Home » Eclipse Projects » Simultaneous release » Eclipse Galileo on Kubuntu 9.10(Doesn't work)
Eclipse Galileo on Kubuntu 9.10 [message #506522] Thu, 07 January 2010 10:47 Go to next message
Juan Damián Bernabé is currently offline Juan Damián Bernabé
Hi everybody,
I'm Trying to run eclipse ganymede on Kubuntu 9.10. I've downloaded it already and uncompressed on my home folder. when I execute eclipse the eclipse splash appear, but, eclipse doesnt start, instead, a non-text windows appear. I can't close that window even if I click on the x windo button. To close that I had to use ctrl+c on the console.
On the console appears the following when I execute the command "./eclipse"
(eclipse:5093): GLib-WARNING **: g_set_prgname() called multiple times
What can be happening?
by the way, compiz effects are active.
Thnx!
JCrx,
Re: Eclipse Galileo on Kubuntu 9.10 [message #508151 is a reply to message #506522] Sat, 16 January 2010 11:58 Go to previous messageGo to next message
gia  is currently offline gia
I have the similar problem with the similar warning message since I've upgraded my kubuntu to 9.10. In general, Galileo still works (it was perfect with kubuntu 9.04) but I can't do some essential operations anymore like creating new projects, refactoring some variable names, exporting preferences and many others. For example, if I want to create a new bzr project and I select let's say "Branch as a new project" and then push the "next" button it doesn't respond at all. Is there any solution for this problem? Thanks.
Cheers, Gia
Re: Eclipse Galileo on Kubuntu 9.10 [message #508428 is a reply to message #508151] Mon, 18 January 2010 13:19 Go to previous messageGo to next message
No real name is currently offline No real name
See http://ubuntuforums.org/showthread.php?t=1362942
It's due to the unstable version (2.22.3-0ubuntu1) of libglib2.0-0.
Downgrade it.
Re: Eclipse Galileo on Kubuntu 9.10 [message #510534 is a reply to message #508151] Wed, 27 January 2010 13:38 Go to previous message
Eric Rizzo is currently offline Eric Rizzo
gia wrote on Sat, 16 January 2010 11:58
Cheers, Gia
See http://www.eclipse.org/forums/index.php?t=msg&th=161210& amp;start=0&
Previous Topic:Removing EMF Index from Helios
Next Topic:Eclipse Galileo on Kubuntu 9.10
Current Time: Sat May 25 13:05:56 EDT 2013
Powered by FUDForum. Page generated in 0.01854 seconds
