Home » Eclipse Projects » Web Tools Project (WTP) » ContentAssist with AdditionalInfo in HTML format
ContentAssist with AdditionalInfo in HTML format [message #510042] Tue, 26 January 2010 05:31 Go to next message
Xavier Coulon is currently offline Xavier Coulon
Member
I'm working on a plugin for the WTP HTML editor. For now, this plugin provides just extra elements based on the Apache Tapestry web framework.
For each proposal, I want to display additional info based on the javadoc of the web framework components (if available).
Up to now, I've managed to generate the proposals and I can retrieve the javadoc in plain text or HTML format, using
JavadocContentAccess.getContentReader(component, true);
or
JavadocContentAccess.getHTMLContentReader(component, true, true);
Yet, the javadoc is not displayed as an HTML content, so all paragraphs (<p> tags) and links are lost, and the additional info is not very readable.
Actually, the CompletionProposal constructor only takes a String as a parameter for additionalInfo attribute, I haven't seen any switch to activate some HTML rendering.
Also, I've read on another thread that the JDT additional info uses the SWT Browser underneath to render the javadoc in HTML.
Does this feature exist in the context of WTP HTML editor ?
Thank you in advance
Xavier
Re: ContentAssist with AdditionalInfo in HTML format [message #510284 is a reply to message #510042] Wed, 27 January 2010 00:39 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
No, but not because we've never thought of it. We're waiting for the
necessary classes to become proper API in the Platform rather than
create and support our own copies of them.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=218482
https://bugs.eclipse.org/bugs/show_bug.cgi?id=241896
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: ContentAssist with AdditionalInfo in HTML format [message #510572 is a reply to message #510042] Wed, 27 January 2010 16:14 Go to previous message
Member
Hello Nitin,
Thank you for the answer. I just voted for those issues Wink
Xavier
Previous Topic:Can't get logfiles for tomcat 5.5
Next Topic:STDERR in red in eclipse for tomcat 5.5
Current Time: Wed May 22 08:22:48 EDT 2013
Powered by FUDForum. Page generated in 0.11466 seconds
