| Problem with run menu action [message #511146] |
Sat, 30 January 2010 07:55  |
Originally posted by: a0309169.unet.univie.ac.at
I have a simple problem - when I open a file of my specified content
type, the "Run" option from the "Run" top-level menu remains invisible.
However, I have implemented everything needed for launching, up to and
including a LaunchShortcut (which works from the context menu of the
project navigator). Which means I have missed something again.
I've dug through this list, the Wiki, and the Ruby plugin, but
unfortunately I haven't found my answer.
Any idea about what should I add?
Mikołaj
| Re: Problem with run menu action [message #552979 is a reply to message #511493] |
Sun, 15 August 2010 12:04  |
Hi Alex,
for the record - this solved the problem, thanks :).
Mikołaj
> Hi Mikołaj,
> I think the following should help:
> <extension point="org.eclipse.ui.actionSetPartAssociations">
> <actionSetPartAssociation targetID="org.eclipse.debug.ui.launchActionSet">
> <part id="org.eclipse.dltk.ruby.ui.editor.RubyEditor" /> (use your
> editor id here)
> </actionSetPartAssociation>
> </extension>
> Alex
FUDForum. Page generated in 0.01638 seconds
