| How to use AGR to capture interactions in other environment. [message #511710] |
Tue, 02 February 2010 10:56  |
Caio Bulgarelli Messages: 16 Registered: February 2010 |
Junior Member |
Hi all,
I work at Motorola (Brazil) and I would like some help with TPTP AGR.
I'm working in MOTODEV Project. Have all of you ever heard about Motodev Studio?
It's a software (based on Eclipse) that general users can use to develop apps for Motorola phone.
This is the web site:
http://developer.motorola.com/
So, I need to do several tests on this software.
How can I use the AGR to recorder MACROs (and Call "hooks" in order to do JUnit tests to validate the Tests)?
I have easily used the Eclipse to capture "mouse interaction" inside ECLIPSE.
But... How can i get the "mouse interations" (MACROs) inside MOTODEV STUDIO with AGR?
(Like a "Target" ... I mean... I create the Recorder inside environment MOTODEV STUDIO using ECLIPSE).
Thanks for the help.
Caio Bulgarelli
R&D - CM - MOTODEV
MOTOROLA BRAZIL
| Re: How to use AGR to capture interactions in other environment. [message #511902 is a reply to message #511710] |
Wed, 03 February 2010 06:21  |
Paul Slauenwhite Messages: 970 Registered: July 2009 |
Hi Caio,
Please see:
http://www.eclipse.org/tptp/test/documents/gettingstarted/Au tomated_GUI_Recorder_Getting_Started.html
Note, the AGR requires an Eclipse IDE and does not support
RCP/stand-alone SWT applications.
Also, in TPTP 4.5, the AGR was moved from a Technology Preview component
to an As-Is component. As-Is components are primarily provided for prior
users but imply no support (for example, defects, news group, and mailing
lists).
Paul
"Caio Bulgarelli" <qbxt43@motorola.com> wrote in message
news:hk9hvi$o0$1@build.eclipse.org...
> Hi all,
> Studio?
> ECLIPSE. But... How can i get the "mouse interations" (MACROs) inside
> Caio Bulgarelli
> R&D - CM - MOTODEV
> MOTOROLA BRAZIL
FUDForum. Page generated in 0.01726 seconds
