Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » guide for analyzing Object allocation(guide for analyzing Object allocation)
guide for analyzing Object allocation [message #511441] Mon, 01 February 2010 10:51
Devaraj  is currently offline Devaraj
I am able to profile my application using HeapProf option.
After collecting the data, i am able to open them with Object Allocation or Memory Statistics option.
Now i got the following details.
Class
package
Total Instances
Live Instances
Collected
Total Size
Active Size
can any body guide me, how to analyze these above statistics.
can i assume that Live instances are supposed to be garbage collected, since they are unreachable, they are not garbage collected?
Please let me know, if there is any article to interpret these above results.
regards
Devaraj
Re: guide for analyzing Object allocation [message #511476 is a reply to message #511441] Mon, 01 February 2010 07:02 Go to previous message
Eugene Chan is currently offline Eugene Chan
Hi Devaraj
Here is a quick summary of the columns in the view:
a.. Live Instances: The current number of objects in the heap, of the
specified class, that are presently being utilized (have not been garbage
collected.)
b.. Total Instances: The total number of objects in the heap, which have
been created during the JVM's lifetime (including those that have been
garbage collected).
c.. Active Size (bytes): The total size of all object instances, of the
particular class, that are presently used by the JVM (e.g. have not been
garbage collected.). Note that object-size is JVM implementation dependent.
d.. Total Size (bytes): The total size of all object instances of the
class, including those have been garbage collected earlier in the
application lifecycle.
e.. Average Age: The average age of an object before it is garbage
collected, as measured by the number of garbage collections that this object
has survived. Objects that have survived a large number of garbage
collections are considered to be a memory leak if their usage is no longer
required by the application.
f.. Collected: The total size of objects that has been GC'ed.
Eugene
"Devaraj" <dkommineni@yahoo.com> wrote in message
news:hk6t9f$9pd$1@build.eclipse.org...
> Class
> package
> Total Instances
> Live Instances
> Collected
> Total Size
> Active Size
> results.
> regards
> Devaraj
Re: guide for analyzing Object allocation [message #511477 is a reply to message #511476] Mon, 01 February 2010 07:02 Go to previous message
Please also check the Help Content which contains more detail about the view
and its content.
Eugene
"Eugene Chan" <ewchan@ca.ibm.com> wrote in message
news:hk706p$r8o$1@build.eclipse.org...
> Hi Devaraj
> collected.)
> garbage collected).
> dependent.
> object has survived. Objects that have survived a large number of garbage
> Eugene
>> Class
>> package
>> Total Instances
>> Live Instances
>> Collected
>> Total Size
>> Active Size
>> results.
>> regards
>> Devaraj
Previous Topic:Profiling the application does not work properly with CGProf option
Next Topic:Eclipse JNI Help?
Current Time: Tue May 21 06:56:52 EDT 2013
Powered by FUDForum. Page generated in 0.01960 seconds
