| Eclipse without connection any repository [message #505107] |
Sat, 26 December 2009 13:02  |
trompeteandos Messages: 2 Registered: December 2009 |
Junior Member |
Sorry for my english.
I've installed my operating system (Debian Squeeze)
Then i've installed sun-java6-jdk and I've dowloaded eclipse from eclipse.org site.
When I run eclipse, all appears ok, but when I clicked on Help -> Install new Software... and select....Galileo - http://download.eclipse.org/releases/galileo for example I receive the next message:
Unable to read repository at http://download.eclipse.org/releases/galileo/content.xml.
La red es inaccesible
The log file appears:
No repository found at http://download.eclipse.org/releases/galileo.
EXCEPTION STACK TRACE:
org.eclipse.equinox.internal.provisional.p2.core.ProvisionEx ception: No repository found at http://download.eclipse.org/releases/galileo.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.fail(AbstractRepositoryManager.java:380)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:606)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:92)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:88)
at org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.loadMetadataRepository(ProvisioningUtil.java: 88)
at org.eclipse.equinox.internal.provisional.p2.ui.QueryableMeta dataRepositoryManager.doLoadRepository(QueryableMetadataRepo sitoryManager.java:55)
at org.eclipse.equinox.internal.provisional.p2.ui.QueryableRepo sitoryManager.loadRepository(QueryableRepositoryManager.java :195)
at org.eclipse.equinox.internal.provisional.p2.ui.QueryableRepo sitoryManager.loadAll(QueryableRepositoryManager.java:108)
at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryH andler$2.run(PreloadingRepositoryHandler.java:71)
SESSION DATA:
eclipse.buildId=M20090917-0800
java.version=1.6.0_0
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=es_ES
Framework arguments: -product org.eclipse.epp.package.php.product
Command-line arguments: -os linux -ws gtk -arch x86 -product org.eclipse.epp.package.php.product
So, What it's the problem that I can't connect and install new software?
It's happend even if I add new repository...zend pdt for example.
Thank you.
| Re: Eclipse without connection any repository [message #505126 is a reply to message #505107] |
Sun, 27 December 2009 02:30   |
Ed Merks Messages: 24688 Registered: July 2009 |
--------------010207030302040404060005
Content-Type: text/plain; charset=UTF-8; format=flowed
The foundation newsgroup isn't for asking technical questions it's for
asking about the operations of the Eclipse organization. Please use the
platform or newcomers newsgroup for technical questions about the
platform. Your problem sounds a little like this one:
< http://www.eclipse.org/forums/index.php?t=msg&th=159863& amp;start=0&>
> eclipse.org site.
> the next message:
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> SESSION DATA: eclipse.buildId=M20090917-0800
> Thank you.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
the platform or newcomers newsgroup for technical questions about the
platform. Your problem sounds a little like this one:<a
href="http://www.eclipse.org/forums/index.php?t=msg&th=159863&start=0&"><br>
</a>
<blockquote><a
href="http://www.eclipse.org/forums/index.php?t=msg&th=159863&start=0&">http://www.eclipse.org/forums/index.php?t=msg&th=159863&start=0&</a><br>
</blockquote>
<br>
<blockquote cite="mid:hh64lm$g43$1@build.eclipse.org" type="cite">Sorry
for my english.
<br>
<br>
<br>
eclipse.org site.
<br>
<br>
<a class="moz-txt-link-freetext" href="http://download.eclipse.org/releases/galileo">http://download.eclipse.org/releases/galileo</a> for example I receive the
next message:
<br>
<br>
<a class="moz-txt-link-freetext" href="http://download.eclipse.org/releases/galileo/content.xml">http://download.eclipse.org/releases/galileo/content.xml</a>.
<br>
<br>
<br>
<br>
<br>
No repository found at <a class="moz-txt-link-freetext" href="http://download.eclipse.org/releases/galileo">http://download.eclipse.org/releases/galileo</a>.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
software?
<br>
<br>
<br>
<br>
Thank you.
<br>
<br>
</blockquote>
</body>
</html>
--------------010207030302040404060005--
FUDForum. Page generated in 0.01594 seconds
