Home » Eclipse Projects » ATF » Blog on dev.eclipse for ATF
Blog on dev.eclipse for ATF [message #511204] Sat, 30 January 2010 14:36 Go to next message
sNop is currently offline sNop
Hi Jacek,
when you will have more time, you can also post some infos about ATF into http://dev.eclipse.org/blogs/atf/ ;)
Re: Blog on dev.eclipse for ATF [message #511250 is a reply to message #511204] Sun, 31 January 2010 15:32 Go to previous messageGo to next message
Jacek Pospychala is currently offline Jacek Pospychala
Good idea. Any suggestions what the community would like to hear about
for start?
I'll have to think about this but any suggestions are welcome.
....or maybe you'd like to write a couple of posts about ATF?
Jacek
sNop wrote:
> Hi Jacek,
Re: Blog on dev.eclipse for ATF [message #511252 is a reply to message #511250] Sun, 31 January 2010 15:59 Go to previous message
if i will have some idea a let you know.
Dne 31. 1. 2010 21:32, Jacek Pospychala napsal(a):
> for start?
i'm not english man, so my english isn't so good, so as (in order to) i write english blog.
> Jacek
> sNop wrote:
>> Hi Jacek,
Re: Blog on dev.eclipse for ATF [message #562597 is a reply to message #511250] Sun, 31 January 2010 15:59 Go to previous message
> for start?
> Jacek
> sNop wrote:
>> Hi Jacek,
Previous Topic:Blog on dev.eclipse for ATF
Next Topic:Browser proxy configuration
Current Time: Tue May 28 21:52:55 EDT 2013
Powered by FUDForum. Page generated in 0.01646 seconds
