Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » Testing with AGR in headless moda and integration in the build process
Testing with AGR in headless moda and integration in the build process [message #511182] Sat, 30 January 2010 14:45 Go to next message
Michelle Davidson is currently offline Michelle Davidson
Member
I'm using the AGR from TPTP for functional testing of my Plugins.
Now I have a question. How can I automated the test process for integration in my build process. Is there a chance to do that with ant. I'm looking for that but I found no information.
Another question is, can I use agr for testing on a mac or does that not function?
And how can I debug a test. The normal way, to do this by run in the debug mode is not allowed.
[Updated on: Sun, 31 January 2010 02:59]
Report message to a moderator
Re: Testing with AGR in headless moda and integration in the build process [message #511345 is a reply to message #511182] Mon, 01 February 2010 01:48 Go to previous message
Paul Slauenwhite is currently offline Paul Slauenwhite
For build integration, we suggest using the ASF:
http://help.eclipse.org/galileo/topic/org.eclipse.hyades.tes t.doc.user/tasks/tlaunching-tests-from-scripts-and-applicati ons.htm
TPTP uses the same infastrcuture for our BVTs:
http://www.eclipse.org/tptp/home/documents/process/test/auto mation/process/TPTP_Testing_Strategy_Part_2.html#5.0
Unfortunately, the AGR does not support Mac.
In addition, in TPTP 4.5, the AGR was moved from a Technology Preview
component to an As-Is component. As-Is components are primarily provided for
prior users but imply no support (for example, defects, news group, and
mailing lists).
Paul
"Michelle Davidson" <michelle.davidson@gmx.de> wrote in message
news:hk2296$o0a$1@build.eclipse.org...
> Hello,
> Another question is, can I use agr for testging on a mac or does that not
> function?
Previous Topic:Creating Agent
Next Topic:profiling doesn't stop
Current Time: Wed May 22 16:50:25 EDT 2013
Powered by FUDForum. Page generated in 0.02540 seconds
