Home » Eclipse Projects » Rich Client Platform (RCP) » INI file missing in the deployed RCP product
INI file missing in the deployed RCP product [message #511576] Tue, 02 February 2010 01:37 Go to next message
Karan  is currently offline Karan
Hi all
I am new to RCP. When I finished creating an RCP app, I deployed it.. but could not find the eclipse.ini file or <launcher>.ini file.
I need this ini file so as to increase the memory usage as my product gives out of memory exception when too much data is given to it.
How do I put an INI file onto my deployed product so that the memory usage may be controlled so that it can handle large amounts of data given to it?
Thank you,
Re: INI file missing in the deployed RCP product [message #511579 is a reply to message #511576] Tue, 02 February 2010 01:55 Go to previous messageGo to next message
Daniel Krügler is currently offline Daniel Krügler
> given to it?
Please check the following:
1) Your .ini file should be part of the bin.includes section of
your build.properties file.
2) Since you speak of a *product* I assume that you extended the
org.eclipse.core.runtime.products extension point. Check out that
you have a properties element which references the .ini file:
<extension
id="/your-id/"
point="org.eclipse.core.runtime.products">
<product
application="/your-app/"
description="/your-descr/"
name="/your-name/">
<property
name="preferenceCustomization"
value="/your-ini/.ini"/>
HTH & Gretings from Bremen,
Daniel Krügler
Re: INI file missing in the deployed RCP product [message #511596 is a reply to message #511579] Tue, 02 February 2010 03:34 Go to previous message
Hi Daniel,
Thanks for the reply.
Actually, the build.properties file under the bin.includes does not have any mention of a .ini file.
build.properties file :=
source.. = src/
output.. = bin/
bin.includes = plugin.xml,\
               META-INF/,\
               icons/,\
So what INI file and how must I include it into the build.prop file?
And ...
the org.eclipse.core.runtime.products does not have any property refering it.... so should I be explicitly creating another property in the XML refering the same ini file i have specified in the build.properties?
Thank You,
Previous Topic:Multi Plugin Project Problems with Menu
Next Topic:commands vs actions
Current Time: Wed May 22 19:08:06 EDT 2013
Powered by FUDForum. Page generated in 0.08436 seconds
