Home » Eclipse Projects » Eclipse Communications Framework (ECF) » Integrating the Communication perspective within my own RCP application
Integrating the Communication perspective within my own RCP application [message #508374] Mon, 18 January 2010 10:33 Go to next message
Giovanna  is currently offline Giovanna
Dear all,
I am just starting to use Eclipse and ECF in particular, so please excuse me if I am asking a silly question.
My problem is that I am having several difficulties in integrating ECF within a rich client application I developed.
What I would like to do is to add the Communication perspective to my own application, so as to enhance it with the communication capabilities offered by the ECF.
To this end, I added the ECF, as well as the required plugins, to my target platform and modified my plugin.xml file in order to include the communication perspective id. Unfortunately this is not enough.
Can somebody please tell me what I need to do to properly include the Communication perspective, togheter with all the functionalities it provides, into my own RCP application?
Thank you so much,
Cheers
Giovanna
Re: Integrating the Communication perspective within my own RCP application [message #508563 is a reply to message #508374] Tue, 19 January 2010 08:03 Go to previous messageGo to next message
Remy Suen is currently offline Remy Suen
Giovanna wrote on Mon, 18 January 2010 10:33
I'm not sure I understand what you're trying to achieve here.
Which bundles did you add? And why are you modifying your own plugin.xml anyway?
Re: Integrating the Communication perspective within my own RCP application [message #508647 is a reply to message #508563] Tue, 19 January 2010 12:34 Go to previous messageGo to next message
Remy Suen wrote on Tue, 19 January 2010 08:03
Dear Remy,
First of all thank you for your help!
Actually I did several attemps, trying to succeed in integrating ECF into at least an empty RCP application.
I started by adding the org.eclipse.ecf and the org.eclipse.ecf.identity bundles.
I modified my plugin.xml file so as to add a perspective extension, specifying there the Communication perspective id: I though this was needed to add a perspective to my application. Is this wrong?
Thank you again for your kind help,
Cheers
Re: Integrating the Communication perspective within my own RCP application [message #508690 is a reply to message #508647] Tue, 19 January 2010 16:09 Go to previous messageGo to next message
Giovanna wrote on Tue, 19 January 2010 12:34
The perspective is defined in the org.eclipse.ecf.ui bundle, I believe. The two bundles you listed makes no contributions to the user interface.
Extensions are processed by the workbench as the bundles are read. If you want the perspective, just make sure you have the bundle noted above and you should be okay.
Re: Re: Integrating the Communication perspective within my own RCP application [message #508696 is a reply to message #508647] Tue, 19 January 2010 11:50 Go to previous messageGo to next message
Wim Jongman is currently offline Wim Jongman
Hi Giovanna,
The perspective extension you are trying to use does not add the perspective
to the RCP but it adds a shortcut to your perspective to open the
communications perspective. The bundle that contains the ecf perspective
(i.e. the one that uses the org.eclipse.ui.perspective extension point) must
be added to the list of required plugins in your RCP. This is the bundle that
Remy suggests.
A perspective is a framework that can be extended by other plugins. Just by
adding the perspective probably does not give you everything you can see. You
need to know which bundles to include. One trick is to use the plugin spy
ALT+SHIFT+F1 & ALT+SHIFT+F2 to identify the bundles that you want to include
in your RCP.
Best Regards,
Wim Jongman
-- Who's General Failure & why is he reading my disk?
(Eclipse Old Skool Quote Service)
anyway?
> Dear Remy,
bundles.
> Cheers
Re: Re: Integrating the Communication perspective within my own RCP application [message #508814 is a reply to message #508696] Wed, 20 January 2010 07:59 Go to previous message
Dear Remy and Wim,
thanks to your suggestions I finally understood the mistakes and everything is woking now!
Thank you again for your invaluable and kind help,
Cheers
[Updated on: Wed, 20 January 2010 08:01]
Report message to a moderator
Previous Topic:ECF Rest: Bug 297239 (requestEntity)
Next Topic:Integrating the Communication perspective within my own RCP application
Current Time: Sun May 26 01:32:26 EDT 2013
Powered by FUDForum. Page generated in 0.01648 seconds
