Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] junit tests in headless buckminster
Re: [buckminster-dev] junit tests in headless buckminster [message #510010] Mon, 25 January 2010 21:50
Achim Demelt is currently offline Achim Demelt
Nick,
It's "org.eclipse.buckminster.junit_1.0.0.r11055.jar".
Your -name pattern doesn't mach that. But no worries, the
feature's there ;-)
Thanks for to taking the time to search for the file,
though.
Achim
On Tue, 26 Jan 2010 00:44:58 -0500
Nick Boldt <nickboldt@gmail.com> wrote:
Searching for such a feature or plugin on the
buckminster
update site,
the best I can find in ~/downloads/tools/buckminster is:
$ find . -maxdepth 3 -type f -name
org.eclipse.buckminster.junit.\*.jar
./updates-3.6/plugins/org.eclipse.buckminster.junit.source_1 .0.0.r11055.jar
./updates-helios/plugins/org.eclipse.buckminster.junit.sourc e_1.0.0.r11055.jar
./headless-3.6/plugins/org.eclipse.buckminster.junit.source_ 1.0.0.r11055.jar
Is this feature being built and published?
N
On Mon, Jan 25, 2010 at 12:30 PM, Cailliau, Dieter
<dieter.cailliau@barco.com> wrote:
> I need an archived update site (containing the
>org.eclipse.buckminster.junit.feature.feature.group ? )
> This is not mentioned on this page:
>http://www.eclipse.org/buckminster/downloads.html
> so i don't know where to find it.
> -----Original Message-----
> From: buckminster-dev-bounces@eclipse.org on behalf of
>Achim Demelt
> Sent: Mon 25/01/2010 18:14
> To: Buckminster developer discussions
> Subject: Re: [buckminster-dev] junit tests in headless
>buckminster
> Hi Dieter,
> The Buckminster JUnit and EclEmma code has been committed
>to the Buckminster
> repository at eclipse.org. You can find the features on
>our regular p2 sites,
> i.e. the ones you're using anyway to install (headless)
>Buckminster.
> Cheers,
>  Achim
> On Monday 25 January 2010 18:03:26 Cailliau, Dieter
>wrote:
>> I was wondering how to integrate my junit tests in the
>>headless build
>>  procedure. Is this still up to date:
>>  http://code.google.com/p/buckminster-contrib/wiki/Buckmins terJUnit
>>? If i
>>  do so, it stops with a NullPointerException:
>> x@x:/usr/local/hbm$ ./buckminster -data /tmp/x1 -L DEBUG
>>-consoleLog junit
>>  -l /plugins/com.x.util/src-test.launch !SESSION
>>2010-01-25 19:50:18.752
>>eclipse.buildId=unknown
>> java.version=1.5.0_14
>> java.vendor=Sun Microsystems Inc.
>> BootLoader constants: OS=linux, ARCH=x86, WS=gtk,
>>NL=en_US
>> Framework arguments:  -L DEBUG junit -l
>> Command-line arguments:  -data /tmp/x1 -L DEBUG
>>-consoleLog junit -l
>> !ENTRY org.eclipse.buckminster.runtime 0 293 2010-01-25
>>19:50:22.546
>> !MESSAGE junit '-l' '/plugins/com.x.util/src-test.launch'
>> java.lang.NullPointerException
>> DISCLAIMER:
>> Unless indicated otherwise, the information contained in
>>this message is
>>  privileged and confidential, and is intended only for
>>the use of the
>>  addressee(s) named above and others who have been
>>specifically authorized
>>  to receive it. If you are not the intended recipient,
>>you are hereby
>>  notified that any dissemination, distribution or copying
>>of this message
>>  and/or attachments is strictly prohibited. The company
>>accepts no
>>  liability for any damage caused by any virus transmitted
>>by this email.
>>  Furthermore, the company does not warrant a proper and
>>complete
>>  transmission of this information, nor does it accept
>>liability for any
>>  delays. If you have received this message in error,
>>please contact the
>>  sender and delete the message. Thank you.
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
> DISCLAIMER:
>this message is privileged and confidential, and is
>intended only for the use of the addressee(s) named above
>and others who have been specifically authorized to
>receive it. If you are not the intended recipient, you are
>hereby notified that any dissemination, distribution or
>copying of this message and/or attachments is strictly
>prohibited. The company accepts no liability for any
>damage caused by any virus transmitted by this email.
>complete transmission of this information, nor does it
>accept liability for any delays. If you have received this
>message in error, please contact the sender and delete the
>message. Thank you.
Nick Boldt :: JBoss by Red Hat
Productization Lead :: JBoss Tools & Dev Studio
Release Engineer :: Dash Athena
http://nick.divbyzero.com
Previous Topic:Re: [buckminster-dev] junit tests in headless buckminster
Next Topic:Re: [buckminster-dev] junit tests in headless buckminster
Current Time: Thu May 23 02:51:47 EDT 2013
Powered by FUDForum. Page generated in 0.01729 seconds
