Home » Language IDEs » AJDT » bug 92163 ?
bug 92163 ? [message #50778] Fri, 22 April 2005 08:05 Go to next message
Barry Kaplan is currently offline Barry Kaplan
Any clue what might be the problem here. I'm essentially locked out of using ADJT, and I'm starting to get the shakes.
thanks!
-barry
Re: bug 92163 ? [message #50805 is a reply to message #50778] Fri, 22 April 2005 08:56 Go to previous messageGo to next message
Sian January is currently offline Sian January
Member
Hi Barry,
Would you be able to try this with the latest development build and let
us know if you still have the problem? The code that appeared to
produce that exception has been completely overhauled this week so
hopefully the latest build should fix your problem. Development builds
are available from the AJDT download page:
http://www.eclipse.org/ajdt/download.html
Sian
> thanks!
> -barry
Re: bug 92163 ? [message #50859 is a reply to message #50805] Fri, 22 April 2005 11:30 Go to previous messageGo to next message
Yes, I'll try and let you know. Thanks.
-barry
Re: bug 92163 ? [message #50887 is a reply to message #50805] Fri, 22 April 2005 11:35 Go to previous messageGo to next message
Sian January wrote:
> Hi Barry,
This version is for 3.1M6?
-barry
Re: bug 92163 ? [message #50915 is a reply to message #50805] Fri, 22 April 2005 11:37 Go to previous message
Sian January wrote:
> Hi Barry,
Do you mean 1.2.0.20050420095141? If so, that is what I was using.
-barry
Re: bug 92163 ? [message #587783 is a reply to message #50778] Fri, 22 April 2005 08:56 Go to previous message
Member
Hi Barry,
Sian
> thanks!
> -barry
Re: bug 92163 ? [message #587813 is a reply to message #50805] Fri, 22 April 2005 11:30 Go to previous message
-barry
Re: bug 92163 ? [message #587816 is a reply to message #50805] Fri, 22 April 2005 11:35 Go to previous message
Sian January wrote:
> Hi Barry,
-barry
Re: bug 92163 ? [message #587824 is a reply to message #50805] Fri, 22 April 2005 11:37 Go to previous message
Sian January wrote:
> Hi Barry,
-barry
Previous Topic:AspectJ nature breaks JUnit plug-in
Next Topic:Large jar on InPath
Current Time: Mon May 20 01:12:42 EDT 2013
Powered by FUDForum. Page generated in 0.02614 seconds
