Home » Eclipse Projects » Eclipse Communications Framework (ECF) » ECF Rest: Bug 297239 (requestEntity)
ECF Rest: Bug 297239 (requestEntity) [message #507866] Thu, 14 January 2010 17:18 Go to next message
Andre Dietisheim is currently offline Andre Dietisheim
Hi Scott
I found some time to hack again today. I catched up with your latest
changes. I therefore dropped my unfinished approach and I try to
concentrate on submitting a patch that brings a mock to ecf.
I had an approach that provided different parameter types (Get-, Post-,
etc.) and double dispatched back to the service. There was pretty much
work ahead an your current implementation (that test by
postRequestType.useRequestEntity()) pretty much fullfills the need.
Just a remark: My impression is that the API is not very fluent so far.
Building a container first, an adapter afterwards, getting the service
and disposing the reference and the container in the end's quite a lot
of work and API). I was thinking about providing simplification. What
about a builder? Any other ideas?
Greetings
André
Re: ECF Rest: Bug 297239 (requestEntity) [message #508160 is a reply to message #507866] Sat, 16 January 2010 16:22 Go to previous message
Scott Lewis is currently offline Scott Lewis
Hi Andre,
Ande Dietisheim wrote:
> Hi Scott
Ok, great. There are some remaining issues with this post support
however...for example, how to handle/allow service proxies to be used.
Since the container/adapter structure allows ECF to support a variety of
APIs (in addition to remote services)...and deep extensibility, we
won't/can't eliminate that aspect of ECF. But you (and anyone else) are
more than welcome to propose/contribute API simplifications and/or
additions.
One possibility, for example, would be to have a new subclass of
RemoteServiceContainer...e.g. RestRemoteServiceContainer...although I
haven't thought this through at all.
We should probably move these discussions, though...from the newsgroup
to the ecf-dev at eclipse.org mailing list...just so that we can have a
more technical discussion...as more of the committers and regular
contributors regularly monitor that mailing list (than the newsgroup).
Scott
Re: ECF Rest: Bug 297239 (requestEntity) [message #625020 is a reply to message #507866] Sat, 16 January 2010 16:22 Go to previous message
Hi Andre,
> Hi Scott
additions.
Scott
Previous Topic:ECF Rest: Bug 297239 (requestEntity)
Next Topic:Integrating the Communication perspective within my own RCP application
Current Time: Sat May 25 21:19:14 EDT 2013
Powered by FUDForum. Page generated in 0.01573 seconds
