| Browser proxy configuration [message #511343] |
Mon, 01 February 2010 06:45  |
froq Messages: 4 Registered: February 2010 |
Junior Member |
After installing ATF, opening URL fails. Since I'm behind a firewall I guess I need to configure the proxy. How?
| Re: Browser proxy configuration [message #511435 is a reply to message #511343] |
Mon, 01 February 2010 05:42   |
Jacek Pospychala Messages: 159 Registered: July 2009 |
hi Froq,
unfortunately ATF doesn't provide any UI for proxy configuration at the
moment, however you're not totally lost.
Since we're based on XULRunner, ATF creates a separate profile in your
home directory: <home>/.mozilla/eclipse
There you'll find prefs.js file with all preferences. For example proxy
preferences can look like this:
user_pref("network.proxy.http", "150.254.6.139");
user_pref("network.proxy.http_port", 8080);
user_pref("network.proxy.type", 1);
If you're on Windows, then it should be <home>\Application
Data\.mozilla\eclipse, however I didn't tested that.
I have also created following bug, to fix this:
301424: Integrated browser should use proxy settings as configured in
Eclipse
https://bugs.eclipse.org/bugs/show_bug.cgi?id=301424
thanks
Jacek
FUDForum. Page generated in 0.01577 seconds
