Home » Eclipse Projects » Plugin Development Environment (PDE) » Handling of extracted nested jar files
Handling of extracted nested jar files [message #506447] Thu, 07 January 2010 09:58 Go to next message
Eclipse User
Originally posted by: Jens.Borrmann.gillardon.de
like many others I have come to the conclusion that it can be a good
idea not to use nested jar files in an OSGi bundle. Now I have some
problems to convince Eclipse to handle this properly.
Let's say I have a library third party library somelibrary.jar with
package somepackage containing a class file SomeClass.class. I need
SomeClass in my own bundle that. I would like to something like the
following structure for my bundle:
src
main
java
mypackage
MyClass.java
classes
somepackage
SomeClass.class
META-INF
Manifest.MF
I do not want to put the packages from somelibrary.jar on the root of my
bundle since this can become quite nasty (Today I saw a jar containing a
top level package called temp...).
In build.properties I edited source..
source.. = src/main/java/,src/main/classes/
If I use the export wizard for exporting the plugin as a jar file
everything works well and somepackage can be found at the root of the
newly created jar file.
The only problem with my approach is that the manifest wizard for my
bundle does not "know" somepackage. If I try to add an Exported Package
on the Runtime tab I am only offered mypackage and not somepackage.
Editing MANIFEST.MF manually is possible. So is importing a manually
created export from another bundle.
So I suppose that I am missing a basic trick that would help the PDE
tools to help me. Any suggestions?
--- Jens
Re: Handling of extracted nested jar files [message #506588 is a reply to message #506447] Fri, 08 January 2010 03:21 Go to previous message
ekkehard gentz is currently offline ekkehard gentz
--------------030509080700060402040808
Jens,
if you're using a 3rdParty Library then the best way is to create a
wrapper bundle
only including the classes from 3rd bundle at the root
and exporting these classes
then in your own bundle you can import them
this way its also easy to use a newer version of the 3rdparty jar
or perhaps you can ask the developer of 3rdParty to add OSGI
informations to the MANIFEST
and later use this jar directly inbstead your wraper bundle
ekke
Am 07.01.10 15:58, schrieb Jens Borrmann:
> src
> main
> java
> mypackage
> MyClass.java
> classes
> somepackage
> SomeClass.class
> META-INF
> Manifest.MF
> my bundle since this can become quite nasty (Today I saw a jar
> containing a top level package called temp...).
> Package on the Runtime tab I am only offered mypackage and not
> somepackage. Editing MANIFEST.MF manually is possible. So is importing
> a manually created export from another bundle.
> --- Jens
ekke (ekkehard gentz)
independent software-architect
senior erp-consultant
eclipse | osgi | equinox | mdsd | oaw | emf | uml
max-josefs-platz 30, D-83022 rosenheim, germany
mailto:ekke@ekkes-corner.org
homepage (de): http://gentz-software.de
blog (en): http://ekkes-corner.org
twitter: @ekkescorner
skype: ekkes-corner
Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID: DE189929490
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=ISO-8859-15"
http-equiv="Content-Type">
</head>
<body text="#000000" bgcolor="#ffffff">
Jens,<br>
<br>
wrapper bundle<br>
only including the classes from 3rd bundle at the root<br>
and exporting these classes<br>
<br>
then in your own bundle you can import them<br>
<br>
this way its also easy to use a newer version of the 3rdparty jar<br>
informations to the MANIFEST<br>
and later use this jar directly inbstead your wraper bundle<br>
<br>
ekke<br>
<blockquote cite="mid:hi4sq7$g8h$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
src
<br>
ekke
independent software architect
blog: http://ekkes-corner.org
Re: Handling of extracted nested jar files [message #604025 is a reply to message #506447] Fri, 08 January 2010 03:21 Go to previous message
Jens,
wrapper bundle
ekke
> src
> main
> java
> mypackage
> MyClass.java
> classes
> somepackage
> SomeClass.class
> META-INF
> Manifest.MF
> --- Jens
skype: ekkes-corner
<html>
<head>
</head>
Jens,<br>
<br>
wrapper bundle<br>
<br>
<br>
<br>
ekke<br>
<br>
<br>
<br>
<br>
<br>
src
<br>
ekke
Previous Topic:Handling of extracted nested jar files
Next Topic:Troubles with PDE build and target platform
Current Time: Thu May 23 13:02:08 EDT 2013
Powered by FUDForum. Page generated in 0.05837 seconds
