| Re: Error Installing from Web Tools (WTP) Update Site [message #506977 is a reply to message #482851] |
Mon, 11 January 2010 05:31  |
Christian Bayer Messages: 2 Registered: January 2010 |
Junior Member |
I am having exactly the same problem with Eclipse 3.4 based Rational Software Architect 7.5.4. I do also have dozens of plugins installed, don't know which one initially pulled javax.wsdl [1.6.2.v200806030405].
WTP refuses to install because this exact requirement is missing, which is obviously there:
As a matter of facts javax.wsdl_1.6.2.v200806030405.jar is in the plugins directory and is loaded on startup - if I delete it from the plugins directory, the IDE hangs with "initializing plugins" or something like that. So you cannot use Update manager to install an older version of it. WSDL 1.5.2 cannot be installed when 1.6.2 is present, because Update Manager complains that a newer version is installed...
Putting a WSDL 1.5.1-jar changes nothing, either it is not properly installed or simply ignored. To make it even worse I do not even know if the WTP will run with WSDL 1.5.
| Re: Error Installing from Web Tools (WTP) Update Site [message #570463 is a reply to message #482908] |
Sun, 30 August 2009 18:55  |
Steven McArdle Messages: 5 Registered: July 2009 |
Junior Member |
OK,
So what is the correct update site for Ganymede 3.4 ? I am using the webtools/updates site.
Is this todo with some SUN licensing issue such that javax packages cannot be delivered via updates? Something similar to issues with SUN libraries using Maven?
The entry in the plugins directory must have been installed by another plugin, but it is not seen by the webtools update and fails to install
I am not about to give a detailed description of all the plugins I have as I have dozens of them.
It must be pretty easy for one of the developers to trace at what point this library is required, where from and the reasons for it not being available.
The more I use the new update manager the more I hate it. The messages it produces are to cryptic and absolutely no help in problem tracking for users.
Steven McArdle
| Re: Error Installing from Web Tools (WTP) Update Site [message #570529 is a reply to message #570463] |
Mon, 31 August 2009 13:19  |
David Williams Messages: 176 Registered: July 2009 |
There isn't one. We assume you install it and you're done. See
http://wiki.eclipse.org/WTP/Retention_Policy
> being available.
That "developer" to debug your problem will have to be you. You'd at
least need to narrow it down some. For example, explain what you are
trying to do. Ideally what you have done in the past to get to this
point. But, perhaps now that you know there is no update site for
Ganymede level of WTP, perhaps it is not really a problem.
FUDForum. Page generated in 0.01843 seconds
