| RE: [buckminster-dev] junit tests in headless buckminster [message #509903] |
Mon, 25 January 2010 12:30 |
Originally posted by: dieter.cailliau.barco.com
------_=_NextPart_001_01CA9DE4.4E99B2D3
Content-Type: text/plain;
charset="iso-8859-1"
I need an archived update site (containing the =
org.eclipse.buckminster.junit.feature.feature.group ? )
This is not mentioned on this page: =
http://www.eclipse.org/buckminster/downloads.html=20
so i don't know where to find it.
-----Original Message-----
From: buckminster-dev-bounces@eclipse.org on behalf of Achim Demelt
Sent: Mon 25/01/2010 18:14
To: Buckminster developer discussions
Subject: Re: [buckminster-dev] junit tests in headless buckminster
=20
Hi Dieter,
The Buckminster JUnit and EclEmma code has been committed to the =
Buckminster=20
repository at eclipse.org. You can find the features on our regular p2 =
sites,=20
i.e. the ones you're using anyway to install (headless) Buckminster.
Achim
On Monday 25 January 2010 18:03:26 Cailliau, Dieter wrote:
> I was wondering how to integrate my junit tests in the headless build
> procedure. Is this still up to date:
> http://code.google.com/p/buckminster-contrib/wiki/Buckminste rJUnit ? =
If i
> do so, it stops with a NullPointerException:
>=20
> x@x:/usr/local/hbm$ ./buckminster -data /tmp/x1 -L DEBUG -consoleLog =
junit
> -l /plugins/com.x.util/src-test.launch !SESSION 2010-01-25 =
19:50:18.752
eclipse.buildId=3Dunknown
> java.version=3D1.5.0_14
> java.vendor=3DSun Microsystems Inc.
> BootLoader constants: OS=3Dlinux, ARCH=3Dx86, WS=3Dgtk, NL=3Den_US
> Framework arguments: -L DEBUG junit -l =
> Command-line arguments: -data /tmp/x1 -L DEBUG -consoleLog junit -l
>=20
> !ENTRY org.eclipse.buckminster.runtime 0 293 2010-01-25 19:50:22.546
> !MESSAGE junit '-l' '/plugins/com.x.util/src-test.launch'
> java.lang.NullPointerException
>=20
>=20
> DISCLAIMER:
> Unless indicated otherwise, the information contained in this message =
is
> privileged and confidential, and is intended only for the use of the
> addressee(s) named above and others who have been specifically =
authorized
> to receive it. If you are not the intended recipient, you are hereby
> notified that any dissemination, distribution or copying of this =
message
> and/or attachments is strictly prohibited. The company accepts no
> liability for any damage caused by any virus transmitted by this =
email.
> Furthermore, the company does not warrant a proper and complete
> transmission of this information, nor does it accept liability for =
any
> delays. If you have received this message in error, please contact =
the
> sender and delete the message. Thank you.
>=20
_______________________________________________
buckminster-dev mailing list
buckminster-dev@eclipse.org
https://dev.eclipse.org/mailman/listinfo/buckminster-dev
DISCLAIMER:
Unless indicated otherwise, the information contained in this message is =
privileged and confidential, and is intended only for the use of the =
authorized to receive it. If you are not the intended recipient, you are =
hereby notified that any dissemination, distribution or copying of this =
message and/or attachments is strictly prohibited. The company accepts =
no liability for any damage caused by any virus transmitted by this =
email. Furthermore, the company does not warrant a proper and complete =
transmission of this information, nor does it accept liability for any =
delays. If you have received this message in error, please contact the =
Content-Type: application/ms-tnef;
name="winmail.dat"
eJ8+IgQRAQaQCAAEAAAAAAABAAEAAQeQBgAIAAAA5AQAAAAAAADoAAEIgAcA GAAAAElQTS5NaWNy
b3NvZnQgTWFpbC5Ob3RlADEIAQ2ABAACAAAAAgACAAEEgAEAOgAAAFJFOiBb YnVja21pbnN0ZXIt
ZGV2XSBqdW5pdCB0ZXN0cyBpbiBoZWFkbGVzcyBidWNrbWluc3RlcgCAFQEF gAMADgAAANoHAQAZ
ABIAHgAOAAEAOgEBIIADAA4AAADaBwEAGQASACAAAwABADEBAQmAAQAhAAAA RkY1N0U0OTZGNzVF
RjE0NkFGMTBFRjZGQjQzQ0ZCRjkAmgcBA5AGAGAPAAA5AAAAAwAmAAAAAAAD ADYAAAAAAEAAOQDf
Lt8N5J3KAR4APQABAAAABQAAAFJFOiAAAAAAAgFHAAEAAAAzAAAAYz1CRTth PVJUVDtwPUJBUkNP
O2w9S05ETUVYMDEtMTAwMTI1MTczMjAzWi0xODY4ODMAAB4ASQABAAAAOgAA AFJlOiBbYnVja21p
bnN0ZXItZGV2XSBqdW5pdCB0ZXN0cyBpbiBoZWFkbGVzcyBidWNrbWluc3Rl cgAAAEAATgCArAvM
4Z3KAR4AWgABAAAAJAAAAGJ1Y2ttaW5zdGVyLWRldi1ib3VuY2VzQGVjbGlw c2Uub3JnAAIBWwAB
AAAAZQAAAAAAAACBKx+kvqMQGZ1uAN0BD1QCAAAAAGJ1Y2ttaW5zdGVyLWRl di1ib3VuY2VzQGVj
bGlwc2Uub3JnAFNNVFAAYnVja21pbnN0ZXItZGV2LWJvdW5jZXNAZWNsaXBz ZS5vcmcAAAAAAgFc
AAEAAAApAAAAU01UUDpCVUNLTUlOU1RFUi1ERVYtQk9VTkNFU0BFQ0xJUFNF Lk9SRwAAAAAeAF0A
AQAAAA0AAABBY2hpbSBEZW1lbHQAAAAAAgFeAAEAAABBAAAAAAAAAIErH6S+ oxAZnW4A3QEPVAIA
AAAAQWNoaW0gRGVtZWx0AFNNVFAAYS5kZW1lbHRAZXh4Y2VsbGVudC5kZQAA AAACAV8AAQAAABwA
AABTTVRQOkEuREVNRUxUQEVYWENFTExFTlQuREUAHgBmAAEAAAAFAAAAU01U UAAAAAAeAGcAAQAA
ACQAAABidWNrbWluc3Rlci1kZXYtYm91bmNlc0BlY2xpcHNlLm9yZwAeAGgA AQAAAAUAAABTTVRQ
AAAAAB4AaQABAAAAFwAAAGEuZGVtZWx0QGV4eGNlbGxlbnQuZGUAAB4AcAAB AAAANgAAAFtidWNr
bWluc3Rlci1kZXZdIGp1bml0IHRlc3RzIGluIGhlYWRsZXNzIGJ1Y2ttaW5z dGVyAAAAAgFxAAEA
AAAbAAAAAcqd4da8eWScS4qVRva9Dxk704YgxAAAjch+AB4AdAABAAAAIgAA AEJ1Y2ttaW5zdGVy
IGRldmVsb3BlciBkaXNjdXNzaW9ucwAAAB4AGgwBAAAAEQAAAENhaWxsaWF1 LCBEaWV0ZXIAAAAA
HgAdDgEAAAA2AAAAW2J1Y2ttaW5zdGVyLWRldl0ganVuaXQgdGVzdHMgaW4g aGVhZGxlc3MgYnVj
a21pbnN0ZXIAAAACAQkQAQAAAHMHAABvBwAA0gwAAExaRnVhzVR+AwAKAHJj cGcxMjXiNgNDdGV4
BUEBAwH3/wqAAqQD5AcTAoAP8wBQBFY3CFUHshElMgLjAgBjaOEKwHNldDIG AAbDESX2MwRGE7cw
EiwRMwjvCfe2OxgfDjA1ESIMYGMAUDMLCQFkMzYWUAumIEnkIG4J4GQgA5EK wBPQhGl2HTF1cGRh
DrD2IACQHmEoBaACMAtxC4AwZyB0aB5wBbBnLk0FkGwFIBQQLmIa0GsKbQuA cw6wci5qdeEDAHQu
ZmUeUAhwIIAHIcYJwAhgcCA/ICk7CqIKgFQdwAQgI9Fub/cFQAeAAjBpAiAd MQIgH5GDI9EKsGdl
OiBoAkDgcDovL3cmYCAXH+GCLyCpL2Rvd24XsNBhZHMuJfBtAyEjY5RzbyPw ICggbicFQPZrJDAH
4HcfsBggH5ApgL5mC4AdQCGRI1Qrii0sonpPBRBnC4AHQAXQB5BzdyWhLKMj VEYDYSXQIKktWQEA
di0G4CFwYweQQJMmqSUCYmUT4GxmH9CFMcBBHbFtIERlB4C8bHQjVAZgAjAl 0E0lEaEOMC8wMS8B
0DEWUKAxODoxNCNVbyXQnkIguCmwL9AyoG9wNgJZBABjdQQQJLFzMtV1rGJq BZAzYVIlwVsvDdxd
ICFjH5AHkHQj4QOgex+wKIBsLZEu+iNUKQVI7SmgRAiQISEsK4ojsB5wuTV6 SlU58gBwHUBFIDB0
RW0AwCAFoAEAJeBh/zsxCeFAQUAQHqAOsB1AKtHPH6I1eiNUGCBwbx6RBbCO eR1QBUAmqS4gWQhg
/0BAA5ErAx+iIcUEICURCGGyIBggZ3ULYAXAcBRA6R6ScywpBWkgEETwH6Pr HRAEIHkIYCcqoTcQ
H2LxAHB5d2FD8CrRIPIHQLUDICg6xik1ait7Qx+w3wSQSBA8BTITK4pPA6Az kd8eQEPwDjA/IABw
dQrAUBHBNEUwMzoyNhIgC3D7S0AHMHVIID0EKmADYA6wujojVD4c4UqABCB3 T9H7BnEfcWgqQUrD
DrAJwB5S/m1D8DndH6I6yQMQCzFTVPclgANgMEBkIgIc4AQgJUP/IRBR4R4R KsIeQlMnJeZAUlEi
sG9vZzsALkExL1pwJ1otHvIFEGImUGm4a2kvNXk/NCMgSTHA7wCgWBYoIB6A b0ggOgEhEHc2gFPx
HqBoHVAHsEdQbMRQb1UickV4MEAFMMcksVMnUzZ4QHgmMDcQBygAF7BFUGwv aGJt6CQgLidaIC+w
HlBAMKYvKNBc0HgxZlBMMmDwRUJVR2ZQHvEpcDsA7kxcQDnEWActAyBcwApA BS0hc1vBbS54LnWl
WdEvZKBjLToyLgtgAzAhYbAhU0VTU0lUT05Q0y00AC1QMTEQOTo1MDSgOC43 /jUTUGj3bn9vj3Ba
RDdXs3hJZD0hcCoiC5BTRWpwYXZhLh3gFAAksT3AMS41LjBfNLZzR3srIAWw PTfgT6EN4ANgc+p5
IRFtBCBJMDArdVOQ+kJcMHRoUCiAEoFn4gGQxQIwcyXQT1M9IEBQgAJ4SCBB UkNIPXgUODZIIFd5
MGd0axFIIE5MPQnwX1VTm1M2LqBhB4BUEHJrHYH/R0AkcnjxZzg51Gl/ao9r kv9TNghQQBErIH4w
C4AecHyL/2Z/Z4991lgHfm9/f4CHUzbAIUVOVFJZH98g5i5yIXAkoAeAIBZQ MjnWM2xvUYAydEA0
DlCIpqJNbAFBR0U5xSd+MM4njrCF74b/aCdy545/34+PkJ9zJwtgH3AuYf8k sQNjTlM2RElTQ0xB
+kmN4FJTJz9AOwMrEQ3g1x5RJPEfoXID8WVIIB+i+wuAAhByAMAkonhiHyId Mf9WsyPRB4EtsiPx
WAkd0AMQ/0cwHTMdQB7xKwABACSRB0C/SCA/kiPSVTFUMSTybEPw/5wRH5M3 EB/BMcAfoVgHKIDm
ZEZxFBBlKEvxLUAHgP8dQQbgHeA/g5sDU/FUsECR66UxQONzNpBjBpCakUtA 70Pxk5BUsAUQegmA
WAcq0f8YIDBAHdErQl+iSYEdgR5w/yQym7ShZakhBSAIkAIwSCDzqhYqgmJ5 WAckMacxQaL/E+A/
ckPwNtEUECDhnFNIIJ820V3ik5FGsnhScHkfYu+i452oo0grIC8FsR5QAZD/ E9B8wyPyr/I4MKHx
WJEdwPpiHqFkRPA+MkExCrCusX8A0GLCJBJYB1IBtRCJ4HT/ogSuo3wAnhJF UKKhHUCtEP+uk58w
iwBZUVVwAIBBZblx/yVDMoBR0Xc3e9AIcJsSBGB/GCCblLXGKCAHkSQySoBy /7pRP3FYgjaSn7SD
IDsADrD/qGi6VDcjsUeb+UggJDA2Ef++Ej9itlO3b60oAQALYHaQ/6nHplOp JUXCnaoDoASQA2D/
PVAlgDsAQLC1oh8RODCjC/8UEFQyP4PF4T0hH5Od1bVi3wBwfGBJgXc3I1Rf zk/PX//QKiNULw0k
YFHRH2KJ4CEQ/9E/L7IweiNUJfJ48CZAL8H/Jpu7kgOBZMCv4ZvyXOsvwQUr in3aEAAeADUQAQAA
AD4AAAA8MDI4QUU4QTdDMDRFRTE0ODg5QkU5OUU1NDUwQkUzMkQwNjE4MTNE NkBrbmRtZXgwMS5i
YXJjby5jb20+AAAAHgA5EAEAAABzAAAAPDAyOEFFOEE3QzA0RUUxNDg4OUJF OTlFNTQ1MEJFMzJE
MDYxODEzRDVAa25kbWV4MDEuYmFyY28uY29tPiA8YTE0MTE1ODljN2EwY2M5 OThhNzYwM2VmZWJk
YTE5ODZmMTNkNDNhMEBsb2NhbGhvc3Q+AAAeAEcQAQAAAA8AAABtZXNzYWdl L3JmYzgyMgAACwDy
EAEAAAAfAPMQAQAAAIAAAABSAEUAJQAzAEEAIABbAGIAdQBjAGsAbQBpAG4A cwB0AGUAcgAtAGQA
ZQB2AF0AIABqAHUAbgBpAHQAIAB0AGUAcwB0AHMAIABpAG4AIABoAGUAYQBk AGwAZQBzAHMAIABi
AHUAYwBrAG0AaQBuAHMAdABlAHIALgBFAE0ATAAAAAsA9hAAAAAAQAAHMN8u 3w3kncoBQAAIMI93
nk7kncoBAwDeP69vAAADAPE/CQQAAB4A+D8BAAAAEQAAAENhaWxsaWF1LCBE aWV0ZXIAAAAAAgH5
PwEAAABEAAAAAAAAANynQMjAQhAatLkIACsv4YIBAAAAAAAAAC9PPUJBUkNP L09VPUFHMDAxL0NO
PVJFQ0lQSUVOVFMvQ049RElFQwAeAPo/AQAAABUAAABTeXN0ZW0gQWRtaW5p c3RyYXRvcgAAAAAC
Afs/AQAAAB4AAAAAAAAA3KdAyMBCEBq0uQgAKy/hggEAAAAAAAAALgAAAAMA /T/oBAAAAwAZQAAA
AAADABpAAAAAAAMAHUAAAAAAAwAeQAAAAAAeADBAAQAAAAUAAABESUVDAAAA AB4AMUABAAAABQAA
AERJRUMAAAAAHgAyQAEAAAAkAAAAYnVja21pbnN0ZXItZGV2LWJvdW5jZXNA ZWNsaXBzZS5vcmcA
HgAzQAEAAAAXAAAAYS5kZW1lbHRAZXh4Y2VsbGVudC5kZQAAHgA4QAEAAAAF AAAARElFQwAAAAAe
ADlAAQAAAAIAAAAuAAAAAwB2QP////8LACkAAAAAAAsAIwAAAAAAAwAGEHf0 StYDAAcQjwgAAAMA
EBAAAAAAAwAREAAAAAAeAAgQAQAAAGUAAABJTkVFREFOQVJDSElWRURVUERB VEVTSVRFKENPTlRB
SU5JTkdUSEVPUkdFQ0xJUFNFQlVDS01JTlNURVJKVU5JVEZFQVRVUkVGRUFU VVJFR1JPVVA/KVRI
SVNJU05PVE1FTlRJAAAAAAIBfwABAAAAPgAAADwwMjhBRThBN0MwNEVFMTQ4 ODlCRTk5RTU0NTBC
RTMyRDA2MTgxM0Q2QGtuZG1leDAxLmJhcmNvLmNvbT4AAACLeA==
------_=_NextPart_001_01CA9DE4.4E99B2D3--
FUDForum. Page generated in 0.01594 seconds
