Home » Eclipse Projects » Web Tools Project (WTP) » Security Constraint not working with Tomcat Server in Eclipse
Security Constraint not working with Tomcat Server in Eclipse [message #506005] Tue, 05 January 2010 13:29
Aloha  is currently offline Aloha
Hi there,
The only security constraint I can seem to get working in my Web project is /*
I have made a folder called private under the WebContent dir and tried to constrain it using the url-pattern /private/* but it doesn't register it as a constrained resource at all.
Is there anything else I need to configure in my web.xml?
Thanks in advance,
Aloha
	<!-- Setting up security -->
	<login-config>
		<auth-method>FORM</auth-method>
		<form-login-config>
			<form-login-page>/login.html</form-login-page>
			<form-error-page>/error.html</form-error-page>
		</form-login-config>
	</login-config>
	<security-role><role-name>admin</role-name></security-role>
	<security-role><role-name>guest</role-name></security-role>
	<security-constraint>
		<web-resource-collection>
			<web-resource-name>ReceiptLogin</web-resource-name>
			<url-pattern>/private/*</url-pattern>
		</web-resource-collection>
		<auth-constraint>
		</auth-constraint>
	</security-constraint>
Previous Topic:our existing web project not recognized in eclipse
Next Topic:WSDL - using IP addr instead of hostname
Current Time: Sat May 25 12:30:56 EDT 2013
Powered by FUDForum. Page generated in 0.01645 seconds
