Home » Eclipse Projects » Web Tools Project (WTP) » How to write validate results to console and not popup?
How to write validate results to console and not popup? [message #506382] Thu, 07 January 2010 06:21 Go to next message
Ben Stover
Assume I load an XML file into Eclipse.
Then I right click on the XML file on the left side and select "Validate". The result is shown as a popup
(e.g. "No validation errors)".
Is it possible to avoid this popup and write the result to the "Cosole" pane an the bottom instead?
Ben
Re: How to write validate results to console and not popup? [message #506441 is a reply to message #506382] Thu, 07 January 2010 09:41 Go to previous messageGo to next message
Ian Tewksbury is currently offline Ian Tewksbury
Member
Ben wrote on Thu, 07 January 2010 06:21
As of right now it is not possible to write the results to the Console view. It is possible to disable the pop up though. To do this go to "Window -> Preferences -> Validation" then deselect the "Show a confirmation dialog when performing manual validations" option.
If the ability to write to the console is an enhancement you would like to request feel free to submit an enhancement request to Bugzilla.
Ian Tewksbury
WTP JavaScript Tools
IBM Rational
“When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return.” ~Leonardo da Vinci
Re: How to write validate results to console and not popup? [message #506442 is a reply to message #506382] Thu, 07 January 2010 09:41 Go to previous message
Member
This was an accidental duplicate post because of browser issues.
Ian Tewksbury
IBM Rational
[Updated on: Thu, 07 January 2010 04:42]
Report message to a moderator
Previous Topic:Memory usage and performance degrade for large files
Next Topic:Republish does not work.
Current Time: Fri May 24 08:26:36 EDT 2013
Powered by FUDForum. Page generated in 0.02084 seconds
