| PDE Build not working in command line [message #507239] |
Tue, 12 January 2010 05:20 |
Shiva Selvadurai Messages: 25 Registered: July 2009 Location: Bangalore |
Junior Member |
I tried PDE build process a described in http://www.vogella.de/articles/EclipsePDEBuild/article.html. The build works fine. When i run the same using java -jar <eclipseInstall>/plugins/org.eclipse.equinox.launcher_<version >.jar -application org.eclipse.ant.core.antRunner -buildfile <<eclipseInstall>/plugins/org.eclipse.pde.build_<version>/scripts/productBuild/productBuild.xml > -Dbuilder=<path to the build configuration folder>
in command line it doesn't work. I'm planning to integrate my app with cruisecontrol for continous integration, is there any way to run the build in cruisecontrol or in commandline
FUDForum. Page generated in 0.01479 seconds
