiT8nJlxdOGnDyfvePgltKswGq3py6y2o47vKe7x99xdVvX fcf3XFZiNqJpE4sk
8l0qvZIf/PoLiUhPld1SUOpA3NsWP6BvIy8GybloZK74QDGdCxwI0BE/KOwO u9/OXWk+aqYbzLDa
DAqTw+Q3ceuMsNoIIjBCLnCkSedrst6iO4lsyhATlalj1qjJGtNZdVaxO6q3 x9zukmfRdOl8XH7c
+a8eKPOAx+PUKuMcSHSSaclXJCKP5LjkmxJOIuGY9gn2TWuZyu7rY0obzRsT Pj9CwaDf38eM2yWe
C2NkMXouqIQs2ZBW0sWitJpYVuZiRKeIPvHcD3tvCvkCOnt/dSBenbO6e7R7 dWXfnrWxG2rzguqs
y8JtW1f3jvauBuPXjvtM/3Y4q0jvawiXNVaWrumtb95Wl21Sv7bd5mpuKamr LK/vZzx0ePE3VMo9
h7qrgORHzcYT2dnkxLPy8/K3UYPZ7vZqM1osrcfCwS9RZYbPq7YrP6/ajv2v dB39hy8qP7p4KLWB
ewFp6yWrUM/IxwPgL4Ir/WBGQn0XGdgaCzGSVSEYClXvWQWrcrVE3LRHCcpx BXQooFzRoKD5CpAo
LAqq8MVdZm15m0GrbNFoxIoWmSPtHQs/GUvBvLCMtvTjVhm3V6rRoUJ+j0Ba YS77xmzPlYJXIlr2
Mt8HkYiHopPSVJ10z5ujUpAZOu8VOD+vETm/zRgMrpDr/YEifdXWeI3P5Che 7bZH1q7NpkqXJ0uW
sgaDVtHrtsAdXZsvCgAnlk6oDQpRsG37nv3VjPmNuWF3Oi6pQV38Q8SRBrG0 PVp8IAcqcuAGD4id
Zic9aoUqKxy24CpsBrpTDbkq2CMGPw83UHDFpAx7NtRQUmneyTwgsUnTPhM1 KeJ2LRdndjRD9SVs
XBoy9BmM5ks8CsMl9GcOx4XxLQ37BlaPb62/JrHq71oPDpQ3H/3RVZkndBy8 uf34388fubnt+Msp
T8XIrZfP/+K+gaWnsK/axX8X8ahTXaSU3Bqtyui2roKRAoqqbWceGJlqUyig WwZNMpDJYxWSRgmV
iLtRVEvdalKjgq+rQMW2WIg9VaqySNmZsmfLzpeJVsQmzfvM1OyNO7XqYJvO LG9RmcQtUiLseIkd
Lkwva74w08jIGX19SxoQzUsEkB24LypCwfkSLZkl5B2xVML575JC/R+XNGH1 1saC/MbBq47HS1sV
3vXlFVvikSILKkDXyutquEeUgZJizZ+tgb8+JWjC4suuaem675Zdl4UwrLMX t2zbe22UMcG6OtR/
I4vvcU+iX1WAFkBvccu0MYW8SaOWHpbBbkQL274Vty+T+XJIkytugzHbbtsh G9dqA9u5xVejZrkq
JkPY1eLRaLg2o1nRojbJNCRyERG44emw4HUilLED/rw0+SsN4TQKlowv1jC0 qDlQhspWdLc2WieZ
S5H6vSO/vacvVNxc7uQlMlH3pBRsIyKpRPR8YGV+zaYCuvvTu2yB50viVS5r WctKZWEobIGUNbDw
tDlUnJ/2hZjfsQt53UdGo03ibHN2fjankDqkfinHmonbDGaz/6Qf9vtf9VNP bFIO8qy47ibrN6wf
WlNWEbGC1arTtvj6fZM+zufLb+WXHI20shaYnZG9L5z2M/I+61RYuCXfepm8 YtvGgZmajn0dKwKb
xnd/JZrftmGNOVCpdbZVNV03VOOs2BDsvH3NTZaVJTnhvv2bhh85tn19PsYS stRfH3XmxI//ZE/9
QK1z1Qq2gV60ZVtFX0GevyJaP2SZsxywcKqoTBfTeFweus/zBw+VxO2gsYPd nmUjTRqzxmg0hDTg
0YBUY9VQjSErbrNazTaNWMy1ytObi4RZ8FAqKDgEdWEslLL9hvummYYTKMn8 pwwXV1QavBEaloQl
Xg7jBGnA64/lmcJ7Nq6I+k1y8eCV0usPR/N+qf3lgFT+aCCAEpQbdoTWFjrX 59BAoOAf/7Fj4U1f
I5PhGdzUJxgTSYiDrI86NU6XM+jk7nWCdL1ej/6QSMO5OHovc4cEp0TLnBJV u0WETpFm2Q8RAn6B
A9H69F3iFH3B7uQyJ+lO5iTV6rILzeaCbJ0uu8BsLszWoU/BXFgIX1qJnZZj 9oeRrwrI6FPEggsx
Is5dtqackwQuI8BVkibcDcu65CnWcWgqKSXEh0Ima1LEkcdcLTkmjRSFR4vC o5GZMsJTetH7Rpbq
Rznq7+tLSw9k4rBlJ3xJb0qYNGFAS/+TSU9bo3VCcMjNl0iPVCrqvk6ael2Q HvpBYGVBbUvBwhFu
1BZ4riS+EsUnXqn0hcLmFFgDtFEQHyAlix/wTagnHNAUPW5kkThwMj8unoqg TSqTNvEiI8+LBGMJ
CiW0AVVgkKJUGJVKxQqcQPlnGTwtgznZARlNyKBdBvUyyJOBWQYiGfyRwhv0 XYpeP1xGIZ82Umql
IKFwVPm0knYo55S0Tgk+JciV+F6qVFIZx1vv1j6spVqt03lucX/UGFoVG3JC 3Am5zjJnvZPTOsHJ
2ELh9sUSTqDxTDnPkhV7mod7+TM8JTzwDjkQCkoZlYuIkW+RakQcYLwUKWUU COstVaiuGfP7p/un
/TN4+dPhoAXjwSDS5csuVPcsUtSS5w/yfu2L0LcUOOqA2QKmG3gvJ8SLYQOE HZ8LJLkDdVelXmh8
eET60XVQ3rz3pWxHOqDMKzbSKxa+KsSONbRn4T64vnrzclg51iHw43rGj2j7 isi+p4gOd2xHfmzi
oJuAzdCUdTIHLstBrsxpyqE5jCt1yJU5hhxKc3KKV8g4fxOw0CMLDTugrgQS x9iryGRryTLJ8trU
WpQscqmHL4QbX8KliDFI6/IvYdDyZQ6GSmRQd7dILpPRnHhvIvxFLl2yBN9i kUvKYFpZ5pcEWlbl
fAmrKtPmYOEgrtuC/l8ef4rYybXRlmYpKu8zymeV55VcXJlQTik5pTJLk3Vv Fl3Mgv6syax9WW9n
LWbx0SywW0gTT/OgHBqAA2qP8xaNLi4LqaPquPpV9TtqXs0YSZbtianVGK+h Ixhh1o157YKmZEYO
rf30jE5QlCxhavAytShkFplXnkk+oZL8wQO/PiU9rSz8wTcD9XZvicFZ6S3J c6icr6lfS23glSUF
dW+/ppC+OGNyrRlqvKeDwOJ7hIhe4GuIhzwQHT8sgiu5oxyVZGOU5tK63C7O 5eKfNMCDBjhsuNNA
DXo98LxXY7ao1ZZeChqjyxg0ckajOaFhuRC3jtPp3taARiOyWhKeRPZz2a9m c9nZ0O/RqxMiIgGJ
hPaLuLSlyyTe0AboqoLTaYhlh8MLpVcffJGxtzWIQXc4kzQJC2awIG3UvZXF nB84T2UY7aCH86D9
j0CY86jPvPagnPuwqk7s6t3SbnmzD7ZVR9dFaerEAEhrJ3qi2uG6tk/+odwh +oa9PPXsP4vEHCz8
+WRq6NTCWxwWPk59Q+D7mcUL/DjaCx+ZjtqPeeBKjLUckG8eMdOdphtMdKsJ ykzgZcxdjKbCm5sr
wm2rVH7rZt7QL5/UnNe8reEIQ4VcFPXGvQkv5/U6+1Fjf9bKs5g23BdGtl92 atMZNH1FLqMv5y0X
zDwsh7Fsn2qOPn3zv9y+4aq3oPTJw2/0BNbUJhOHfvvtLYGtd1xRu3O0yxVb UxOc3X/IsOmmH+/9
IVT8YsZlTL35qD+44yepf0v2n5qvM+b4rS+nXtK5bRq0KKOok7+G+7Vg9HpV tKcrAB1FgJFrjxvG
XbDZBYeNEDDCUQNUGdYZ9hi4XE2Zpl7D3SCFXCkckIDg8vq51Vwzx/k2u0kI JyUlUyWg3KxBZcn3
54p0/VbDZxz5vs878sybTYcvGae1VgSX+Dws0hGdr9h6uOPyu67sq3WVJw62 X3731Vsi7oUfX/nz
29uLe697+NW9DCpoverhf+Giw/fPRWK7v/6dMxuHTs3UNu285+FHPv3rpmMv 7pp+4+l7pmo3HXtp
58DLT9+/t0mI8T5CWXgeZcFGcsnx6OVHPZCrK9PV6ziRyqiiV0qPSqnNCm3W XpPRiP/3m2DGBHFT
AuMUk2azy5U/lQ+5BLxe6JWIjTaS0OTC+dy3cxdzOWQPb0LSL+NMIE5YRXrC hBt1HksqsTRL1TLX
AyLGGmQsgsJ+0I8KvyQEAmK45cBvSf8ZsIYrSEc+KAzwTO/j8oXfy0+hCFDj /EMT5cHea9t/c5s8
9cpf8nqODZTdctPtw3RDSiQk75H/izt3r2+/bmu9ceE9Rznd0OvvuKp1z+6F HyL/16degn3kdWIi
eU/IyP1qltKLKtGl53m1+B7+Pt0pEvkzEjLMkntV6UBcUs4sj+C3CT7QvtyN u9o39xcEC+rLs0py
jStWb798vXWjs6MyK8vpX1FRZVoRZbn/Zwjh8xDvDvJMdI9aItaITQTE0GYE Y69GbNSIo5q4JqHB
8EUDKvOzDnjYAVUOKGTHMk7p/SqoUEEBxlcqp4qqHGajpt9EJGrUbg3s2yv4 LfkLocME1hLoVYPa
bXfGZGpYrwaiVlh1nFQMqn6RIkOS0khYX1XVN+2f7mOJW3TAdUJ1OiYPCzoY n0ICpe8gs8La557T
HnzuOaSSQSAQlw7QgaVvNWAA4UH/8Ifb5QuL8vvPpGZPyVPN8q/BO6/cJocL 8ltuhMgBOdwpv4P+
aaGfUQY+SfHsSbfQqL283J4ahTvZUzgnQX0tkSKurORsdNKiA7cypKQGJYiU cIhAh2YIPW+dTt9r
Edwm6FUpjSrlHhWMqRCGehWsVgFj51wVp1JJrWqLxc6MpUhkFOWKOBHXJ9XJ +q1qJVVwFj0n7Te9
roIDiFsgYoYhjD6nM2gSoi/UX6V9pWGGpWAYsWLLJLkPWoXMtpXp9vBSmtTj VVxMXhhYpJBhafqa
93c/SMpTK+VMe8M1P6ddcKs8ifDCO/JzPxB95ZPzSyz7KXCL5fZPtgrlkvTZ 0ccovH9FnChIc7R4
t/SQlO6WHJJQjQrofhVIxGJ+WAZdGIEqFKRXg16aQtyPYRrfz+nTWRfcxrSw 0D62kb7+aSHeWl6q
BmD6AenC+9Lk+QdQBUgfiy+thhEFyPTih/zdqDsDZF/U0eiGXHeZm46itXDA iH2n/QY7V2avtzOv
/Y/RCrUuRgK9BTmFQAq1hbSwUG5kJ1hUrw86N8sDhf0rVuRY+zWTxvPGt5ll 1Yhy+nlD+tylL33w
Upq2GowLg0tefBrtyzHisvGo/JzxqExvSPRs7d79hzcc+eVtG/e/AyVnv/LP w+G1XM3pK65+9zsj
VSM3X1axtavRGvk2yx4f6rIWONTNN/74mpeh4o0Jd1bqnQdKyodfTL399MQD E5U6h1sDA/aKCoaL
xT+hLH8XaWEg90THjfpcPaV6qJKAQuKQ+CWcBNr0Bn2vVGKUSiUGMd+3i0A7 GSR0DQuaTV3SESmV
yvo0ap5o+hNSGJJCXApSqudk6v5JA8QNUGaoN9CvGGCOlRLok0iURsaZaXll x5hhIXONWELU9KUl
FgO2g4LPvKRMBSygw3hRqYLo1qQcXpYn3x5Iuf7+IjcegJtFHzJSf6IXPfnJ XcuMaBBsxvuLn/IP
4n7VaDNGog1dFlitbFbSmzm4gruSoxGuhUOrCEJ0eZiCcckyMltxpfeoF21d jljS68npFydyOU+/
POFiTIlGkvkGTLL6Pm8pmYVEbS8kaEEPgjGgYiEF6AdhL6JfxG54duepV6oP xO783d2bUqtOffxg
1/TrqVefrTp0YL7gYVny1W/LON3VZ6fKPrmS47d+Fzj6s9iNr1z/ROrN12ZQ baS3mNE3Ij3uT0u2
RkMSqVR/VA17UYuqVMoDWohrE1parwUtAO1Voh7VcMp++R8lEJckJFQiOLYG cwydvoRcLzg+fiEf
nVYcurRnl9kiBjIg4Vj4b0A/Lk0TTvz6q7+4+kb35JquT4sEctBqXmr/ZEwt Bktq39IyEaGA/vmL
3IvESNaQO6Ij62qhaiUMB+eDtCMIpFhbTJ3sQHNUDV1qyFPBvBKK/LE1Jv5N MTwhhvvEsEd8WEzH
MBQtE4NXDJSItWIqFq9NVEBFhTbmqm4t8VRCZWWJQxHP15pIm92cydkKggmC zWakwpglHcgtnVOw
eC8tnoIAXjyU+EJKJ12+mH6vhFM5TfU11glrft4KR/zQYCWaTHAZG7oGQnUj DbmF60evOd6S09Xb
6XnQsG7qnpGKkcsaTPpAbu5s2/rRtXmyMVthqZVuE8vF3OV3/Gi8tCuSu9Jc W1VY0n3l+p5vHd/V
FZQoNNJP67bfmShSm2yKd6/xFvnXDVQIerUz1cjdhHG6jzwR3Sv2QZMe9KMA BYJlaSosMBYWFjio
n66mGEbD/6BwN32Y/jvlKC1UnxGfZ9jzZ2dlPVH4biE9Uwh3L6k8fZTGKTXS XFpGuf0U5ijQgoIV
nlZLrXOTc4vzV84PnbzTackqbMFwWsOi5wySBV8ZxTxzmIqli6epWL10oNon nKgaPJ8PheEifs1p
T5orKANy/N89rnRInFOSmls9Pj7bYC/wuA15Aa2tyt+6LmILfG+K+85CLpxY NbAcII+3LwwPnZyq
pryY/2nCUtqSCLRxvbZ0zMxPcy8hJx5+iqxZfOdJDJllCpCkI2FdzENymnxP euHbXjjhRXexXKqO
WRZ1IBz6+JBLdbq1ibUQXAurqsJlTRXlq4raItqKlpW6cpPXpG7RmYi9jddm uC+d4BGUHYsThdQo
woJtEDI+zDr4gYXN5i9GzSKW9/lMYSkJZObGPZvaOn0dAyIJC6BlqddHWQC9 ImBZuaqy2M0PPoAB
tZQvClpWrq4KsrKQHsrybOro9HUP0N8H46s9VwxrVoRKzSlqw6DaVMKC6kqr r6I66lx47gsVLC32
Ahs1Kch09eIH3NvCdwyrycFo3w3lMB+C+lBHiFaE4GgR7CmCbUVwRQEochw5 tNsC4clcdmaWm6vh
J+yTvn0+6vPV7Nfcgj4R+yREUzHndoVcUdeUa7+Ld7lI+sMGW/EskSx92ICR aJ+Q5BMMLCt+9rQB
lg9cLjkluyTlnAlfsI+QyawF2sk+bljRMnH43u6+b6wpqFPkjFd13zjaqHeu 6+gVPm6o3nkWNuas
ai1mHzdMbt10JCKR8BtWz5+Z3f/+T781H82yv3Wj0dVz98/ndd4sfaj76o2j j127PtXKvm2o2X5b
5zV7chxVO9NnMBsQZy8IZxUhciBqbAlCd/5YPvXngSzPlkd9ZsZl70RlyGWG WH8hFDKeq8RSYWEp
KdWWhkqjpfFSPiTr5oBzxwqgEprQpSU9LHfjApc3bjfL/J/L3GQSN+xUojR9 Oj59Yckn+ULaRpQW
waXzxXTqBkqul0LReg5dND6vta0tf9Xw+hX5jcPX3N6e19relvcdZ1tp++HB yr5Nrrq6NdlC7qbJ
GC4P6/PXhBwXj6dkRrfFb7VuufOlkakrTfml2QwnPCHcP/D1RE70ZCJaN6+7 XkebtMDptVqq6xcB
EYFIRIlUIpHJYIId2txMYQ+FKyh0U9DQFkopEc1LeZ0OtGIx+5KNRQnBtAO8 fFYXLNVVVaWTNDoW
IAgfdaBAodUIc2EJJ5xJg4f+R+WpyoXvGukfTp78ifm/82qJVLbwLXgNylKv QNlu7o5PZ66l99rr
3Xn5C4LPT9zsXA1tcBHZE9101Am7nbDaApdJoFGS/kqtoHDKm+vlJ+1e/KfK yytWRfWumMo1q0E+
oPeS8+RtskhE6GAV7MwVm2blGvV5NVWr5TYSyeRh0nFo+usnIbhhyla7ZL6W +Z4yvr/kAyjG7GIJ
7hED0VoOfr/tntFw09GfHRw8FcmvU2rD1WuyBw+251qrhzasnnQl5umDjoXH mg2+cJTTBrr2bpxO
7o3Y9GB/Rm7UyFYOHess62ss1ErpnXemOlDZ8OnvHdG2v4r6VI8Y+Fa0bVce HM4GOztzy1fALh5M
bhTufRzs4KCZ24zocMs1sYLDeZCXH1txCMnJR33wHz74tQ/u98FVPuAafV2+ ER9X6YMcH1AfS1w6
5OuID3y+YnXsFgws81t8DlncreVJm3XJziN6ZgTH28/su2Djp9HZZF5mqb8k RJidB8HWZwz98vGM
hymI/KXDAUtaAwPc542trbbuKRlc2Xrt5hLDirVQZKzvGig9fHzTbW9cn9PT 153z/h5p6q0Gif4K
ucGupQ+r1JvveGm89LJIrsbvyzr94PUfJEckSo30rx9bg3B1fqvAL7vRZ2tE fpGSdVE/GiQFAckI
B70crEOh5uQHMQQShwAvMW8VSXei94QXFWeYoSrCwnomz2nfWcgwA6MxeMED +rqVXK36058e5ZwL
PxARqNn4iVZ0P4oY8SOfvs+3EScpIQ3kaFQ1VDtXe6CWc7sx6HEyteNh56RW h5Wu14GGEbCedtAh
ymGAs2bCLJ3wepk6KlCoY2av2aslE/uYx9UUmNBGZZaYljcUzpaWZlfPOiTZ s6r0F5jCV3tVy99h
pr9sYN81pCUQieH3p7/PYT6AwMDsXKkYMp81wDIfp0ll+FyZe39FU19Z19bq K3/wlR8+c/L2aGfF
1MNzZx9a+FnfniaHpaxt9WW713ts5e2nW8YidsOKhpKW0WqrvnCtqD6+LxHR ZB8dmfzOfPV9Jx76
WVHWrs2Ju7ZV3fjJPIZYXaH4anfF4NHO8s5qN/1e1Za9a4qaSuzlm69sLGwo y0Y6vk9+Kjoluh7j
2oqoU66W8WoiO82JqZqLiiXqkGQ/utiEe0QmPiPkLn7W5yd2K/NEsSB82AE6 r85T7kEX22OiH7M/
sHlwFE7T+VQXnB6B06muEcHP+z0hYq+QfzkebR0WPGS1VqvX9cotZsUe5WEl VSoUZrNzygkyq006
LIYuFCqp1G7r3SM6LKIijqMWa0L+NobYMqpVSLl+Fc/ZzDrab0ShjZSmEwbs V88SvYK3guy1UCqE
ABezXqxSKFkvpJtKQt6lEJzzZJ7pgI2ddpuXAvLHL6e7Lk+H5ucfkC28J31s cOHw4APSpSB94U9U
I0RwQtqAli/81FGeyfedEeTEiZrV1GMft1Ox2Wymwq6smznO5WL8WG5bFduj O6yjOq1WI5XJJRJ5
r0aWiEghIm2R7pPeLBVJowZbTCrVaPslCT0n1/SrMqkFxp/+vhkkynJSGzfm F3J8aZUBpRXp9J3k
Cwk+Lx364fPHb719StvypnzhhXRiz7br9EQ4evgXJ+jY44/dfHDh+t5U3VJQ WtZ3XcvQQ3sbBF9g
MS+1gUqEnK6fnIgqhrg57gDHiSgE2K4qHAWxycC+AI0GwLo+J8dCYgajgWC0 Ld1puMFwwsANGyBg
AIcBVAbYZ1g00AkDGNhQj1wVMzjbC0TGFrNGHedvkkGtbJNsi+xXsg9lvEzG O5a/PMocmbLQfHpa
0Cra9OFpn5Dv5gXFeIkn9aWHqU5D5LKJNYEupyeoUeTYs0KFOerTh6UQrv78 2WrBtq8ligyKpycU
Wmv1aAv33N84ZxVo/2ekvZ3cHbUIqd3vWuGw9U7rQ1bOarGI5fKsLLbVDUh7 IwGDgeV0NTaXjdps
JGEkZq2Zms0aY9AYMfYbJ403G+81SljKZtHIGaO5BTGjUWxIyIgSlEqW9wVx v0i//AW8Ns0WXzzz
AIEz0oceiJ9L0hPCiYfXkznxgL+7fJkjRO6l047Ufw7CD1bXxGo42rvwlyWm WDrleI2dcggfJxDg
sx82t3/Ur6n+iLjSfxP5o1uH7lv6M0DknEaJlD+FtlfKkhUk/c0DkXhSDeSy 5b8WHEK5ufSqoB+Q
evQyAO8WvNfR02SDiCwuINzOpuGOkSx8dnJO0o5whFaRHdhWg2Ub9j2MfQ+x Mt61eI9k+vTiPcPm
47tICT7XY9ki+s3ie1ie4f+ejCL8Ec5bj89nxKcX36OnFz/G+mm+a/FP/N8v vi+aXXyPrYs7ttiJ
9esRrsYb10Z4vN0iIqx7N95+foS8j2N+L8xZtZjHnrj0InISjBCDbVRLT9KT 6NFWczeI1KL1olf4
7fz3xRvE5yQbJC9IS6V3ST+UJeQV8u8r8hWPKVcov6MqVY2pUupD6h9rNml+ pK3QHtGV6V7VzxnU
hjsMHxt3m7SmDaY/mwvN91uMllNWdxrXpII0ok1Ne/VaEmR/X8q9JroX61hr FnRl/sKYkGhmBPvV
kmgGpkRM4hmYIzlkqb8I9cHuDMwTJbk5A4uJmdydgSVkLzmbgaXECP4MLCNq iGRgBa5h4/JfORfD
eAZWkX3wtQysJn5qZisWybC0n67JwOjT0uczMCVK+usMzJF6eiEDi0gxV5KB eWLl+jOwmBRxuzKw
hPyZuy8DS0mh6GsZWEayRM9mYAVZKXozAyvJ5ehqpGEVSfGTGVhNusQ76sdH x+fG9w4PuYcG5gbc
D7lLQ6FK95rZweGJoeEZ99rJmanJmYG58cmJYvea7dvdM+OjY3Oz7pnh2eGZ ncNDxRvGtw6n293t
wzPjI+vmBraPDy6PD7g/38Gd7vE3qruGZ2ZZXUlxqPRiF6FH4AsDx2fdA+65 mYGh4R0DM1e4J0fc
bbiP2MBckXvdxGAxLnJ0fHZueAYrxyfcncXtxe74wNzwxJx7YGLI3bE8sGVk ZHxwWKgcHJ6ZG8DO
k3NjuPpt8zPjs0Pjg+xts8VfhpT2ueGdw+6NA3Nzw7OTE2Nzc1OrgsFdu3YV D2Q6D2Lf4sHJHcH/
qm1uz9Tw0PDs+OgEbr94bG7H9s7ZYbafuTHc4yU7HpnExc9OjsztGpgZZvuf nd+6bXhwzj03iX2H
3Yif4QkcOjA6Mzy8g+10XljxrrHxwTH3nsl598Dg4PDUHGKEdf9bMxf/V4vd vjxIWCmpJ+NkFO85
vPeSYVSQbrwHsDyA0EN4l2JYHiKVCK0hs2QQ+0xgj2EygzVrySQ+p4TfAWGO SWwtFvpux39urGfz
j2HbrFAaxicbu1N4VzHZgO1bhZqL492kXagZJyNknbCS7QgPfsn7A3j/r2Zw f2aO/7PeXUL97HK/
ElxxCDHyZbNcnCPwv/HGcQEfDMdzQgvb0Q58zpArsG5SWElbhh4xYWSRsLYJ nLE4g8lRYZY5Ye50
z3Fh7k7s0S70igsjGcbmhLdNCL06vuSNLfjGEWG9w5f0HBTmZntJzzyJ8FgG 99vIvLDfWezJxi3t
bRbf/L/LKe3C6nYK79wo1M8JHMLaxoTSFFmFhiRIdgn/irHPZ2cezMxbLEA7 sOf/7bg5sgfLw0L7
rMC1ExnqFwtz7kB6dgrcu0Qfhos0Hb+cxiPCk2F+VhgxhysZEGi1RP9ZxOFW xOSwgD8242RmXtZn
e4YeE5m3DuCa2GhGtyWazl+C413Cegbx1417mcQ2NmZQmGNKwOzQJbP/n665 +P8as9u/5E0XcSrY
erL4h9PPLXpwii+5niVxkKABDgq/Z0AU1cGrC/DsAmgXYPITiH4CH58DTVTv c/13x6LrL/FC10fx
atef/ljtegoMoI8eqHZ9eKHa9UHTouu9uM/1O7x/+26167/Fy13v4v3rJ8Ku d56wu37/ftj19lth
16+4sCv4fv/7+94/875Ig8CZ99Ehk5G3oDr4VuStfW89+5aIAS1vnUHw/FuL b0k0b8G/4qh/ime5
fon3L/D+x/ii6+Uf17h+3FLt+mGLD5eiSK8x+AJEXrj5Bfr8Nxddz+JSzoHq sSY9PpTfw5q/2+Jz
ac6BPCqDpx8pc33/kUUhoAs/lVvY+FQ81xX5HjyJg559AjRn+s9Mnrn3jGjq 0f2P3vIo53409Gj0
0VcffefRPz4qfgT7PAM6UgNa0gnaxxzV+AJ1tNjHdWrug+ApuPkULJ6CxKmp U/tPcQ/pF10Pcouu
k2F95z048u72atf966uFN5u+6cltvPebZ75J78JV3rl+0XUCW54BJ1iIj7jA +ni7zxX5PpZawBJd
T796e7VLc/u+26nstniN61a8jyMmbrmxxnXzMZ/rpmM1LnIMVmuOwY34koPX +lwHrq12TV27/1q6
c77a9cd5mJtd4ZoV8GKKOqZ8rskJv2uiaYXLrnB02sLWTkmY6xTjYp8BOxiF Jdge7w+7oufA+Fhu
QSOu+fEBf6hR+PpjwOVtTPRHXf1sPqy4q8+e3Xh5k9u1uTfk6m3yuYyg7zTg rnngOkU4sUb4I6N+
bh93hhMn2qfa97dzba1BVytO8E78j3GqaXG1BFu45qawaz3iY11TtSvWtNKl aXI1BZvON73d9Icm
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #511666 is a reply to message #511622] |
Tue, 02 February 2010 08:38   |
Ed Merks Messages: 24529 Registered: July 2009 |
--------------060005010000000108020501
Content-Type: text/plain; charset=UTF-8; format=flowed
Vlad,
Comments below.
Vlad Varnica wrote:
> Ed,
> Every good EMF developer knows that the needed job to upgrade to
> Athena is just two to three days and that you just need to change
> plugin dependencies :lol:
I have no idea why you're talking about Athena builds. Even if that
were relevant, exploiting Athena would not involve changing any plugin
dependencies.
> The question could be why so few persons have been trained on EMF
> technologies ?
So few? You've done a survey or is this another one of your aimless
reassertions.
> What is the EMF adoption by companies ?
I've not done a survey myself, but according to EclipseCon stats, EMF
places third only to JDT, and RCP in terms of usage.
http://ianskerrett.wordpress.com/2009/04/06/eclipsecon-2009- demographics/
> So......this EMF project is dead for me
Certainly by now you've made your point clear and your poisonous
complaining has grown tiresome. The incessant whining is shrill. It
stands in sharp contrast to folks like Hasan who show up with creative
contributions.
> because except build dependencies change required for each new Eclipse
> build no quality has been added on EMF since 2005 !!
It was a very fine year. May you enjoy it in perpetuity.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Vlad,<br>
<br>
Comments below.<br>
<br>
Vlad Varnica wrote:
<blockquote cite="mid:hk8udi$ob5$1@build.eclipse.org" type="cite">Ed,
<br>
<br>
Every good EMF developer knows that the needed job to upgrade to Athena
is just two to three days and that you just need to change plugin
dependencies :lol: </blockquote>
dependencies.<br>
<blockquote cite="mid:hk8udi$ob5$1@build.eclipse.org" type="cite">The
technologies ?</blockquote>
reassertions.<br>
<blockquote cite="mid:hk8udi$ob5$1@build.eclipse.org" type="cite"> What
is the EMF adoption by companies ? <br>
</blockquote>
places third only to JDT, and RCP in terms of usage. <br>
<blockquote><a
href=" http://ianskerrett.wordpress.com/2009/04/06/eclipsecon-2009- demographics/"> http://ianskerrett.wordpress.com/2009/04/06/eclipsecon-2009- demographics/</a><br>
</blockquote>
<blockquote cite="mid:hk8udi$ob5$1@build.eclipse.org" type="cite">So......this
EMF project is dead for me </blockquote>
contributions.<br>
<blockquote cite="mid:hk8udi$ob5$1@build.eclipse.org" type="cite">because
except build dependencies change required for each new Eclipse build no
<br>
</blockquote>
It was a very fine year. May you enjoy it in perpetuity.<br>
</body>
</html>
--------------060005010000000108020501--
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #511720 is a reply to message #511701] |
Tue, 02 February 2010 11:19   |
Hasan Ceylan Messages: 198 Registered: July 2009 |
Hello Vlad & Ed,
I'll throw my 2c...
In a previous assignment we had a project more like an intranet application
where you manage document, make applications (which flow through a complex
400+ step BPM), integration with a SOA engine, task, inbox, etc... It was a
big government project with 500 daily users.
We chose the EMF / teneo, RAP(RCP), Databinding, hibernate, JTrecache,
equinox project stack. We also have written a simple editor to manipulate
EMF model.
I must admit I enjoyed defining my models in ecore. With the help of teneo
my DAO consisted only ~100 lines. Since the application security (this is
including down to input element levels with hidden/read/write granularity)
was so tight we also kept the security definitions in the ecore model.
We kept the database schema definitions along with the ecore classes, which
helped BI developers and DB admins to get updates momentarily (In the early
phase of the project there were weekly deployments).
I think one of the problems with java world is it has the J2EE definition.
90% times you make a project, you choose the Application server, JPA, Web
model etc for the project. But people believe "If it is a commercial /
corporate product it's gotta be J2EE compliant", which is a big bold and
IMHO unnecessary binding. Most of the time, you do not WORE! Not to mention
there is the saying "Write Once Debug Everywhere".
Lately application server vendors started adopting OSGI and we'll see where
this will go. But to be honest (this might require a correction) without
using equinox, you cannot use much of the eclipse technologies where the
base plugins require definitions via extension points. e4 with the new
dependency injection stuff may make this comment deprecated. But with the
more and on-the-target adoption of OSGI, we'll see more eclipse technologies
used outside RCP and IDE domain.
On the other hand, Ed can give more examples but from Aviation to Eclipse
independent Development tools and CRUD apps, RCP, (Riena RAP) is enjoying
more and more adoption. And it is becoming a fact that "If you go with RCP,
you gotta go with EMF"
Last but not the least, as an EMF newsgroup (or forum) follower, I think you
like EMF as well. To help more industry adoption, we (you, me and the
others) are the messengers. We should spread the word. On the project above
I mentioned, people were like 'Are you crazy you are taking way more risks,
how are you gonna get support', well, we used the SOA engine and DB of one
of the largest provider provider, we have a support ticket still open for 6
months, where I had over 20 interactions with RAP, Teneo, EMF team. (Ed
might remember the EMF databinding development).
In the end, the project was a big success and a breakthrough not in the
country but at the global level. I was actually planning to apply for
speaking in Eclipse Con but as, I left the company, this won't happen.
Check out [1], I think the reason for the drop in EMF is due to the crisis
where companies needed cheaper resources...
Hasan
Vlad Varnica wrote:
[1] http://www.indeed.com/jobtrends?q=EMF%2C++osgi&l=
> Quote:
>> demographics/
> Nobody uses EMF except few plugin providers which are going to Eclipsecon.
> The result of this survey is not relevant.
> My personal survey is that I asked 100 companies using Eclipse if they
> ever used EMF except for testing, The result was 0 professional use of EMF
> !! :twisted:
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #511941 is a reply to message #511824] |
Wed, 03 February 2010 08:31   |
Sven Efftinge Messages: 1667 Registered: July 2009 |
It used to be entertaining, especially Ed's replies.
But lately it started to get annoying. Please stop it.
Sven
Eike Stepper schrieb:
> Vlad Varnica schrieb:
>> This post is stupid as well as EMF/Ecore marketing strategy that this
>> project has done in the last 7 years.
>> I don't say that EMF is bad, this is actually excellent to generate
>> the skeleton of your application what I don't agree is that EMF is the
>> final stage of modeling and will replace UML.
>> It seems to me that EMF is like the muslim extreme religion which
>> consider itself as the final stage religion because created after. The
>> reality is that we need both and should respect both but never try to
>> attack or destroy the other !! EMF systematically attacked UML in the
>> last few years and successfully created a fake dreaming story !!
>> This is why I am so upset with Ed comments and this is why I have
>> decided to start my personal war against EMF. Stop criticism against
>> UML and I will stop attacking your EMF technology.
> Thank you for your personal war and please don't stop it! It's the most
> entertaining story in the community ;-)
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #511948 is a reply to message #511720] |
Wed, 03 February 2010 08:51   |
--------------080806080904090201050504
Hasan,
That for the interesting background story!
Hasan Ceylan wrote:
> Hello Vlad & Ed,
> I'll throw my 2c...
> EMF model.
> Hasan
>> Quote:
>>> demographics/
>> !! :twisted:
<html>
<head>
</head>
Hasan,<br>
<br>
That for the interesting background story! <br>
<br>
<br>
Hasan Ceylan wrote:
<blockquote cite="mid:hk9ja4$qkc$1@build.eclipse.org" type="cite">
<pre wrap="">Hello Vlad & Ed,
I'll throw my 2c...
EMF model.
Hasan
Vlad Varnica wrote:
[1] <a class="moz-txt-link-freetext" href="http://www.indeed.com/jobtrends?q=EMF%2C++osgi&l=">http://www.indeed.com/jobtrends?q=EMF%2C++osgi&l=</a>
</pre>
<blockquote type="cite">
<pre wrap="">Quote:
</pre>
<pre wrap="">I've not done a survey myself, but according to EclipseCon stats, EMF
<a class="moz-txt-link-freetext" href="http://ianskerrett.wordpress.com/2009/04/06/eclipsecon-2009">http://ianskerrett.wordpress.com/2009/04/06/eclipsecon-2009</a>-
demographics/
</pre>
</blockquote>
<pre wrap="">
!! :twisted:
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------080806080904090201050504--
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #511999 is a reply to message #511971] |
Wed, 03 February 2010 10:48   |
Vlad,
Comments below.
Vlad Varnica wrote:
> EMF project is for me dead today because:
> - the modeling expectations have never been reached.
You should not confuse your personal expectations with those of others.
> I mean that technically EMF is full of bugs and it would require a
> very large investment to make it usable today.
In actual fact, the number of bugzilla defects (as opposed to feature
enhancements) is about a handful.
> The problem is that IBM, Omondo or any other corporation don't want to
> invest anymore in this technology.
I don't remember Omondo ever investing anything. I understand it relied
significantly on public funds for development though. I've noticed SAP
investing significantly these days, but I guess they're such a tiny
little company they don't really count.
> - the EMF adoption has been very poor in real projects.
A baseless assertion.
> I don't even know except EclipseUML Omondo how many very complex
> projects have been created in the last 7 years ?
That's the real problem. You know almost nothing so you make things up.
> - EMF is perfect to generate a skeleton of an application but it is
> impossible to generate another quality code without erasing existing
> code manually codded.
Yet I do this myself on a regular basis, as do uncounted other clients.
> In my experience we had many bugs between 2002 and 2006 because we
> used EMF to generate code at each model change. It was a real
> disaster. Hundred of thousands of users have experienced diagrams
> crashed, model corruption, out of memory etc....
Neither EMF nor Java can be responsible for how downstream clients code
their application as a whole.
> Finally being very upset with the framework quality I required from
> the research team to manually fix bugs with JDK and not to regenerate
> a code from a model.
I'm sure it was a pleasure to work for you and your ability to retain
your employees was exemplary.
> Since 2007 we are not anymore using EMF code generator to re create
> code if the model change and preferred to manually update the
> application. The application was getting a lot better than previously
> using directly JDK and not EMF.
I'm sure hand coding the metadata is an interesting exercise in futility.
> - EMF is trying to target to many modeling domains and is not
> therefore a specialist in any specific modeling subject. This is a
> wrong architecture decision started at the project creation and it is
> too late to go back.
Wrong for you, but very right for the community.
> - EMF is too complex to understand and require 18 month full time
> training just in order to be able to use the framework in the right maner.
I wouldn't argue EMF is trivially simple, but I would argue that
complexity is in the eye of the beholder. Java itself take a long time
to learn
> How will today invest 18 month in such an unstable, none monetize
> technology ?
Others see it differently. They see a stable, reliable code base that's
used by a large and growing client base with many millions of dollars of
time invested in it.
> I don't say that Ecore/EMF are bad technology but just that if you try
> to cover all domains then you cover nothing as today. EMF is dead and
> please rest in peace !!
Yet you see to want to do precisely the same thing with UML. UML is
most certainly not simpler than Ecore, nor is the technology base as stable.
> Vlad,
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #512073 is a reply to message #512054] |
Wed, 03 February 2010 14:34  |
Vlad,
Comments below.
Vlad Varnica wrote:
> If SAP is using EMF this is certainly not a good recommendation
> because in the last few years their development tool netwearver was
> real crap !!
Could you be more poisonous?
> I remember when they have selected togethersoft in 2002 as corporate
> modeling tool, and meeting them in a conference somewhere in Germany
> in 2005 during this short talk they said to me that EMF is not scalable.
> This was ridiculous to hear that Ecore /EMF are not scalable because
> this is one of the key advantage of this technology
It's amazing the type of FUD folks will spread isn't it? CDO certainly
helps with scaling...
> SAP should stop netweaver immediately and buy Tibco then they will
> have solid rock foundation on which they could build advanced modeling
> tools and use Ecore with UML :)
I'm sure they'll jump right on your latest recommendations.
> Vlad,
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #618586 is a reply to message #618584] |
Mon, 01 February 2010 12:34  |
Vlad,
How this relates to the post is beyond my understanding. How about
grinding your ax elsewhere?
Vlad Varnica wrote:
> This open source modeling market is not easy specially for
> contributors not making any money from their job.
> The question is to know how much EMF is strategic to some companies ?
> The other question could be is Athena strategic and important today ?
> we could see strange or last moment contributions if it goes totally
> the wrong way so just wait ......
> Vlad,
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #618587 is a reply to message #511490] |
Tue, 02 February 2010 05:22  |
Vlad Varnica Messages: 546 Registered: July 2009 Location: Milton Keynes - UK |
Ed,
Every good EMF developer knows that the needed job to upgrade to Athena is just two to three days and that you just need to change plugin dependencies :lol:
The question could be why so few persons have been trained on EMF technologies ? What is the EMF adoption by companies ?
So......this EMF project is dead for me because except build dependencies change required for each new Eclipse build no quality has been added on EMF since 2005 !!
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #618588 is a reply to message #618587] |
Vlad,
Comments below.
Vlad Varnica wrote:
> Ed,
dependencies.
> technologies ?
reassertions.
contributions.
<html>
<head>
</head>
Vlad,<br>
<br>
Comments below.<br>
<br>
<br>
<br>
dependencies.<br>
reassertions.<br>
</blockquote>
<blockquote><a
</blockquote>
contributions.<br>
<br>
</blockquote>
</body>
</html>
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #618592 is a reply to message #618589] |
Hello Vlad & Ed,
I'll throw my 2c...
EMF model.
Hasan
> Quote:
>> demographics/
> !! :twisted:
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #618938 is a reply to message #511729] |
Tue, 02 February 2010 14:21  |
This post is stupid as well as EMF/Ecore marketing strategy that this project has done in the last 7 years.
I don't say that EMF is bad, this is actually excellent to generate the skeleton of your application what I don't agree is that EMF is the final stage of modeling and will replace UML.
It seems to me that EMF is like the muslim extreme religion which consider itself as the final stage religion because created after. The reality is that we need both and should respect both but never try to attack or destroy the other !! EMF systematically attacked UML in the last few years and successfully created a fake dreaming story !!
This is why I am so upset with Ed comments and this is why I have decided to start my personal war against EMF. Stop criticism against UML and I will stop attacking your EMF technology.
Vlad,
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #618939 is a reply to message #618938] |
Wed, 03 February 2010 01:27  |
Eike Stepper Messages: 5148 Registered: July 2009 |
Cheers
/Eike
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #618945 is a reply to message #618939] |
Sven
> Cheers
> /Eike
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #618947 is a reply to message #618938] |
Wed, 03 February 2010 08:45  |
Vlad,
Comments below.
If you refer to your own post then it's the first thing you've said in
this thread with which I agree.
That's for each of us to judge for ourselves.
Oh great. Let's bring religion into the discussion. That should help
keep it technical.
> dreaming story !!
You seem to be an expert on fake dreaming stories too.
As long as you don't feel compelled to crash airplanes into buildings
full of people I'm sure your rhetoric will provide some entertainment
value.
At the end of a post like this you really have to question exactly who
is the religious fanatic?
While I will argue that UML has a valuable place in the community, that
it is ideal for solving a sizeable class of problems, I will also argue
that UML is not a panacea and that it is not ideal for all problems in
the known universe. Surely any reasonable person sees the world in
shades of gray where white and black are simply the extremes...
> Vlad,
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #618950 is a reply to message #511720] |
Hasan,
Hasan Ceylan wrote:
> Hello Vlad & Ed,
> I'll throw my 2c...
> EMF model.
> Hasan
>> Quote:
>>> demographics/
>> !! :twisted:
<html>
<head>
</head>
Hasan,<br>
<br>
<br>
<br>
I'll throw my 2c...
EMF model.
Hasan
</pre>
<pre wrap="">Quote:
</pre>
demographics/
</pre>
</blockquote>
<pre wrap="">
!! :twisted:
</pre>
</blockquote>
</pre>
</blockquote>
</body>
</html>
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #618954 is a reply to message #511948] |
Wed, 03 February 2010 10:01  |
- the modeling expectations have never been reached. I mean that technically EMF is full of bugs and it would require a very large investment to make it usable today. The problem is that IBM, Omondo or any other corporation don't want to invest anymore in this technology.
- the EMF adoption has been very poor in real projects. I don't even know except EclipseUML Omondo how many very complex projects have been created in the last 7 years ?
- EMF is perfect to generate a skeleton of an application but it is impossible to generate another quality code without erasing existing code manually codded. In my experience we had many bugs between 2002 and 2006 because we used EMF to generate code at each model change. It was a real disaster. Hundred of thousands of users have experienced diagrams crashed, model corruption, out of memory etc....
Finally being very upset with the framework quality I required from the research team to manually fix bugs with JDK and not to regenerate a code from a model. Since 2007 we are not anymore using EMF code generator to re create code if the model change and preferred to manually update the application. The application was getting a lot better than previously using directly JDK and not EMF.
- EMF is trying to target to many modeling domains and is not therefore a specialist in any specific modeling subject. This is a wrong architecture decision started at the project creation and it is too late to go back.
- EMF is too complex to understand and require 18 month full time training just in order to be able to use the framework in the right maner. How will today invest 18 month in such an unstable, none monetize technology ?
I don't say that Ecore/EMF are bad technology but just that if you try to cover all domains then you cover nothing as today.
EMF is dead and please rest in peace !!
Vlad,
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #618956 is a reply to message #618954] |
Vlad,
Comments below.
to learn
> technology ?
> Vlad,
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #618959 is a reply to message #511999] |
Wed, 03 February 2010 13:13  |
If SAP is using EMF this is certainly not a good recommendation because in the last few years their development tool netwearver was real crap !!
I remember when they have selected togethersoft in 2002 as corporate modeling tool, and meeting them in a conference somewhere in Germany in 2005 during this short talk they said to me that EMF is not scalable.
This was ridiculous to hear that Ecore /EMF are not scalable because this is one of the key advantage of this technology
SAP should stop netweaver immediately and buy Tibco then they will have solid rock foundation on which they could build advanced modeling tools and use Ecore with UML :)
Vlad,
| Re: Appeal for review from modeling community to review EMF Build Manager Project Proposal [message #618967 is a reply to message #618959] |
Vlad,
Comments below.
> real crap !!
> Vlad,
Current Time: Sat May 18 20:23:09 EDT 2013
Powered by FUDForum. Page generated in 0.07640 seconds
