Home » Eclipse Projects » Plugin Development Environment (PDE) » Newbie, Eclipse Plugin For ActionScript Developers(Need help to develop Inline Preprocessor Plugin Works With Flex)
Newbie, Eclipse Plugin For ActionScript Developers [message #505885] Tue, 05 January 2010 08:40
ali nakipoglu is currently offline ali nakipoglu
I have a an idea of developing a preprocessor that allows ActionScript developers to optimize their code by in lining functions and variables. This plugin will work with Adobe Flex Plugin and modifies source code sent to compiler. I think, to make this happen i need to solve following problems :
If i used Meta Tags to mark which functions and variables will inline, i need to find a way to bypass this meta tags in Eclipse (or Flex) code checking routines. Because Flex will ignores this tags and bubbles errors. Maybe there is a way of introducing this meta tags into Eclipse IDE. I found [Meta Tag] is supported by Flex and its allows to use customs as well.
A way to process this tags and move to desired source code location these inlining functions and variables without developing a whole compiler or source code exploring library. Maybe by utilizing existing Exlipse (or Flex) source code exploring futures.
A way to modify source code sent to compiler.
Im not a java or PDE developer, im experienced actionscript developer who dont want to wait ten years for simple things done by Adobe.
With this community help i believe i can develop this.
Any level of help will be appreciated.
Thank you.
Ali.
Previous Topic:Invalid preference page path: HTML Syntax
Next Topic:Newbie, Eclipse Plugin For ActionScript Developers
Current Time: Thu May 23 17:25:16 EDT 2013
Powered by FUDForum. Page generated in 0.07316 seconds
